Trade: home improvement contractor
Crown To Sloped Ceiling
we want to run 2 piece crown ( base + crown ) to the sloped ceiling.It looks like about a 12/12 pitch (45 deg.) and on all four walls (hip roof). The crown we will use will be 37 deg. . My question is should we put the crown tight to the ceiling or hold it down some?
#2 | |
Motorboatin' son of a ...
Re: Crown To Sloped CeilingQuote:
Check out: http://www.contractortalk.com/f13/cr...ceiling-25779/ and http://www.garymkatz.com/TrimTechniq...ansitions.html |
yes thanks..what we have is a trayed ceiling,and a photo covered that.If I want to hold the crown tight to the ceiling,I must rip the top edge on the back.
Do a search, there are alot of discussions on it.
Trade: Framing and General Construction
I dont like the look of that transition. It is a nifty technique for sure but I just dont think it looks proper from an architectural standpoint. I tend not to force transitions that aren't technically supposed to work
Trade: trim carpenter
On shallow vaults, you can just cheat the spring angles and skip the transition piece. If an owner wants crown on a vault and will pay me to do it, I don't talk them out of it. The transition piece is small and the overall effect can look nice, so it is a good thing to be able to do. Here is an interesting view of a vault with crown and the transition pieces at the 4 bottom corners:
http://s436.photobucket.com/albums/q...ree/?start=all |
| Crown on a Drop Ceiling | jim71 | Finish Carpentry | 9 | 04-05-2008 08:47 AM |
| How to install crown on vaulted ceiling | sayoungws | Finish Carpentry | 3 | 11-24-2007 11:58 PM |
| Sloped ceiling in a steam shower | Eric K | Remodeling | 6 | 08-08-2007 06:16 PM |
| Crown questions... is there a consensus? | El Dorado Wood | Finish Carpentry | 14 | 01-04-2007 08:50 PM |
| sloped ceiling recessed lights | zbwmy | Electrical | 4 | 01-09-2006 07:23 AM |
