Trade: HOME IMPROVEMENTS & REMODELING
CHAUK Or Wood Putty?
What's up guys?
I've always used white chauk to fill my holes when i do trim. But i have noticed that after its dried and I paint it, you still see a slight edge around the nail holes as if the chaulk shrunk. Any recommendations i really would like to make it invisible to see where the nail hole is. Is wood putty a better option? If so which brand should i get? |
Thag
Trade: Home improvements
Re: CHAUK Or Wood Putty?
Ask your brother
....wood putty would work also. You may wanna wipe the caulking with a wet rag or finger to get rid of the problem you're having using caulking. Yes,caulking will shrink. I never have problems using caulking.
Thag
Minwax wood filler.. In the yellow tube.. Sand nice and NEVER shrinks
Thag
Shirwin Williams Carpenters Wood Filler
I like DAP Fast 'n Final(interior/exterior).
it actually swells a little when it sets up, but you can sand it, just a lick, after an hour or so. i
Trade: general contracting
What I do is mix a little bit of plaster of Paris or any fast setting compound, and let it dry and get hard. Once its dry I break a piece of and I scratch it on the nail holes. No sanding needed and it doesn't shrink. Don't waste your money on fillers- theres probably a piece of dried up plaster somewhere on the job site.
Carpenter/Finisher
bondo...or minwax's woodfiller equivelent
1st Gen tradesman My summer job in college became my profession |
Never caulking for nails as it will always shrink and leave a visible dimple when painted. I pesonally like light weight spackling; apply high, the sand it down when dry. The lightweight sands much easier than interior/exterior ro any other spaclke that contains vinyl additive. However our current painters have made a believer of me in Crawford's Painters putty.
Trade: trim carpentry
i always feel my holes with COCK (as a northern would say.) mine doesnt shrink untill i'm done wiht the job. and then i'm long gone
Young Gun
Trade: Smartass
I learned a trick a long time ago being as i am 21 about 3 years ago doing finish work. Try using finishing drywall mud. You put it on just like chalk with your finger let it dry and sand it and paint it. It works better then chalk or putty.
Trade: Remodeling contractor
Here's what I do - Tell the painter to fill the nail holes.
Complete Custom Remodeling "When Quality is Top Priority" www.completecustomremodeling.com |
Trade: painter
I am a Painter and have tried just about everything on holes.... the best thing for nail holes is a lightweight putty..it is easy to work with and sands with your finger if you hand to>>>caulking like the others say is a complete no-no and there really is no way to fix once you've done it, always makes the painted trim look like crap...
Try using Plumbers putty, you can paint it as soon as you apply it and never shrinks.
Was plumbers putty a joke? It makes sense, I just never thought it would be paintable.
Thom
I've tried almost everything (not plumbers putty) and I like ez-sand (the setting drywall mud) It's easy to work with and doesn't shrink.
I've used multiple kinds of caulk but never chalk. I'm unfamiliar with chauk. |
Re: CHAUK Or Wood Putty? L O L
CHAUK or maybe
#18 |
CHALK how about
CALLK or CAWLK maybe CULLK i don't know i think its CAULK are the more? |
#19 |
Trade: General contractor
glazing putty
#20 | |
Re: CHAUK Or Wood Putty?Quote:
stain blocking primer... at least. You would need to prime first (read the can), and wait weeks to paint with latex (read the can) Why go to such trouble when Minwax makes perfectly good filler putty that you can buy practically anywhere?? I still like Fast N Final even if I do have to make a pass with 120 grit.
| New kind of Pressure Treated wood | karma_carpentry | Carpentry | 23 | 08-21-2008 09:06 AM |
| Pressure Treated Wood | rjordan392 | Carpentry | 4 | 05-28-2007 02:23 PM |
| wood putty | bigbrew | Flooring | 3 | 01-17-2007 07:41 PM |
| Wood people I need your help | Floorwizard | Flooring | 11 | 05-18-2006 09:07 AM |
| Really Dark Wood...Primer/Application Q | slickshift | Painting & Finish Work | 13 | 04-28-2006 04:47 PM |
