Crown Moulding Cope Or Miter Joints?
Old 03-15-2009, 08:53 AM   #81
m1911's Avatar
Trade: trim carp
Re: Crown Moulding Cope Or Miter Joints?
[quote=loneframer;636307]
Originally Posted by Gus Dering View Post
Funny thing is, that guy right there could kick our asses and not break a sweat. By the way I'm not a homo, I'm a no mo sexual, I gotta get another girl. Homie please.
SPEAK FOR YOURSELF FOOL!
m1911 is offline
Old 03-15-2009, 08:59 AM   #82
KemoSabe
loneframer's Avatar
[quote=m1911;636323]
I'll bet Boy George could still kick your ass.
loneframer is offline
Old 03-15-2009, 09:17 AM   #83
m1911's Avatar
Trade: trim carp
did you mean kick or lick?
m1911 is offline
Old 03-15-2009, 09:22 AM   #84
KemoSabe
loneframer's Avatar
Yeah, both, not in any particular order.
Old 03-15-2009, 10:58 AM   #85
Coastal Carp's Avatar
When I learned trim work from My Father, there was never another way to go other than coping. I have found over the years, in "trac" developements, you see mitre cuts everywhere because they want quanity rather then quality . In "custom" work, you see coped joints; takes a little more time but the look is cleaner all the way around... Always cope crown, base......
Coastal Carp is offline
Old 03-15-2009, 12:50 PM   #86
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
All right then you bunch of muther copers, how do you keep your outside miters from separating huh? Cope those too?
willworkforbeer is offline
Old 03-15-2009, 01:44 PM   #87
KentWhitten's Avatar
You don't have any troubles making friends do you?
Salmon Falls Cabinetry
KentWhitten is online now
Old 03-15-2009, 01:49 PM   #88
Funny that you should mention that, haha
Old 03-15-2009, 01:54 PM   #89
basswood's Avatar
Trade: trim carpenter
Here are a few tips for keeping outside miters together.
1) Glue, pin and CLAMP them together (I use Collins clamps)
2) Crown at outside corners should be secured more heavily for 2-3' on each side of the joint and fastened more lightly at the coped ends or ideally the other end of a piece of crown with an outside corner is a butt cut behind a cope. The cope allows the "floating end" of the piece behind it to move.
3) Install outside corners tight to the corner in the dry season, but if it is the humid season or the moisture content of the crown is above 10%, leave a 1/16" gap between the crown and the wall, so when the crown shrinks it can move in toward the corner without "bottoming out" and forcing the miter open. MDF is more stable than wood across the width of the molding but moves more along the long axis... so long runs of MDF crown are helped by running these outside corners slightly long too. The small gaps between the outside corner crown and the wall are caulked with a flexible caulk.
Leaving small gaps behind crown is also a good idea when the crown is installed across the grain of wood columns, posts or newels. In the column photo here I do the same thing with the base and basecap, but hide the gap on the back side of the column.
I do all these things automatically, and hardly give it a thought... this stuff doesn't add anytime to the job.
Crown moulding cope or miter joints?-column-capital-crown-staged-.jpg   Crown moulding cope or miter joints?-cap-w-expansion-gap.jpg
basswood is offline
Crown moulding question davinci Carpentry 14 02-21-2009 10:54 PM
Fypon Crown moulding brailediver Finish Carpentry 17 01-30-2009 09:21 PM
pricing crown moulding boydbuild Finish Carpentry 15 12-19-2008 10:12 PM
Crown Moulding in Joist Bays, opinions. 415moto Finish Carpentry 7 11-15-2006 08:24 PM
Crown moulding miter Q Nutty Carpentry 7 02-23-2006 07:21 AM
