Trade: carpentry
Carcass Construction
I'm intersted to hear how you all build your carcasses.
Do you run your sides down past the base like on the left, or set them on top of the base (on the right)? ![]() Unless I have a good reason not to, I drop the sides on top of the base. It provides better vertical support, and I only need to make the 1-1/2" adjustment to the measurement once (to the height) if I'm building a whole set at the same height but different widths instead of adjusting for each individual unique cabinet width. I build 'em like that, but I see them the other way all the time... I know this could turn into cope vs. miter , but thought I'd dip into the collective wisdom anyway. |
Eater of sins.
Trade: Designer/Drafter Extrordinaire
Re: Carcass Construction
I rabbet the sides then glue, nail or whatever it takes. I don't like to see end-grain.
Andy.
www.draftinginoc.com |
| The Following User Says Thank You to ScipioAfricanus For This Useful Post: | mics_54 (08-19-2009) |
Trade: carpenter/ handyman
I'll beat Basswood to it. Dovetail!
![]() Steve |
Sides all the way down for a clean look, - - who wants to see the sides of the bottoms??
http://www.tr-built.com |
| The Following User Says Thank You to Tom R For This Useful Post: | mics_54 (08-19-2009) |
Trade: trim carpenter
Re: Carcass Construction |
Yard Boi
Trade: Landscaping
I hire a professional so I don't have to make these decisions.
Bob's Lawn & Landscape When You Want The Best Serving the LC Valley & Moscow-Pullman |
Maker of fine kindling
Are you talking finished or unfinished ends?
I have to assume you are referring to unfinished ends. If so you are doing it the same way I do.
Every parent who has walked barefoot into their child's room late at night hates Legos |
#8 | |
Trade: carpentry
Re: Carcass ConstructionQuote:
![]() No one wants to see the sides of the bottoms. If the end is exposed, I'll usually cap it with a framed panel that mimics the look of the doors. The end-cap panel and the side wall of the cabinet are both capped in front with 1-1/2" face frame. End grain is bad. |
LRG WoodCrafting
Usually I make a lower cabinet that has the sides go down to the floor. I use a dado to trap the deck of the cabinet. The end panel is usually the side of the panel. If it needs to be a panel end I just add it to it.
If you are using a system with a detached toe this can work toward your advantage for plywood savings. You can make the sides less than 32" and get 6 sides per sheet instead of 4.
| I want to get in Construction and am looking for advice | chompchomp12 | Business | 21 | 12-17-2009 10:39 PM |
| Did you know Microsoft has Financial and Operational Software for Construction | bdupper | Accounting Software & Discussion | 0 | 06-12-2009 09:25 AM |
| Construction vs. Manufacturing. Who wins? | poole_3 | General Discussion | 10 | 04-04-2009 08:51 PM |
| Construction vs. Manufacturing. Who wins? | poole_3 | Business | 16 | 04-04-2009 08:18 PM |
| Reed Construction Data Launches SmartLead | Grumpy | General Discussion | 0 | 12-18-2008 09:40 AM |
