Cabinet Hanging Opinion
Old 01-27-2010, 11:22 PM   #1
jmckay's Avatar
Trade: Trim Carpentry & Interior Remodeling
Question for you all regarding hanging a cabinet. I recently built a 40" tall x 60" wide by 24" deep wall cabinet to hang over a client's front loading washer and dryer. It's very heavy (constructed of 3/4" birch plywood and poplar face frames with 3/4" plywood shelving). I getting ready to mount this and will have the studs behind the cabinet, studs on one wall to the side of the cabinet, and one ceiling joist out from the wall approximately 10 inches. My question for you all: Are these installation points enough to make this big cabinet not sag? I'm just a little worred about it being out from the wall 24" and my last ceiling joist I can hit is at the 10" mark (especially on the side where I can't tie into the wall framing). Any comments? Thanks!
jmckay is offline
Old 01-28-2010, 12:38 AM   #2
Trim40's Avatar
Trade: Guy who plays with wood
Re: Cabinet Hanging Opinion
Are you sure there is only one joist in that space? I had to ask. Since you are asking here, I will assume there is no access above the cabinet. I think you are at looking cutting a hole in the ceiling and adding some reinforcement.
You already knew that, you just wanted someone else to tell it to you.
Trim40 is offline
Old 01-28-2010, 12:53 AM   #3
Tom R's Avatar
If I'm reading this right, - - just cut a section of ceiling out from about the 11" point to about the 23" point and install a few cleats perpendicular to your joists.
Then cover it with your well-attached cab.
(Oop, I see Trim40 just said as much).
Tom R is online now
Old 01-28-2010, 01:06 AM   #4
genecarp's Avatar
If the cab is well built, you have all the support you need, GMOD
genecarp is offline
Old 01-28-2010, 01:08 AM   #5
I like Green things
WarnerConstInc.'s Avatar
Use some grk screws. It will be fine.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is online now
Old 01-28-2010, 01:23 AM   #6
President of the world
world llc's Avatar
Trade: general contractor
the sides of the cab will hold everything.... like a bracket, with the back edge against the wall, how could it do anything other than pull away from the wall?
like genecarp said... if they are built well, you have nothing to worry about...
world llc is offline
Old 01-28-2010, 08:33 AM   #7
stp57's Avatar
Trade: carpenter/ handyman
At a couple of houses across the street from me, I have been checking out the custom cabinets being built there. Very impressive oak (solid & ply), but not a drop of glue on anything (lots of pocket screws though). I guess they don't want the obvious problems with trying to stain over excess glue?
I can easily see these cabinets sagging down the road after the owners load them down.
Steve
stp57 is offline
Old 01-28-2010, 09:04 AM   #8
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Frameless?
Partition in the center?
Gus Dering is offline
Old 01-28-2010, 09:13 AM   #9
stp57's Avatar
No, framed.
Steve
Originally Posted by Gus Dering View Post
Frameless?
stp57 is offline
Old 01-28-2010, 09:26 AM   #10
Tom R's Avatar
The safe thing to do is add ceiling attachment. There was a lady in my area who was paralyzed years ago from falling (overloaded) cabinets.
Now granted, - - the root cause was determined to be both a combination of the over-loading and the use of carbide screws that sheared, - - but with a cabinet of that size, - - why take any chances??
Especially with todays void-prone and green-glue delaminating plywood.
Tom R is online now
Old 01-28-2010, 08:24 PM   #11
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Have you thought about french cleats?
JustaFramer is offline
Old 01-29-2010, 08:30 AM   #12
DN Construction
dnconstruction's Avatar
Trade: Construction
I thought about french maids
dnconstruction is offline
Old 01-29-2010, 10:33 AM   #13
Trim40's Avatar
Just don't dress like one on the job.
I know how you Jersey shore guys are, I used to be one.
Trim40 is offline
Old 01-29-2010, 04:50 PM   #14
world llc's Avatar
you used to dress up as a french maid?
Old 01-29-2010, 08:51 PM   #15
Trim40's Avatar
Back when I ran a crew, I showed up wearing a coconut bra and a grass skirt.
Trim40 is offline
Old 01-29-2010, 08:55 PM   #16
LRG WoodCrafting
Leo G's Avatar
It doesn't really matter how many screws you put through the cabinet into the studs. If the cabinet isn't built up to par then it will sag.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
stp57 (01-29-2010)
Old 01-29-2010, 11:35 PM   #17
mattsk8's Avatar
Trade: Building and remodeling
That's why I dado everything. If you do that it cant sag. I should have charged more for the island I'm making right now because I'm pretty sure it could double as a bomb shelter! It's a 48" island that will have a granite counter top w/ a 12" over hang half way around it. That will be a heavy counter top!!
mattsk8 is offline
Old 01-30-2010, 12:40 AM   #18
world llc's Avatar
loose intepretation of hawaian shirt day?
Old 01-30-2010, 10:01 AM   #19
Trim40's Avatar
John Dibella would have been proud.
Trim40 is offline
Cabinet Software Bergstrom Finish Carpentry 58 01-10-2010 11:11 PM
Fun Cabinet.. Leo G Finish Carpentry 8 01-10-2010 01:01 AM
Small Cabinet Shops kcremodeling Finish Carpentry 38 01-06-2010 10:30 PM
Hanging a floating vanity Gus Dering Finish Carpentry 28 05-08-2009 10:22 PM
Island cabinet install not2late Finish Carpentry 3 03-15-2009 08:10 PM
