Corbel Over Tile
Old 04-16-2006, 01:52 PM   #1
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
Corbel Over Tile
Alright, I have a change order, and the contractor wants corbels instead of cabinets in the bathrooms. Its a comercial. Steel studs boys and girls bathrooms. marble countertops weighing around 140#s a peice. I am milling the corbels out of 1" thick laminate pine, to go with the rest of the building.
My main problem is the tile guy has already been in, and put tile around the whole room. How would you guys mount these?
Real nice guys
King of Crown is offline
Old 04-17-2006, 12:27 PM   #2
RowdyRed94's Avatar
Trade: Residential custom home builder
Re: Corbel Over Tile
Did the tiler use cementboard or drywall? Obviously wall stiffness is an issue so you don't crack the grout (and maybe the tile). How about adding some extra nuts & washers to regular toggle bolts to leave the head sticking out a half inch, then insetting keyhole plates in the back of the corbels to hang on the screwheads? Three or four per corbel would hold in the studs, I'd think.
You could also make some cleats to go across the wall, high and low. Screw them to the studs and notch the corbels around them.
Clint - carpenter, coordinator, webmaster
RowdyRed94 is offline
Old 04-17-2006, 01:07 PM   #3
miterclamp.com
clampman's Avatar
Trade: interior trim/cabinets
I would pass on that job myself. I assume these slabs are 20" or so wide, and not very thick. To the weight of the marble you're going to have to add the weight of at least two boys sitting on the edge.
Designing with corbels will put the top fasteners in tension as well as shear, and unless those studs are structural steel studs, the fasteners will have little strength.
In addition, even flawless Carera has hardly any strength except in compression, and is usually supported all the way under it, right up to the sink cutout. Also most of the interior designers out there don't know the difference between marble and travertines, and most of the "marbles" I've seen are travertines. They will often fall apart just picking up a slab, and are composed of as much epoxy fillers as they are limestone.
If I couldn't talk them into columns at the front corners under some sort of rail, I'd pass on that job.
Good luck.
regards,
jimc
clampman is offline
Old 04-17-2006, 02:46 PM   #4
RowdyRed94's Avatar
I'd guess they're "cultured" marble.
Old 04-17-2006, 04:47 PM   #5
miterclamp.com
clampman's Avatar
Even if they are cultured marble, attaching them with corbels will not work for very long.
No matter how your contract is written with the GC, as soon as some kid rides it down and gets cut up, the lawyers will be going after everybody, regardless of who was "at fault".
Not only are screws, mollies, and toggles insufficent for a leveraged load like that, standard steel studs are as well, and I doubt that even the structural studs used on commercial balconies would be enough to prevent severe deflection, even if the fasteners were welded to them.
I would still pass on that job. Sometimes the juice just aint worth the squeezing.
Regards,
jimc
clampman is offline
Old 04-18-2006, 09:40 AM   #6
RowdyRed94's Avatar
That's probably good advice. Tile is easily repaired. Open the wall, fit two or three layers of 3/4" plywood where appropriate, and reinstall cementboard. Tile can be reset in minutes.
Old 04-18-2006, 10:29 AM   #7
Heavy Weight Champ
thanks guys.
Real nice guys
Old 04-18-2006, 11:58 AM   #8
miterclamp.com
clampman's Avatar
King,
Is this plastic marble or real marble? If real marble, I would fax the supplier and ask him how it needs to be supported. For example, what kind of unsupported span it can handle with kids sitting on it. And have him fax the answer back to you - and save the fax.
regards,
jimc
clampman is offline
Old 04-20-2006, 12:19 AM   #9
Heavy Weight Champ
I live in Arizona.
They dont care. I beleive its cultured, but seriously, I've been talking with the company directly and they seriously didnt care.
Real nice guys
quarry tile to quarry tile rservices Flooring 8 01-15-2010 12:37 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
odd bullnose tile mdshunk Ceramic & Stone Tile 25 09-18-2006 11:25 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
