Crown Masters Help
Old 04-24-2007, 08:21 PM   #1
BUFORD72's Avatar
Trade: general carpentry
Crown Masters Help
got a booger for a no coping crown guy......any takers?
BUFORD72 is offline
Old 04-25-2007, 10:06 AM   #2
BUFORD72's Avatar
Re: Crown Masters Help
how do you find numbers when you have a 45 and a 90 coming in together....in other words how do you match the tops of the profiles
BUFORD72 is offline
Old 04-25-2007, 02:10 PM   #3
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
45 and a 90 coming together?
Real nice guys
King of Crown is offline
Old 04-25-2007, 02:32 PM   #4
Workaholic's Avatar
Trade: Painting Contractor
I am not understanding the question. Do you mean 2 45's?
Sean
Workaholic is offline
Old 04-25-2007, 02:33 PM   #5
send_it_all's Avatar
I'm not sure I even understand the thread title, but why would someone be a "no coping" crown guy?. Is coping now bad? Did I miss a memo?
send_it_all is offline
Old 04-25-2007, 03:11 PM   #6
BUFORD72's Avatar
nah.....inside 22 1/2 cut overlap w inside 45 at the tops of profiles....little 3" flat spot between....kinda dives into a corner
its hard to explain....is there a way to sketch on here?
BUFORD72 is offline
Old 04-25-2007, 03:21 PM   #7
Workaholic's Avatar
take a pic with your phone.
Sean
Old 04-25-2007, 03:29 PM   #8
BUFORD72's Avatar
right on....but it will be tomorrow
BUFORD72 is offline
Old 04-25-2007, 07:24 PM   #9
KentWhitten's Avatar
who copes?
Salmon Falls Cabinetry
KentWhitten is offline
Old 04-25-2007, 07:29 PM   #10
Teetorbilt's Avatar
He may be working a ceiling rake to a wall, my best guess.
Albert Einstein
Teetorbilt is offline
Old 04-26-2007, 06:05 PM   #11
BUFORD72's Avatar
ok guys this is what i got....HELP!
BUFORD72 is offline
Old 04-26-2007, 06:31 PM   #12
When It Rains, It Pours..
highlife77's Avatar
Trade: Remodeling(Everything)
are you going from cabinet crown in
to ceiling/wall crown...??
"When It Rains, It Pours"....
highlife77 is offline
Old 04-26-2007, 06:59 PM   #13
Professional
In_Mexifornia's Avatar
Trade: Finish Carpentry
You need to miter the two larger pieces from where that small piece ends.
Please excuse the crudeness of my drawing.
In_Mexifornia is offline
Old 04-26-2007, 07:15 PM   #14
When you make the small middle piece, put it up against the larger pieces and where the intersection is, then you will have to mitre the bigger pieces like Mexifornia said.
Now the angle is a little tricky, but not too bad. If you can picture the walls coming together, without the small part, then you have an inside 45.
My mind is drawing a complete blank, would this make it a really sharp inside 67.5 angle for the top snub off?
Old 04-26-2007, 07:31 PM   #15
wannabe
WNYcarpenter's Avatar
Trade: carpentry
In my humblest opinion....I would run your piece over the door first with a miter that lays flush to the wall, then cope the smaller piece (cope on right, square an left), then scribe the last piece of cabinet trim to the clusterf!@#.
In my strange mind, the higherarchy goes from room trim that should be consistant, to cabinet trim which is added.
I'd like to see the finished project! Good Luck!
WNYcarpenter is offline
Old 04-26-2007, 07:47 PM   #16
BUFORD72's Avatar
right....how do you find that #?
BUFORD72 is offline
Old 04-26-2007, 07:49 PM   #17
BUFORD72's Avatar
id like to see that too.....were always waiting on the cabinet guys
BUFORD72 is offline
Old 04-26-2007, 09:43 PM   #18
BUFORD72's Avatar
wall to cabinet.....same stock......not the problem....any ideas?
BUFORD72 is offline
Old 04-26-2007, 11:22 PM   #19
TexasTrim's Avatar
Trade: Trim carpenter
Great Pics Bufford.
Later
TexasTrim is offline
Old 04-27-2007, 01:54 AM   #20
BUFORD72's Avatar
evybodys quiet all the sudden
BUFORD72 is offline
space above crown ch0mpie Finish Carpentry 6 03-06-2007 01:41 AM
Nailing Strips for Crown Mpeters Finish Carpentry 5 02-24-2007 08:53 PM
Crown Molding SHAWNPAINTS Painting & Finish Work 16 01-05-2007 02:07 PM
Crown questions... is there a consensus? El Dorado Wood Finish Carpentry 14 01-04-2007 08:50 PM
Crown Moulding in Joist Bays, opinions. 415moto Finish Carpentry 7 11-15-2006 08:24 PM
