Crown
Old 05-16-2007, 08:37 PM   #1
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Question
Crown
I have a crown question. I have a wall thats "cliipped to a 45 degree angle". So instead of a 90 degree in the corner, it angles over. I guess its technically a 135? Im trying to double cope it. I have a outside corner 45 dying into it from each side. So I tried cutting the cope sides with miter 14.3 and bevel at 17.6. Then cope. It seems to work except the back cut angle on the cope needs to be sharp. I used a rasp to remove a lot behind the cope but it still doesnt fit.
osborn is offline
Old 05-16-2007, 08:42 PM   #2
Tom R's Avatar
Re: Crown
You have to back cut it more, more, more . . .
Tom R is offline
Old 05-16-2007, 09:29 PM   #3
The Deck Guy
Greg Di's Avatar
Re: Crown
You REALLY have to back cut it. The trick is how you hold/position the crown whilst doing the backcutting.
I use a Collins Coping foot and you need a blade that is nearly double the length of the standard blade for that cope. That's a good indicator of how much MORE you have to back cut.
Greg Di is offline
Old 05-16-2007, 10:42 PM   #4
Tom R's Avatar
Re: Crown
Here's a little cheater method I don't tell everybody ()
Take your 'opposing' piece (the one you're not coping), - - and mark it where you would just as if you were going to miter both pieces, - - then miter it (with your same settings) about 1/8" over-sized (in length).
That will remove the areas that are causing you to have to so heavily back-cut your coped piece, - - and your fit-and-finish will still come out exactly the same as if you had left the opposing piece uncut . . .
Tom R is offline
Old 05-17-2007, 06:56 AM   #5
osborn's Avatar
Re: Crown
Thanks Ill continue rasping.
osborn is offline
Old 05-17-2007, 09:18 AM   #6
Tom R's Avatar
Re: Crown
Osborn, - - remember, - - when your cutting your cope, - - you also need to hold your coping saw at a 'compound' angle to get the right back-cut.
Try to picture the direction your opposing piece is going to run through your coped piece, - - and hold your saw in that same (compound) direction . . .
Tom R is offline
Old 05-17-2007, 07:29 PM   #7
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Re: Crown
I'll break out a Dremel tool from time to time with hardwoods. Might save you some elbow grease!
WNYcarpenter is online now
Old 05-17-2007, 08:18 PM   #8
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Re: Crown
we've been using an angle grinder for taking most of the material off when coping - 50 grit, wear safety glasses. you can get really really close with this, then I fine tune it with a small rasp and a file.
Mrmac204 is offline
Old 05-18-2007, 08:06 AM   #9
Cardiac Paul's Avatar
Trade: remodeling contractor/carpenter
Re: Crown
Tom R, I like your idea a lot, I'll be trying that one real soon on one of my projects. Thanks
Paul
Cardiac Paul is offline
Old 05-19-2007, 08:01 PM   #10
miterclamp.com
clampman's Avatar
Trade: interior trim/cabinets
Re: Crown
I cope everything, unless it's an obtuse angle like the one you are doing. I miter those. 45* crowns can be nearly impossible to cope on a 135* angle when they are fairly easy to do on a 90.
To see where you need to "back cut" more, hold the piece you are coping on the right spring angle (as it goes on the wall), and put your eye at a 135* angle to it and horizontal with the center of the crown.
Any wood that you see behind the leading edge (the profile cut) has to come out of there.
clampman is offline
space above crown ch0mpie Finish Carpentry 6 03-06-2007 01:41 AM
Crown Molding SHAWNPAINTS Painting & Finish Work 16 01-05-2007 02:07 PM
Crown questions... is there a consensus? El Dorado Wood Finish Carpentry 14 01-04-2007 08:50 PM
Crown Moulding in Joist Bays, opinions. 415moto Finish Carpentry 7 11-15-2006 08:24 PM
Flexible Foam Crown Molding pshammond Finish Carpentry 11 08-06-2006 11:53 PM
