Built-up Victorian Casing Techniques Article
Old 02-11-2010, 06:51 PM   #1
basswood's Avatar
Trade: trim carpenter
Many of you have seen this already, but if you want to see the article, click the link, then choose HTML or PDF (PDF is better):
http://www.jlconline.com/cgi-bin/jlc.../View/1002otjb
Cheers,
Basswood
basswood is offline
Old 02-11-2010, 06:56 PM   #2
IHI's Avatar
Re: Built-up Victorian Casing Techniques Article
Thanks for the link
IHI is offline
Old 02-11-2010, 07:06 PM   #3
katoman's Avatar
Trade: carpenter
Thanks for the link.
In regards to the 'jack mitre' - the correct way to do this is the head cassing is installed full width and the side cassings are coped over the shape on the head cassing.
Then the backband is applied which covers the end grain on the head cassing.
I've renovated many turn of the century homes, and this has always been the way the cassings are done. No mitres to open up.
Just thought guys would like to know this.
katoman is offline
The Following User Says Thank You to katoman For This Useful Post:
Tom Struble (02-11-2010)
Old 02-11-2010, 08:41 PM   #4
smeagol's Avatar
Trade: new construction and remodeling
Do you use a shaper when doing jackmiters in new construction? (like a door mullion)
smeagol is offline
Old 02-11-2010, 08:58 PM   #5
katoman's Avatar
Trade: carpenter
If it's a reno job, there usually aren't too many doors, and I'll do it by hand. But if there are a lot of doors (eg. I may have one coming up that has 30 doors = 120 cassing copes) then I will have the cutter made and do them up on the shaper in the shop.
We don't run into this too often these days. But again I don't specialize in historic restorations.
katoman is offline
Old 02-11-2010, 09:15 PM   #6
Time Traveler
texastutt's Avatar
Trade: Home Reno's and Millwork
Do you have any photos of the coping?
TTFN (Tutt-Tutt for Now)
David Tuttle
The King's Woodwright
texastutt is offline
Old 02-11-2010, 10:52 PM   #7
katoman's Avatar
Trade: carpenter
I don't have any photos. Tomorrow I will make a cassing, cope and post photos. I think you'll see why the old guys did it that way.
katoman is offline
Old 02-12-2010, 08:36 AM   #8
basswood's Avatar
The approach you describe works best if the casing is mostly flat, with a small bead detail or small ogee profile on the inside edge of the casing.
If you look at the casing I was working with the profiled area is large. Coping those casing legs to overlay the head casing would be a daunting task with out machining the coped profile with a set of shaper knives.
Also the cope would consist of fins of very thin material that would have to come to a perfect knife edge for the stepped casing... not the best approach IMO.
Another note, if you are coping just the small bead or ogee, those copes are for joints so small that if just jack mitered instead, the miters would not be likely to open. So there is not much point to it, much like coping base shoe molding.
All the best,
Bass
basswood is offline
Old 02-12-2010, 08:46 AM   #9
katoman's Avatar
Trade: carpenter
All the best,
Bass
Agreed Bass, that profile is not the best candidate for coping. The main purpose of coping is to eliminate the butt joint, which will likely open up.
Yes it is usually done on cassings with a small bead molding, and large flat area. All the more reason to cope this. In the homes I have worked on this had been done by hand.
Another alternative which I have done is to bisquit join the flat area.
Always more than one way to skin a cat.
katoman is offline
Old 02-12-2010, 04:17 PM   #10
tang's Avatar
Trade: Remodel contractor
I have JLCs from when it was in newspaper format over 20 years ago. Some of the best articles I have seen in recent years have been published by Bass. The February article was superb. I love the jig with the cheep hand saw to cut the jack miters, with pocket screws at the butt joint its as good as it gets. Coping that profile would be a nightmare for me but after reading the article I feel confident I could produce that casing with the tools I have. Thanks, Bass keep up the great work!! Tang
tang is offline
How many nails in YOUR door casing? custrel Finish Carpentry 74 03-04-2010 08:32 PM
Mitertite Casing Assembly System Review basswood Finish Carpentry 3 11-21-2009 10:36 AM
Creative Advertising Techniques That Work Hancock Marketing & Sales 4 10-26-2009 12:10 AM
my article on built ins. kreg mcmahon General Discussion 7 09-29-2009 07:36 PM
Addition built on top of septic tank KevinA General Discussion 20 04-02-2009 08:16 PM
