Trade: CE Project Engineer
Corner Book Shelf
Hey,
i am looking into building a corner book shelf. have a few ideas. just wondering if anyone has acomplished this and has any tips. book shelf will be 72" tall and 2' on either side. thanks
Higgins "The more we sweat in peace, the less we bleed in war." -- Vijaya Lakshmi Pandit (1900-1990) |
Cabinetmaker
Re: Corner Book Shelf
fixed top and bottom shelf, the rest adjustable
Dado the back panel 1/2" or so in, - - so you have room to scribe the side panels to en-even walls . . .
http://www.tr-built.com |
Built-in, or free-standing?
Plywood sides? A little detail could get better ideas.
it woud be free standing i havent decided if it is going to be hard wood or ply wood yet most likely hard though
I like three fixed shelves,
but if it's only two, it would be the bottom and an intermediate.
MA
Higgs: I would go with a hardwood veneer 3/4" plywood (less $ than large dimention hardwood) and definitely use face frames to hide end grain. Sky is right, fix the top and bottom shelves with dadoed rear panel for support. I recommend shelf pins (either 5mm or 1/4") for the supports which offer a very clean look. There is a great jig and self centering bit avail from www.rockler.com . I would also suggest finishing it off with a nice crown and base detail to give it a "piece of furniture" look. If crown is a bit rich for the look your trying to achieve then incorporate an arched or detailed top rail on the face frame. Good luck!
If you can't fix it with a hammer.....You've got an electrical problem! |
Trade: Porch and Deck Builder
Metal drywall corner bead makes a quick and cheap template to evenly space the holes that hold your shelf clips.
#9 | |
Re: Corner Book ShelfQuote:
But Chris, - - maybe a vinyl one so he doesn't scatch up his fine job?? . . . ![]() J/K, - - great tip . . .
Trade: carpentry
I usually use strips of peg board to template the holes for shelf clips. You can cut them to the exact size of the cabinet sides, then just flip them over for an exact match on the opposing side. It's a no-brainer to keep everything registered...
| question about E-Myth Contractor book | dirt diggler | Business | 42 | 10-17-2008 10:03 PM |
| Residential code book | Michaeljp86 | General Discussion | 11 | 12-04-2007 12:14 AM |
| attach corner bead to fascia | robo | Drywall | 2 | 10-04-2007 09:01 AM |
| Building codes book | Michaeljp86 | General Discussion | 5 | 08-06-2007 03:55 PM |
| Advertising in the Local Book (Yellow Pages) | 72chevy4x4 | Marketing & Sales | 22 | 12-11-2006 10:00 AM |
