Cabinet Standards
Old 12-14-2009, 12:43 AM   #1
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
Cabinet Standards
so i'v been building cabinets more often and i can't help but wonder what the standards are as far as dimentions go.
i know widths are usually in increments of 3", but this does not apply to custom cabs. i have also learned bu you guys not to make door stiles less than 1 3/4". i'm not sure if there is a standard for placement of pin holes... i usually start them a foot from the bottom and end a foot from the top inset about 2" front and back.
i think 4" is norm for kick on lowers and hinge centers should be about 3" from top and bottom, but now that i got the festool 32 jig for the router i am assuming there is an easier way to lay out metricly.
so if any of you veterans have some tips to make our projects easier, please share the wealth!!!
world llc is offline
Old 12-14-2009, 11:41 PM   #2
Trim40's Avatar
Trade: Guy who plays with wood
Rewards Points: 550
Re: Cabinet Standards
Those 3 little letters with the big price tag "cnc", makes Festool seem cheap
Trim40 is offline
Old 12-15-2009, 08:50 PM   #3
world llc's Avatar
i think a cnc would take up my whole garage... and home equity
Old 12-15-2009, 08:57 PM   #4
bconley's Avatar
Trade: Kitchen and bath design+remodel
And you would still need the answer to your question
bconley is offline
Old 12-15-2009, 09:02 PM   #5
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 68
The nice thing about custom cabinets - is that they are custom
3.5 to 4" toe kicks / or in some cases none - make it look like a piece of furniture
I generally start my pin holes with 6 to 8" from the bottom & generally end about 4" from the top (it just depends on what the cab or shelving is for)
Making it easier - dedicated machines / areas or a CNC
SLSTech is offline
Old 12-15-2009, 09:07 PM   #6
jamesclerie's Avatar
Rewards Points: 75
www woodweb com/knowledge_base_images/ms/Process32_041204.pdf
This is Blum;s Process 32 manual great reference.
jamesclerie is offline
The Following 2 Users Say Thank You to jamesclerie For This Useful Post:
BKFranks (12-21-2009), world llc (12-17-2009)
Old 12-15-2009, 09:07 PM   #7
bconley's Avatar
Buy out your door and drawer fronts, you will be able to offer way more variety and save time and money.
There are many vendor to choose from check who the cabinet makers in your area get theirs from
bconley is offline
Old 12-15-2009, 09:08 PM   #8
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 8,389
Standard sizes of boxes are in 3" increments. The toekick should be about 4" tall, the actual toe board will be taller because the deck will need to be flush with the top of the lower rail on the face frame (if you build FF cabs like I do). The bottom shelf pin hole is 8" up from the deck and about the same from the bottom of the top rail. The Euro hinge hole should be 4" OC up from the bottom of the deck. This is especially important if you are dealing with lazy susan hardware.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 12-15-2009, 09:12 PM   #9
Jeremy E's Avatar
Trade: carpentry
Rewards Points: 150
Care to expand?
Jeremy E is offline
Old 12-15-2009, 09:15 PM   #10
LRG WoodCrafting
Leo G's Avatar
If you put it lower then it will hit the lazy susan. Don't ask how I know this please.
This is also for inset doors, I don't think it would happen with overlay doors, which I rarely do.
But 4" is the standard setup by the industry. It doesn't always work, especially with wide short doors like the ones you find in a refrigerator cabinet.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 12-15-2009, 09:16 PM   #11
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,496
World, check out the festool owners group and do a search for the LR 32. YOu will find a bunch of simple, yet useful tips to maxamize that system.
It's big advantage is in framless Euro cabs, and takes care of the hinges and all.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 12-15-2009, 09:23 PM   #12
Jeremy E's Avatar
Trade: carpentry
Rewards Points: 150
Leo,
I just built this one. The lazy susan is 27-1/2" in diameter, and it fits in a 31-1/2" wide corner base unit. The rotating shelf didn't even come near the hinges...
How do you build yours?
Jeremy E is offline
Old 12-15-2009, 09:26 PM   #13
LRG WoodCrafting
Leo G's Avatar
Inset or overlay Euro's
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 12-15-2009, 09:31 PM   #14
Jeremy E's Avatar
Trade: carpentry
Rewards Points: 150
This one had inset euros. Are you simply leaving less room between the edge of the rotating shelf, or am I missing something?
Jeremy E is offline
Old 12-15-2009, 09:35 PM   #15
tccoggs's Avatar
Rewards Points: 874
www.true32.com
Bob Buckleys book is a good read for any cabinet maker. It takes a bit to get used to metric, but once you go metric you never go back.
32mm systems are based on that you can build any width cabinet you want, but the hieghts must in increments of 32mm. Toe kicks are typically not integrated, you use adjustable legs, so everything is a frameless box. You can typically use fillers between boxes and moldings to make them look more like framed cabinets.
tccoggs is offline
The Following User Says Thank You to tccoggs For This Useful Post:
Old 12-17-2009, 01:36 AM   #16
world llc's Avatar
Originally Posted by tccoggs View Post
www.true32.com
well that explains ikea cabs!
thanks for the info... i'm going to read up on this... and that festool siteis awesome! wish i knew about it sooner
we'll see how my cabinets turn out the next time... if i can sell a job... at least it gives me a bit of time to learn more and practice
Old 12-17-2009, 02:26 PM   #17
Quiglag's Avatar
Trade: Finish Carpentry
Rewards Points: 150
If you have access to CAD software, the Woodworking Institute Standards might be of some help to you. The files are free http://www.woodworkinstitute.com/pub...asp?series=100
Quiglag is offline
Old 12-21-2009, 07:55 AM   #18
AustinDB's Avatar
Rewards Points: 592
www.true32.com
that's funny...when I first remodeled my home somewhere/somehow I got a tape w/ a metric scale on the bottom and used it constantly. It was awesome for all sorts of work b/c taking half of anything in metric was so much easier. Well, fast forward a few years and I am much better at math and more familiar with the 'English' measurement system. A little trick for splitting measurements in half...if you are halfing 1/8, always double the bottom number and leave the top number...1/16. still for the unlearned the metric is a lot easier.
AustinDB is offline
Old 12-21-2009, 09:42 AM   #19
Still have all my fingers
Bergstrom's Avatar
The metric system has long been a pet peeve of mine. I love working with it and I wish the Imperial system was completely abolished. Unfortunately we live in a country where the construction industry is ruled by a stubborn hierarchy that has been resistant to the switch.
I am almost forced to use Imperial because things out of my control are Imperial based, things such as lumber,sheetstock,blueprints,appliances etc. I can either convert everything for my own use and then convert it back for everyone else’s (which is a total PITA) or I can just concede defeat and work within the Imperial system.
Any good numerical system is based off of sets of ten and it works.
"That'll be $12.13/32, sir" Okay, do you have change for this $100? Think about it. You can take your inch and shove it a furlong up your......
Killing the Earth, one raised panel at a time.......
http://bergstromcabinets.com
http://minneapoliscabinets.biz
http://maplegrovecabinets.com
Bergstrom is offline
The Following User Says Thank You to Bergstrom For This Useful Post:
ChrWright (12-21-2009)
Old 12-21-2009, 01:04 PM   #20
LRG WoodCrafting
Leo G's Avatar
Hey Glen, go pick me up some 5.08cm x 10.16cm x 2.44m
Just doesn't have the same ring as
Hey Glen, go pick me up some 2 x 4 x 8's
Carpenter by day.
http://lrgwood.com
Leo G is offline
Cabinet Software Bergstrom Finish Carpentry 58 01-10-2010 10:11 PM
Small Cabinet Shops kcremodeling Finish Carpentry 38 01-06-2010 09:30 PM
Island cabinet install not2late Finish Carpentry 3 03-15-2009 07:10 PM
Warped corner cabinet Kent Whitten Finish Carpentry 49 03-07-2009 11:56 AM
how to best price costom cabinet work? mikeswoods Finish Carpentry 14 10-11-2008 01:06 PM
