Could Use Some Help Trimming Out Stairs
Old 03-17-2012, 08:54 PM   #1
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
Hey all,
Installing some trim on the sides of a staircase and I've got a couple of questions regarding how to transition back to floor trim.
A pic is worth a 1,000 words so this is what I'm looking at:
The base trim on the right is also going on top of the 1x10 up the staircase. Trying to figure out the best way to mate back up the two pieces of base trim...
Also, it's a U-shaped staircase and I'm not sure how to best run the trim around the inside corner. I've got the 2 pieces of 1x10 dry fitted w/ 45 cuts on the end.
Thanks for your ideas, guys -
Mac
BuiltByMAC is offline
Old 03-17-2012, 09:06 PM   #2
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
Re: Could Use Some Help Trimming Out Stairs
you could always run the trim down the stringers. or rip the top profile and transition that down. also depends how crazy you want to get ,budgets and time frames.
something like this
blackbear is offline
The Following User Says Thank You to blackbear For This Useful Post:
BuiltByMAC (03-18-2012)
Old 03-17-2012, 09:12 PM   #3
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Don't know if any of these will help, but here's a few pics.
Could use some help trimming out stairs-008.jpg   Could use some help trimming out stairs-007.jpg   Could use some help trimming out stairs-005.jpg   Could use some help trimming out stairs-077-1.jpg
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
Old 03-17-2012, 09:25 PM   #4
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
The U wall is going to be a problem as it is imo. Your skirtboard needs to transition to level before it wraps the corner. I wish i could put into words better what im trying to say....but then again i could be way off base and one of the hardcore trims guys will put me in my place.
jkfox624 is offline
The Following User Says Thank You to jkfox624 For This Useful Post:
BuiltByMAC (03-27-2012)
Old 03-18-2012, 01:47 PM   #5
falcon1's Avatar
Trade: Residential contractor
Rewards Points: 75
Why are you using Stafford casing for baseboard? It complicates things and it will look like crap with all the dirt and dings it will accumulate.
falcon1 is offline
Old 03-18-2012, 04:53 PM   #6
The Deck Guy
Greg Di's Avatar
Rewards Points: 2,000
I don't have a picture of it, but what we've done is run the base to the skirt and put a small miter to turn out to the plane of the skirt (Which is usually 5/4) and then self return that. You then cut the skirt flush to the top of the baseboard. The miters are tiny, but 2P10 works great.
Make sense?
Greg Di is offline
Old 03-18-2012, 06:51 PM   #7
BuiltByMAC's Avatar
Trade: Deck guy
Not sure what Stafford casing is, HOs just wanted a skirtboard that was a 1x10 with the base trim on top of it running up both sides of the staircase. The 1x10 hides some funkiness in the wall itself (like the orig. builders ran drywall down to a stringer in the wall plane and you can see the lines from drywall to wood - looks like crap.)
Make sense?
Not entirely. Sorry. What's a 2P10? In addition to the 1x10 skirt, I've also got base trim going on top of the skirt. I'm trying to figure out how to best transition the base trim/skirt run into a base trim only run.
Thanks again,
Mac
Old 03-18-2012, 07:11 PM   #8
hammer7896's Avatar
Rewards Points: 152
At the top you could cut the skirt flush with the floor so the base can run straight out then down the steps. At the middle you can run your skirt around the corner flush on top then do a three piece corner with the molding.
hammer7896 is offline
Old 03-18-2012, 07:19 PM   #9
The Deck Guy
Greg Di's Avatar
Originally Posted by BuiltByMAC View Post
What's a 2P10?
Oh glasshopper...
http://www.fastcap.com/estore/pc/2P-...oz-6p12826.htm
Can't live without the stuff on interior trim work.
A lot of times, you have to make a very tiny double miter piece of the base cap material that transitions from the rake angle of the stairs to the flat angle of the baseboard. There is no way to make that compound miter in one cut, so you make the rake angle miter first and then make a tiny self-return from that angle to the flat angle. It's a very tiny piece of trim that usually looks like an inverted triangle. Hard to describe, but I don't have any pics of it. I just know how to do it.
I think Gary Katz has a drawing of it on TiC.
http://www.thisiscarpentry.com/2010/...board-returns/
Greg Di is offline
The Following User Says Thank You to Greg Di For This Useful Post:
BuiltByMAC (03-19-2012)
Old 03-22-2012, 07:44 PM   #10
Craftmark's Avatar
Rewards Points: 250
Mac, it looks to me like the stair skirt is 1 x, yes? You need to choose different base trim. What you show in the picture is casing. You'd be better served with a base cap. At the top of the steps choose a 1 x 6 or 1 x 4 for the base with a base cap. Cut the skirt level so that it's an inch or two lower than the 1x base. Run the 1x base and but it into the skirt. Then miter the base cap down to the skirt level then miter it again and run it down the steps.
As for the inside of the U. The same thing needs to happen. You need to cut the skirt to level BEFORE it miters around the corner. Cut it level and this could be a notch as this will then be covered by the base cap as it follows the shape of the skirt. The problem in a nut shell...your trying to turn the corner with your skirt running on the rake of the stairs. This will not work. The skirt must transition to level before turning the corner at both inside locations.
Craftmark is offline
The Following User Says Thank You to Craftmark For This Useful Post:
Old 03-22-2012, 08:32 PM   #11
Jeff
jkfox624's Avatar
Rewards Points: 502
Haha i tried to say that but you put it into better words than me. Thank you.
jkfox624 is offline
Old 03-22-2012, 09:11 PM   #12
General Contractor
greg24k's Avatar
Rewards Points: 7,330
I cut the stringer ears off and follow with trim around and down.
greg24k is offline
The Following 2 Users Say Thank You to greg24k For This Useful Post:
BuiltByMAC (03-23-2012), pinwheel (03-28-2012)
Old 03-23-2012, 08:26 AM   #13
General Contractor
greg24k's Avatar
Make sense?
Stick to building decks my friend
greg24k is offline
go dart (04-11-2012)
Old 03-27-2012, 08:22 PM   #14
BuiltByMAC's Avatar
Trade: Deck guy
This is what I ended up doing...I realized I needed to return the trim to level BEFORE I turned the corner.
I appreciate the suggestions ya'll had..they got me to thinking about how to approach the problem.
Mac
The Following User Says Thank You to BuiltByMAC For This Useful Post:
jb4211 (04-11-2012)
Old 03-27-2012, 08:44 PM   #15
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 888
I think that turned out well! Nice solution!
overanalyze is offline
Old 04-10-2012, 05:08 PM   #16
mmike032's Avatar
Trade: trim carpentry
I'd bob the top of the skirt board off a few inches above where the base/casing will meet. Run (casing) up and around.
where the wall turns:
install 1x6 blocks around the wall. ( 3 sided column) rip as needed.
top of 1x6 on last flight would meet short point of skirt
then install skirts to 1x6
install trim up, down, around
pop/mark lines for skirts and blocks before cutting anything.
figure angles and lengths , then cut and install
mmike032 is offline
Old 04-10-2012, 09:07 PM   #17
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 1,878
Mac
Good recovery, I think that will work out nicely.
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty"
- Thomas Jefferson-
http://www.savingtherepublic.com/Main.html
Snobnd is online now
Old 04-11-2012, 05:27 AM   #18
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Hey all,
Mac
I Just trimmed an addtion with the detail of the landing.
Only problem is I see you have to use Adam's casing as base. I was using one by and base cap. I brought the base cap down and around....I thought I had photos, but I can't find them.
TBFGhost is offline
Old 04-12-2012, 12:43 AM   #19
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Rewards Points: 1,000
something like this
i've probley built 5000 stairs, and i really love that picture
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
Boat Dock Stairs summithomeinc Carpentry 31 02-17-2013 07:18 PM
laddering curved stairs Ohio painter Painting & Finish Work 6 01-08-2012 08:05 PM
3 Doors At the top of the Stairs Docwhitley Framing 4 01-02-2011 08:36 PM
Bid on stairs fix it man Business 10 03-23-2010 07:52 AM
Are uncut stringers old fashioned for stairs? atari Finish Carpentry 2 05-30-2006 12:59 PM
