Remodeler
Trade: Remodel
Ceiling Molding In Log Home ...
Hi -
has anyone installed (any kind of) ceiling molding in a log home against the irregular wall logs? I'd appreciate any suggestions you might have. I had to cover over the original ceiling with 3/8 sheetrock. Now I need to cover the (irregular) ceiling to log corner with some kind of molding. Thank you! |
#2 | |
Priced In
Trade: Exiled For Life
Re: Ceiling Molding In Log Home ...Quote:
The whole ceiling there is this material that covers the whole ceiling and goes on like wallpaper. Never used it but seen the product and I thought is was quality. I it so irregular that crown would be difficult then try picture moulding. Typically held 1/2 to 3/4 of a inch down from the ceiling. But really this is worthless without pics. |
Custom Builder
Pop a line a few inches down from the cieling all around the room, take a rotozip with a 3/4 inch router bit along the line, you may need several passes and it helps to screw a guide to the wall. Then fit a 1x in the slot using a straight line, glue and very slim shims to create a straight platform for nailing crown or cieling trim.
Works for windows and doors and base trim also. Bob
Bob |
What Glass said, - - or lay your 'backer 1 X' on the 'flat' (and scribe it all the way).
http://www.tr-built.com |
Remodeler
Trade: Remodel
great info .. thanks a lot guys.
| Proposals...... | AAPaint | Painting & Finish Work | 3 | 08-25-2007 09:47 AM |
| Flexible Foam Crown Molding | pshammond | Finish Carpentry | 11 | 08-06-2006 11:53 PM |
| Drug caches found in Home Depot vanities | HandyAl | General Discussion | 1 | 06-14-2006 08:14 PM |
| Crown molding...how to handle caulk? | Robie | Painting & Finish Work | 4 | 11-13-2005 12:09 PM |
