Trade: Cabinetry, carpentry.
Crown Questions... Is There A Consensus?
Okay... I definitely have my way of handling these little complications, but I've been told by many people that both ways are right... and both ways are wrong. So... what say you?
Crown on a vaulted/pitched celing: When you do crown going from a horizontal ceiling line to a raked ceiling line (a vaulted/pitched ceiling) do you "tilt" the crown on the horizontal wall so that the angle matches the crown running down the raked wall, and only do one cut.... Or do you double cut (joint) the corner so it turns the corner and then turns up the rake? Crown over air registers: When running crown in a room where the middle of the air registers fall along the bottom line of the crown... do you return the crown on each side of the register? Or notch and box out the crown so it goes across the register? How do you do it? And if it's a third way... by all means... speak up. |
Trade: Home building
Re: Crown Questions... Is There A Consensus?
I know Opinions and style vary but around here I see and we do is to put a built up type of corner block. I know its kind of the easy way out but it does look quite nice. If I can figure out how to post pictures I'll post one.
As far as the cold air registers are concerned we try to plan ahead as far as crowned areas go. Usually we'll drop the register so that it butts up into the bottom of the crown. |
I think I figured it out. Here's what common for crown on vaulted cielings around here anyways.
#4 | |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Crown Questions... Is There A Consensus?Quote:
The only way I have ever seen it done properly is with a transition piece.
| The Following User Says Thank You to Mike Finley For This Useful Post: | gutsy rehab (06-04-2010) |
ContractorTalk Flunkie
I hate to see those blocks. They scream... I don't know how to do it right!
T.C. "Never met a man yet that I couldn't learn something from"Met a few you couldn't teach though http://remodelingncarolina.com
Okay... imagine if you will... you're putting crown in one half of a vaulted room. The measurement of the "horizontal" wall is 12' corner to corner. From each corner up the rake to the peak is 10'. If you preassemble a 10'x12'x10' "U" with standard corners... then lift it into place against the ceiling... there's only one "joint" in the corners, however... the spring angle of the horizontal piece is reduced so it will match the rake piece. Not how it's actually installed... but does that make sense?
#7 | |
I know what you mean when you say I don't know how to do it right. I think that every time I see someone use for instance colonial base or casing in built up crown. |
#8 | |
Chief Toilet Mover
I threw together a quick sketch of it using two identical objects and I can't get the profiles to line up. Last edited by Mike Finley; 04-25-2007 at 03:34 PM. |
#9 | |
I'm prolly not 'splaining it well. Try this... you make up a 1' by 1' corner piece with a normal mitered corner. Then... you hold that piece up to the corner where the rake wall meets the horizontal wall. As you rotate the piece on the rake wall up to the ceiling... the piece on the horizontal wall will... umm... tilt back. What you have now is a perfectly seamed corner, but the spring angles of the two pieces are different. In order to make it work, you need to plane the back/bottom of the horizontal piece so it doesn't stand out from the wall and create a gap... basically change the spring angle by planing it. Of course... to do it with a transition piece (like you pictured)... you need to plane the top of the crown so it fits properly against the sloped ceiling... you can see the gap created in the pic you posted. I prefer this method if the isn't a real strong pitch to the ceiling. I hate the look of the transition pieces... they break up the clean lines of the crown. However... if there's a real strong slope to the ceiling, this way looks bad since the horizontal piece has to be tipped so far back it loses it's profile. Hoping that explains it better. |
Chief Toilet Mover
I see what you are saying now. Your crown on the non rake wall ends up being almost flat against the wall.
#11 | |
Yep... except... I would say it ends up "flatter" against the wall... I don't do this on ceilings with rake more than 20 or so degrees past horizontal. Just doesn't look good. In that case... I use a transition piece... or try to talk the HO out of it. He he he. |
#12 | |
If that is what the HO really wants, thats what I'd give them now, but I'd do my best to convince them otherwise.
Chief Toilet Mover
Do you guys ever get into Trim-tex products for architectural details? I'm getting into it more and more. I find myself looking for places to use it on a job site just because it is so cool looking.
Here are a few examples, not my work, but taken from thier website. ![]() ![]() ![]() ![]() ![]()
#14 | |
Transition pieces work well, although I think they look better on a reasonably gentle slope as compared to a steep pitch. Tilting the crown is my favorite, but definately the most work. It requires you to recut the flats of the crown so it can sit tight against the walls and ceilings at it's new angle. If the pitch of the vault is steep enough, you might have to use the next size crown for the wall to be able to force the cuts. It takes some trial and error to get the cuts, unless you are a geometry freak. The register dilema is definately the lesser (only slightly) of two evils to me. I interrupt the crown as you suggest. I never let anyone convince me to run the crown across the grill by notching it. Last edited by troubleseeker; 12-15-2006 at 08:14 PM. |
Trade: Only base and crown.
One name, Gary Katz. One website for help on this transition GaryMKatz dot com. He has a great DVD collection. Buy the three of them it runs around $129.00. It gives you great ideas to speed up all aspects. Learning the techniques he offers will improve your style even if your only taking away some of the information and manipulating it to your own style. Best of luck. I bought them and it has helped me.
IMHO. |
| space above crown | ch0mpie | Finish Carpentry | 6 | 03-06-2007 01:41 AM |
| Nailing Strips for Crown | Mpeters | Finish Carpentry | 5 | 02-24-2007 08:53 PM |
| Crown Molding | SHAWNPAINTS | Painting & Finish Work | 16 | 01-05-2007 02:07 PM |
| Crown Moulding in Joist Bays, opinions. | 415moto | Finish Carpentry | 7 | 11-15-2006 08:24 PM |
| Crown Moulding Questions | DecksEtc | Carpentry | 23 | 09-23-2005 06:33 PM |
