Carsiding Install
Old 02-18-2010, 05:49 AM   #1
vans's Avatar
Trade: general
Carsiding Install
I have a 6000sq ft of ceiling to cover with carsiding made from pre-finished tulip, boards that are random lenght,most being under 12',
Ceiling will be broken up into 4 bays with a 12' width, making fake beams from ash to divide
Question/opinion's- would a pattern or just a random lenght look the best?-
ceilings are tapered-12' to 24', and I'm thinking a pattern may go faster as we should be able to precut lumber , where random length's may utilize lumber better-less waste, I have 18,000 lineal feet of 5-1/2" siding to accomplish task, quality is very important
Thanks
vans is offline
Old 02-18-2010, 09:36 AM   #2
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Re: Carsiding Install
Do they need to break on a rafter?
Gus Dering is offline
Old 02-18-2010, 09:53 AM   #3
Tom Struble's Avatar
Trade: siding
Gus is a smart man
if they have to fall on a rafter [which unless you sheath the ceiling first they do]you going to be doing a pattern
Tom Struble is offline
Old 02-18-2010, 11:36 AM   #4
Trim40's Avatar
Trade: Guy who plays with wood
I bid a job similar to this( waiting on a decision).
IMO it will look best if the joints are covered by the beams. 2nd best would be a random pattern.
I discussed both with my potential client and they chose the random pattern due to cost.
Trim40 is offline
Old 02-18-2010, 01:37 PM   #5
For me, "random pattern" means
there is a pattern, but it only repeats
after at least 5 or 6 courses.
True random patterns seem a lot more
difficult to carry off on a ceiling
than a floor, at least to me.
Could be a personality defect.
I'm sure Gus will have an opinion
on that.
neolitic is offline
The Following 2 Users Say Thank You to neolitic For This Useful Post:
Tom Struble (02-18-2010), WNYcarpenter (02-22-2010)
Old 02-18-2010, 04:49 PM   #6
I like Green things
WarnerConstInc.'s Avatar
If it is tongue and groove I let they fly with a scarf joint, a few pins and some glue.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is offline
Old 02-18-2010, 06:58 PM   #7
KemoSabe
loneframer's Avatar
"Random Pattern" That cracks me up.
Random, to me, means a complete lack of rhyme or reason. If you are nailing joints at rafters, you may have one rafter with maybe 5 joints breaking on it. First repeat at 5th board, second at 12th board, third at 20th board and so on. One rafter may have two boards breaking, another could have seven. It's easy to look up after it's done and say "I wish I'd have broken that joint one layout to the right". The hard part is achieving what you percieve as perfect as you go along.
Pattern is a repeating order. 32" piece, 64" piece, 96" piece, 112" and repeat. Or 32,96,64,112, repeat....
Patterns are much easier to pick out than a random array. Just look at most vinyl siding jobs. Looks like a staircase on the wall. A good vinyl job won't have that effect, IMO.
loneframer is offline
Old 02-18-2010, 08:52 PM   #8
Trade: siding
thing is if the seams have to land on 16'' centers eventually the pattern has to repeat itself or your going to get seams too close together
its the same with siding,a proper pattern will maximize the distance between each seam which also belive it or not will help keep your siding staighter
Old 02-18-2010, 09:28 PM   #9
KemoSabe
loneframer's Avatar
It doesn't have to be a repeat pattern though.
144------------------------------------
48----------
96-----------------------
128-----------------------------
64-------------
80------------------
32------
112-------------------------
64-------------
32------
48---------
64------------
Old 02-18-2010, 09:38 PM   #10
Trade: siding
i got ya mr loneframer
typically when using a fixed panel length like 12' to maximize the distance between seams,my pattern will repeat every third course
i will usually split my courses by 1/2 say 12' -6'-3'
loneframer (02-18-2010)
Old 02-18-2010, 10:15 PM   #11
KemoSabe
loneframer's Avatar
I have no problem with repeat patterns, as long as they don't look offensive. I do ,however, have a problem with the "staircase" pattern. I've seen jobs with as little as 12" stepoffs.
On vinyl jobs, if I do a repeat, it'll go like this...
full panel
-8'
-2'
-6'
full panel
-8'
-4'
full panel
The Following User Says Thank You to loneframer For This Useful Post:
Old 02-18-2010, 10:24 PM   #12
Trade: siding
yes i agree with the stair step i hate that,is also the reason you look at a wall and see an A or a V in the wall,keeping the seams separated as far as possible will help keep your wall true
Old 02-18-2010, 10:37 PM   #13
Gus Dering's Avatar
What is this Carsiding? Does it have a t&g or not?
I wonder if each 12' bay has the same layout. Some how I doubt that. So one bay to the next will have a different pattern to the one next. If that is any consolation.
I like to step it off 32" at a time for 4 - 5 courses in the 12' then bump over the pattern 16" to start the 32" step again.
Yeah it's a pattern but only those of us with personality defects can pick it up with a casual glance. Sorry Neo, I got no magic wand to help you with.
Old 02-18-2010, 10:42 PM   #14
Trade: siding
no it has a rabbeted butt like ship lap
Old 02-18-2010, 10:51 PM   #15
Gus Dering's Avatar
What is all this talk about bunny butts?
Old 02-18-2010, 10:51 PM   #16
KemoSabe
loneframer's Avatar
That reminds me of a joke about a bear, but I'll be danged if I can remember it.
Old 02-18-2010, 11:04 PM   #17
Gus Dering's Avatar
Don't know the joke butI bet the rabbet got a little bloody.
The Following User Says Thank You to Gus Dering For This Useful Post:
Old 02-19-2010, 12:01 AM   #18
T&G......
neolitic is offline
Old 02-19-2010, 12:19 AM   #19
I like Green things
That is the only kind of car siding I have seen.
I always let t&g run wild. They will hold each other in.
I do it with bead board sofets porch ceilings etc.
Old 02-19-2010, 12:44 AM   #20
Trim40's Avatar
I don't know squat about bears and rabbit butts but I knew someone would catch the random pattern.
Trim40 is offline
The Following User Says Thank You to Trim40 For This Useful Post:
loneframer (02-19-2010)
Mini-split system install requirement question tru HVAC 22 02-10-2010 09:18 PM
Restoration Hardware C-top install Greg Di Kitchens & Baths 12 09-15-2009 11:34 PM
Install Solar/Wind Combo's Bubbles Electrical 7 05-29-2009 10:12 PM
Window Install Questions Brickie Windows, Siding and Doors 9 02-21-2009 06:34 PM
Pond Water-Leveling Pipe Install Trencher Excavation & Site Work 7 12-26-2008 12:28 AM
