Trade: General bldg contractor
Casing On Pre Primed Window Jambs
I have a new construction home that will be trimmed out in a few weeks. I have vinyl windows with pre primed jambs installed. The jambs in some instances are a good 1/8" shy of the face of the drywall. What is the preferred way to handle this type of situation? Hold the casing to the drywall and caulk the gap on the inside of the casing,....or Hold the inside of the casing to the jamb and caulk the outside gap,..or shave the drywall,......? This is only the second time I have used preprimed jambs. The last time I did not like what my carpenter did, so I would appreciate any input from others.
Thks.....Larry |
Class A Contractor "BLD"
Trade: Remodeling and home improvements
Re: Casing On Pre Primed Window Jambs
Hammer the DW down flush with the jamb. Then nail casing. Any gaps front or back will receive caulk as required. Your 1/8" gap is nothing to sweat about.
Looks like some pros were here. |
Heavy Weight Champ
Trade: finish carpentry
exactly
Real nice guys |
Trade: REMODELING CONTRACTOR
I agree.
Steve Unkie. |
Trade: Commercial Roofing Inspector/ Trainer
I agree. This problem, on a consistent more sever basis, lead to the pre-installed jamb extension ban of 2006.
I agree,......I thought it would be nice to have the jambs installed at the factory,...next time I'll install them in the field!
Cabinetmaker
ICF You can still have factory do it in the future however remember to use a jamb that is at least 1/8 wider than the space you are going into. Install window then just take block plane to the jambs and bring em flush. My normal is the same as the poster above, i just take my hammer and whack the rock down to the jamb way faster just dont do it with the "owner" looking LOL LOL . ONly caution is MAKE SHURE you dont go beyond the trim width!
JackM ![]() |
FWIW:
You can also install 1/4" strips on the jams to make the jams sit 1/8" OVER the drywall surface. Face nails the strips with 3/4" Brad nails. Caulk or putty the 'splice' and paint and prime. Install Casing: nail or staple off your inside edges, then just nail the exterior edges of the casing down (Flat on the wall) to make up for the 1/8" difference. The casing will sit flat and tight. To the naked eye .... all will look fine... I usually 'float' (don't nail) the mitered corners so they don't separate on the face side. it's the unside of the casing (casing on jam) that shows up everything...In painted application, caulking can hide the outsides (Casing on wall) ... of the casings.
- Build Well - Last edited by AtlanticWBConst; 11-13-2006 at 09:10 PM. |
#9 | |
Re: Casing On Pre Primed Window JambsQuote:
Actually, I am talking about if the areas are really... considerably bad. Example: if the drywall surfaces are not consistent in their widths over the jam sufaces in one window frame area.
Such as fluctuations of 1/16" to 3/8" on painted wood-work... and you are on a tight commercial schedule. If the surface difference is minimal (sp), then, ...I agree with 'tapping' the sheetrock down with a hammer... to get it right... I was just offering another 'take' on this...of course... based on circumstances, needs, and time issues....
- Build Well - Last edited by AtlanticWBConst; 11-13-2006 at 09:29 PM. |
| Replacement Window Question? | Max10 | Windows, Siding and Doors | 34 | 02-27-2010 06:15 PM |
| Getting laminate under door casing and jambs | Blackhawk | Flooring | 6 | 01-02-2008 04:14 PM |
| Window jambs extend beyond drywall | jstrand23 | Remodeling | 21 | 04-27-2007 12:00 AM |
| Window casing | sidejobs | Carpentry | 2 | 04-24-2007 03:10 PM |
| Condensation Help | Patrick | Windows, Siding and Doors | 10 | 03-16-2007 09:40 AM |
