Crown Backing
Old 02-24-2008, 06:24 PM   #1
One man show.
kevbo's Avatar
Trade: Finish Carpenter
Crown Backing
Does every one go as far as to provide backing strips when installing crown to a ceiling where there's no backing. I know in all the production and custom homes I've done..(in the past...IN THE PAST!), and every one else that does crown, do not go that far and it's not even requested or expected by the builder, client or subs I've worked for...when it's obvious that if the truss is running perp theres no backing. In fact I have never heard of any one going that far for this situation. Now that I'm out on my own and have seen crown pull away from a ceiling after a couple of years go by where there was no backing for a install(and no...the caulking did not shrink that much!), I'm thinking of providing backing strips for all my crown installs to cover my butt down the road, and in case I get a client who asks..."What are you nailing to??" Waste of time??
Who uses a brad nailer w/ 1 1/2"s for base and say 5 1/4" crown...instead of a finish nailer?
kevbo is offline
Old 02-24-2008, 06:32 PM   #2
troubleseeker's Avatar
Re: Crown Backing
The only time I use a backer is for installation over metal framing.
If you are using 1 1/2" brads for 5 1/4" crown, I'm surprised it stays on the wall long enough for the painters, much less having a problem with it a couple of years later. I use a 16 ga finish nailer with either 2 or 2 1/2" nails.
troubleseeker is offline
Old 02-24-2008, 06:35 PM   #3
Chris G's Avatar
Trade: Porch and Deck Builder
Re: Crown Backing
I always use a backing strip. It makes life so much easier for me. Especially if the ceiling/wall is a little wonky, it makes fiddling with the crown simpler. You can nail the crown right in the meaty middle too.
The hardest part is ripping the 2 x 4s. I wish I could find a lumber yard that carried angled strips.
Chris G is offline
Old 02-24-2008, 06:57 PM   #4
JLTrim's Avatar
Trade: Finish Carpentry
Re: Crown Backing
To be honest, most of the time I don't use a backer. I carry a stud finder and land as many nails into the wall as I can and toe-nail the rest into the ceiling, and glue all the corners, and so far I've had no problems. I use 2" 15g nails for crown, and 1 1/2"-2" 15g nails for base.
Next time I get a big crown job, I'm considering using a backer, if the builder is willing to pay extra... I'm not real busy so I don't mind the extra work and if I can charge more per foot then why not? Plus like you said it covers your ass down the road.
Edit: Sorry I meant 15 ga finish nails not 18ga
JLTrim is offline
Old 02-24-2008, 08:00 PM   #5
Trimcat's Avatar
Trade: Trim contractor
Send a message via MSN to Trimcat
Re: Crown Backing
I don't use a backer strip... if I'm worried the crown isn't fastened properly, I'll drive some 16d hand drive finish nails into the top plate of the wall.... that sucks it up nicely.... 1 1/2 brads?... ah... no
Trimcat is offline
Old 02-24-2008, 08:39 PM   #6
al10fred1081's Avatar
Trade: Carpentry/ Home Improvements
Re: Crown Backing
um 2 1/2" 16ga finish nails. if you can, hit the joists. if not then I take and fire two nails toed against each other. kinda like an x. never had a call back for the crown pulling away. I make sure I'm hitting studs on the wall side and cross those into the stud too.
Alex
al10fred1081 is offline
Old 02-24-2008, 09:50 PM   #7
mmike032's Avatar
Trade: trim carpentry
Re: Crown Backing
we also criss cross nails at top and nail str8 into topplate. never had a problem in 10 yrs. if it needs to be pulled up i hand drive finish nails into the topplate. we use 2 1/2 16g nails for everything. pinnail corners together.if installing 4" crown you can nail in the middle of crown str8 into top plate.
mmike032 is offline
Old 02-25-2008, 05:46 PM   #8
Tom R's Avatar
Re: Crown Backing
Just for everyone's information, - - criss-crossing nails or screws is called 'clasping'
Tom R is offline
Old 02-25-2008, 05:52 PM   #9
All ahead flank
Bill in VaBeach's Avatar
Trade: Kitchen and Bath Remodeling, Home Improvement
Re: Crown Backing
Like Chris G, always use the backing too. Appropriate for custom work!
Bill in VaBeach is offline
Old 02-25-2008, 06:03 PM   #10
Teetorbilt's Avatar
Re: Crown Backing
I use a backer on all of it. I also see all of the hacks working new const. where the caulk is 90% of the holding power.
Albert Einstein
Teetorbilt is offline
Old 02-25-2008, 06:13 PM   #11
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Re: Crown Backing
I use backer on everything over 3&1/2 inches. I always use backer at a joint for 2&1/2 and over crown. I fasten a lot of crown with 2 inch brads and use 2&1/2 inch nails for the larger stuff. Never had a problem, I do try to hit the studs or ceiling joists.
silvertree is offline
Old 02-26-2008, 01:31 PM   #12
mmike032's Avatar
Re: Crown Backing
so everyone that doesnt use backers are hacks. so i got a question for all the i'm better than you, never done anything wrong trim carpenters,"would you spend a day or two ripping down backing, cutting and installing crown for 7$ a corner when the GC or customer doesnt see a need for it and is not going to pay extra for it?"
mmike032 is offline
Old 02-26-2008, 01:58 PM   #13
Should be at work
Foldhazi's Avatar
Re: Crown Backing
Depending on the size and material, it really doesn't NEED many nails. But the ones you do use, be sure and know where they land. Its not structural, and the caulk helping it adhere is hardly a bad thing. The less nail holes that have to be filled, the better for everyone.
JMO
I have no problem being liable for how I do it.
Foldhazi is offline
Old 02-26-2008, 07:35 PM   #14
Awaiting direction....
Tom F.'s Avatar
Trade: Residential Homebuilding Contractor--ICF/Stamped Concrete, too
Re: Crown Backing
I only do 4" or bigger crown. Anywhere the top edge can't nail into something behind the drywall, we use backing. Mainly on walls falling parallel to the rafters/trusses. It's cheap insurance. 16ga 2 1/2" nailer almost everywhere, pin nailer and yellow glue on the outside corners. Paslode trim nailer in odd spots.
Tom F. is offline
Old 02-26-2008, 08:41 PM   #15
Carpenter/fencing
nywoodwizard's Avatar
Re: Crown Backing
Not nessasarly, but it is the proven method of what works the best with less of a chance on call backs for lose molding. Although ecomonics may play a role it would only be an extreamly small one. Since there are only two walls in a room that would need build up it would only add an hour or so and if someone don't want to pay for it then they sign a waiver voiding any warranty.
I understand some builders don't give a **** and they leave you no choice.
Can we install crown 5 different ways ? Sure, but i'll chose the right way.
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 02-26-2008, 08:53 PM   #16
mmike032's Avatar
Re: Crown Backing
all i'm saying is there is at least 10 different ways to do anything.just b/c you do something different then the next guy doesnt make you a hack, as long as the finished product doesnt suffer. many builders dont give a shat, but i do. however i will not lose money by investing time in something that is overkill. now if i did have a problem with callbacks than i would change something in order not to lose money on callbacks. so far no callbacks on crown except an occasional joint that needs to be sanded. you cant hold all your helpers hands all day long
mmike032 is offline
Old 02-26-2008, 11:54 PM   #17
JLTrim's Avatar
Re: Crown Backing
I may not have been the biz for as long as some of you, but it's been a while, and I've run more than my fair share of crown...
The only callback I've ever had for crown was when I had some corners separate, since then I glue all my corners, base, crown, casing, whatever... but I've never seen it come down from walls or ceilings. Not once. Not to say it can't happen, but I feel pretty confident in the way I install it.
JLTrim is offline
Old 02-28-2008, 09:27 AM   #18
Carpenter/fencing
Re: Crown Backing
Wavy ceiling on the side that could use build up ? let me see shooting nails in the drywall to hold the crown up tight, and not caulking a huge gap when you're done.
Old 02-28-2008, 09:30 AM   #19
Carpenter/fencing
Re: Crown Backing
Then the shrinking and expanding factor may come in to play, as long as they can get a check and get to the bank before it loosens up ,its all good.
Old 02-29-2008, 07:45 AM   #20
pappagor's Avatar
Trade: general contractor
Re: Crown Backing
i use backer on all most all of my crown that way you know you have something to nail to were you need it
pappagor is offline
Upsidedown Crown moulding!! dkillianjr Finish Carpentry 18 02-15-2008 10:39 PM
Crown and Popcorn silvertree Carpentry Picture Post 12 02-04-2008 09:39 PM
Large crown on a built-in cabinet Bummie Finish Carpentry 5 09-01-2007 08:53 PM
Crown questions... is there a consensus? El Dorado Wood Finish Carpentry 14 01-04-2007 08:50 PM
Crown Moulding in Joist Bays, opinions. 415moto Finish Carpentry 7 11-15-2006 08:24 PM
