Crown Moulding Cope Or Miter Joints?
Old 03-13-2009, 08:46 PM   #41
KemoSabe
loneframer's Avatar
Re: Crown Moulding Cope Or Miter Joints?
Originally Posted by m1911 View Post
furniture isn't nailed to sheetrock and 2x4's and usually doesn't have 20+ FT runs of crown.
That's when I cope, there again, I havn't seen a stain grade trim package in 15 years or more, that died in the 80s around here, even most of the cabinetry is painted with a glaze wiped finish now. Actually, I'd probably cope stain grade too, unless it was furniture.
loneframer is offline
Old 03-13-2009, 08:59 PM   #42
wood is good
Sooner Pesek's Avatar
Trade: trim carpenter
Actually I ship all our crown to this dance hall in Minnesota and some bearded guy grinds on it for a while, then he sends it back to me.
OK, I cope with a coping saw-haven't had the chance to try the grinder method.
Cheers boys,
Roger
"SKILLED Carpenters aren't CHEAP , CHEAP Carpenters aren't SKILLED " --- saw this on a t-shirt a while back ---
Sooner Pesek is offline
Old 03-13-2009, 09:04 PM   #43
OW! My thumb's Avatar
Trade: Finished /Remod/Decks/ done it all /whatever pays
Dont know if anyone mentioned this or not, but I prefer coping.
OW! My thumb is offline
Old 03-14-2009, 12:01 AM   #44
Multi-tradesman defender
Handymanservice's Avatar
Trade: Handyman
"IF your scared to fail, you don't deserve to be successful!"
"Wise men talk because they have something to say: fools talk because they have to say something."
BTW - it's "YOU'RE" not "YOUR" - unless of course the "scared" BELONGS to you!
Damn, I hate it when I miss something like that.
"You can shear a sheep every year, but you can only skin him once!" Remember that when dealing with your customers and pricing.
http://www.yourhandymansite.com
Handymanservice is offline
Old 03-14-2009, 12:32 AM   #45
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Bass, I have had a grinder in my truck for the last 15 years, and I have never thought of using it for that. My complements man, I think I am done buying blades for my coping saw, and you have the perfect back cut.
Scribbles is offline
Old 03-14-2009, 01:44 PM   #46
eisert's Avatar
Trade: General Remodeling Contractor
Hey Basswod- what kind of wheel are you using on your grinder for your copes? I've never seen/heard of that before and would like to try it out next week. Thanks!
eisert is offline
Old 03-14-2009, 02:00 PM   #47
basswood's Avatar
There is a brief text with the video with some info...
I just use two 36 grit sanding disks, back to back (with no backing). They tend to "potato chip" and have to be pressed together with their cambers in opposition, so that when the arbor nut is tightened down they flatten each other out. Otherwise you get an annoying wobble or worse (they can even hit the guard and detonate).
I takes some practice, but can work great. For just one or two copes, I still use a coping saw.
Regards,
Basswood
basswood is offline
Old 03-14-2009, 04:22 PM   #48
nailman's Avatar
Trade: General
Why would you think I that I am a Troll?
nailman is offline
Old 03-14-2009, 04:42 PM   #49
basswood's Avatar
Mitering crown is for outside corners, furniture and cabinets.
It is simply the best practice to cope inside corners on crown installed at the wall/ceiling. Mitered inside corner joints very often fail and open up. Coping done well looks as good as perfect miters and is a more forgiving joint.
All the inside corners in this picture of 6-1/2" crown are coped and were perfectly tight joints without caulk.
I also use copes to hold one end of the crown, working solo, and install the crown in reverse order (if you can visualize that). Works great.
I was just razzing you with the troll label... but coping is really the way to go.
Regards,
Bass
basswood is offline
Old 03-14-2009, 04:55 PM   #50
nailman's Avatar
Trade: General
I got to try that, Hanging crown Thur. by myself and it really sucked.
nailman is offline
Old 03-14-2009, 05:57 PM   #51
basswood's Avatar
I make sure the cope is just right with a short scrap of crown, but don't nail the last 2-3' of crown before the corner. Pull the scrap and pull the coped end down and slip the end of the next piece of crown in, push the corner together and tack in place with one nail or push that corner together with a "3-rd Hand" (by Fastcap) and walk the plank to the other end and check that cope with a scrap... if all is good nail off all but the last 2-3' of that piece and repeat.
I do lots of stuff in my own unique way... might not work for everyone.
All the best,
Bass
Crown moulding cope or miter joints?-cope-crown-holder.jpg   Crown moulding cope or miter joints?-staging-9-crown.jpg
basswood is offline
Old 03-14-2009, 06:01 PM   #52
basswood's Avatar
Cheers boys,
Roger
What?!--Do I look like the coping fairy?
basswood is offline
Old 03-14-2009, 06:06 PM   #53
wood is good
Ummmmmmm........................
Old 03-14-2009, 06:56 PM   #54
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Miter if its stain grade, use test pieces for every joint. I still dont understand why anyone would cope, you cant glue the joint for one thing. I'm sure someone will be along shortly to enlighten me
willworkforbeer is offline
Old 03-14-2009, 06:59 PM   #55
An excellent point
Old 03-14-2009, 08:01 PM   #56
basswood's Avatar
Coped joints can be cut a skosh long and sprung into place tightly for a perfect fit. These joints are much less likely to ever open up. If they do open all you see is a tiny shadow line of the coped piece against the piece that runs behind it and butts against the wall.
However, both sides of the joint pull back equally When an inside miter shrinks, revealing a open miter at least twice the size of the coped joint shrinking under the same conditions. With stain-grade there is no caulk to handle this wood movement and the unfinished wood of the miter cuts shows. For these reasons there is more justification for coping stain-grade than painted crown. Inside miters will often result in call backs... coped joints will not.
I'll leave it at that for now.
basswood is offline
Old 03-14-2009, 08:21 PM   #57
I worked for this company http://hollywoodwoodwork.com/ for a while and we did glued mitered inside corners,
Old 03-14-2009, 08:26 PM   #58
basswood's Avatar
OK... I couldn't just leave it at that.
Coped Joints are:
1) More forgiving of angular variation
2) Less likely to open up
3) If they do open they are less noticeable because...
A) the gaps are smaller,
B) the other piece runs behind the cope and,
C) no unstained wood is revealed in the gap (as in miters).
basswood is offline
Old 03-14-2009, 08:31 PM   #59
basswood's Avatar
See post above. You are arguing against the laws of physics, wood science and optics.
That's all.
basswood is offline
Old 03-14-2009, 08:35 PM   #60
That's all.
Maybe youre using mdf products hmm? No seriously for absolute high-end airtight joints nothing beats a perfect glued mitre.
Crown moulding question davinci Carpentry 14 02-21-2009 10:54 PM
Fypon Crown moulding brailediver Finish Carpentry 17 01-30-2009 09:21 PM
pricing crown moulding boydbuild Finish Carpentry 15 12-19-2008 10:12 PM
Crown Moulding in Joist Bays, opinions. 415moto Finish Carpentry 7 11-15-2006 08:24 PM
Crown moulding miter Q Nutty Carpentry 7 02-23-2006 07:21 AM
