Bullnose Crown Slideshow
Old 02-15-2009, 09:59 PM   #1
basswood's Avatar
Trade: trim carpenter
I put a little slideshow together this evening of a project I've posted about before but this shows more steps.
The most interesting slide may be the upside down jigsaw clamped to a work bench as a circle cutting rig.
http://s436.photobucket.com/albums/q...view=slideshow
basswood is offline
Old 02-15-2009, 10:19 PM   #2
Mod / ArchiBuilder
Cole's Avatar
Re: Bullnose Crown Slideshow
Wow, great work! I hope you are getting paid nicely for it!
Cole is offline
Old 02-15-2009, 10:35 PM   #3
Resta's Avatar
Trade: Ornamental Plasterer/Restorer
Work as a plasterer?
Good work.
Resta is offline
Old 02-15-2009, 10:55 PM   #4
OGStilts's Avatar
Very interesting. I've never seen that before. Nicely done.
OGStilts is offline
Old 02-15-2009, 11:11 PM   #5
Al Taper's Avatar
Trade: Drywall Finishing
Thats a realy great Job..Use durabond or plaster?
Al Taper is offline
Old 02-15-2009, 11:45 PM   #6
Pro Deck Builder
AutumnWood Inc.'s Avatar
Trade: Deck Builder
Very interesting work .... Thank You for the post
AutumnWood Inc. is offline
Old 02-16-2009, 12:09 AM   #7
Teetorbilt's Avatar
That's VERY cool! Shaping that out of wood would take 6-8 hrs.
Albert Einstein
Teetorbilt is offline
Old 02-16-2009, 08:30 AM   #8
basswood's Avatar
Thanks Cole, I billed that job out by the hour. It looks like it will get published in FHB, so I'll likely get a paycheck for that too.
Good work.
I try to never tape drywall in more than one small room. This is my first go at ornamental plaster. Glad you approve.
Thanks, nice to get interesting work when possible.
I've never used real plaster. This is durabond 120 for rough coat and joint compound to finish.
Thanks and you are welcome.
Yeah, for stain grade you could glue up 4 quarters and turn a finial matching the crown profile (like the outside of a bowl). Then drill out the center to match the bullnose corner bead and cut the quarters on a band saw. For paint grade... plaster is a good choice. Thanks,
Bass
basswood is offline
Old 02-16-2009, 09:41 AM   #9
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
That is very cool Bass!
How much time would you budget for each corner if you had to put a number to it? Including making the knife.
Who is the goon you have doing the work?
Gus Dering is offline
Old 02-16-2009, 09:48 AM   #10
D.Foster's Avatar
Trade: Carpentry & Remodeling
Beautiful work!!
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 02-16-2009, 02:17 PM   #11
basswood's Avatar
Thanks Gus,
Knife making goes fast, but next time I will make two knives (scratch coat and final). During the first coat it is easy to drift out and leave a ridge or bulge that is a pain to sand back down. The first coat knife can be rough (scratches are good for bonding later coats), but should leave the plaster back an 1/8" or so.
The total time was about 3 hours per corner (I did 6). One or two would take almost as long as 6, if you get my drift.
Regards,
the Goon
basswood is offline
Old 02-16-2009, 02:19 PM   #12
basswood's Avatar
Originally Posted by D.Foster View Post
Beautiful work!!
Thanks, it was fun... and a pain in the arse.
basswood is offline
Old 02-16-2009, 04:03 PM   #13
KentWhitten's Avatar
bass....you are a definite outstanding asset to this site. don't ever think you are posting too much ever. that's nice planning and a nice finish.
Salmon Falls Cabinetry
KentWhitten is offline
Old 02-16-2009, 04:50 PM   #14
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Undoubtedly, the work is top shelf. But I'd sure have that Jack-Leg get a shave... and maybe a haircut.
Hmmm.... so about a hundred a corner?
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is online now
Old 02-16-2009, 05:40 PM   #15
Quiglag's Avatar
Trade: Finish Carpentry
Send a message via AIM to Quiglag
Looks great, but I can see a color difference on the corner.
http://s436.photobucket.com/albums/q...ownfinalsm.jpg
Quiglag is offline
Old 02-16-2009, 08:04 PM   #16
basswood's Avatar
Thanks for the good word.
Fortunately more people see my work than see me... I sneak around behind the scenes, do my thing and disappear.
I get haircuts when my work van needs an oil change (hair cut shop 100' from the lube shop)... both take about the same amount of time and need to happen with equal frequency.
Charge $200/corner!
Actually the color is good, it is the sheen that is different on the pic. The plaster ended up glossier. After I took that photo, the builder touched up the corners with a clear matte finish product in a spray can...worked great.
basswood is offline
Old 02-16-2009, 09:17 PM   #17
Tom Struble's Avatar
Trade: siding
awesome mr.basswood
Tom Struble is online now
Old 02-16-2009, 10:03 PM   #18
Quiglag's Avatar
Ahh, glad he was able to fix it.
Quiglag is offline
Old 02-16-2009, 10:22 PM   #19
gallerytungsten's Avatar
Trade: Design
hi Bass, lots of clever ideas there. Especially amusing: the upside down jig-saw circle-cutting rig. Although I must say I'm rather surprised a man of your talents wouldn't just freehand it.
Now an actual question: what is the brand of knife you are slicing up? I couldn't make out the name in your shot.
gallerytungsten is offline
Old 02-16-2009, 10:38 PM   #20
basswood's Avatar
8" Marshalltown Knife with a Durasoft handle... nice knife to cut up, but I had left it in a bucket of water for a few months accidentally... buffed the rust off and cut it up.
basswood is offline
crown to sloped ceiling fourcornerhome Finish Carpentry 5 12-26-2009 12:36 PM
plaster crown molding install prices... CREATE NYC Painting & Finish Work 2 01-19-2009 06:43 AM
Need help with a bullnose corner with 8" crown jayweitekamp Finish Carpentry 151 10-30-2008 10:33 PM
Crown questions... is there a consensus? El Dorado Wood Finish Carpentry 14 01-04-2007 08:50 PM
Crown Moulding in Joist Bays, opinions. 415moto Finish Carpentry 7 11-15-2006 08:24 PM
