Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Finish Carpentry
Old 08-25-2009, 07:41 PM   #1
Maker of fine kindleing
Gus Dering's Avatar
Trade: cabinet maker
Break down clamping bench
I made a new clamping bench today. I think it might be of interest to some of you.
The main purpose for this bench is to clamp frames onto boxes. The big advantage it has over using saw horses is that the 3/4" parts are all vertical so there is not much in the way of the clamps.
Plus when you don't need it, it breaks down and stands in the corner somewhere.
As you can see the four parts just interlock with one and other. The narrow setting works well for base cabinets and the wider one is nice for uppers. But the two distances are nice to have for all the stange size stuff too.
The picture with the clamps is the original that I made years ago with a skill saw. The boys want to pitch it and make another new one. I say use it, no sense in getting carried away with the cnc. Ya think?
Originally Posted by WarnerConstInc. View Post
Gus is right.
Gus Dering is offline   Reply With Quote
Old 08-25-2009, 08:25 PM   #2
Still have all my fingers
Bergstrom's Avatar
Pretty nice Gus. How far down do you take that spoil board ? I always had vac problems when I would run down that far.
Killing the Earth, one raised panel at a time.......
http://bergstromcabinets.com
Bergstrom is offline   Reply With Quote
Old 08-25-2009, 08:25 PM   #3
JonM's Avatar
I see you are in the fuzzball makin business...
JonM is offline   Reply With Quote
Old 08-25-2009, 08:35 PM   #4
Gus Dering's Avatar
It has seen it's last fly cut. But about a 1/4" is about the limit.
I start with half inch, fly cut both sides a couple times.
Oh yeah, thinned out glue on the edges so we don't lose anything there.
I find the thinner it is the better the suction. Just that when it gets real thin it curls and moves around alot in between sheets.
Gus is right.
Old 08-25-2009, 08:42 PM   #5
basswood's Avatar
Trade: trim carpenter
I feel like I'm at an Art Film festival, watching a movie in Russian, with Japanese subtitles.
basswood is offline   Reply With Quote
Old 08-25-2009, 08:44 PM   #6
basswood's Avatar
I do really like the clamping bench though.
Old 08-25-2009, 08:59 PM   #7
Gus Dering's Avatar
Let me slow it down for you Bass.
The spoils board is that thin sheet of mdf under that work piece.
The vacuum pumps suck through the spoils board to "clamp" the work piece to the deck during machining.
Every part that is out lined, the cutter enters the spoils board by .008 inches leaving a maze of little dados all over the spoils board.
Eventually you begin to lose suction because the surface has been compromised too much.
So enter the "Fly Cutter". It is a 3 toothed 3" diameter planer. We run a program that grabs that cutter and skims .010 inches off the top of the spoils board. All new again.
Reset the tools to the new elevation and you are good to go again.
Eventually the spoils board needs to be replaced.
MDF is denser on the face than the center so I fly cut the new spoils board twice to remove the densest material, flip it over and do the same thing. Then the board breaths better and holds the small parts much better.
Cool stuff
Gus is right.
Old 08-25-2009, 09:17 PM   #8
basswood's Avatar
I've been having fits setting up the "fly cutter" attachment on the 1953 ShopSmith.
Thanks for the translation... reminds me of the movie Airplane with the jive talk deal.
Old 08-26-2009, 04:20 AM   #9
tomstruble's Avatar
Trade: siding
chump dont want no help ,chump dont get no help
tomstruble is offline   Reply With Quote
Old 08-26-2009, 07:32 AM   #10
Trade: Finish Carpenter
Thats pretty cool Gus. So simple but never thought about it. Would be useful. Thanks.
KMac is offline   Reply With Quote
Old 08-26-2009, 09:27 AM   #11
Gus Dering's Avatar
Huh?
I'm slow, you have to use your words.
Gus is right.
Old 08-26-2009, 09:35 AM   #12
basswood's Avatar
Huh?
That is a quote from Airplane...
Old 08-27-2009, 07:01 PM   #13
Trade: carpenter
Thanks Gus. I like the design and it's knock down. Think I might adjust your design a little and make one for on site.
katoman is offline   Reply With Quote
Old 08-31-2009, 06:17 AM   #14
Don't get carried away with the cnc? Why not? You could spend all week making jigs with that thing. Nice table. for those really big cabinets I might add a third leg so there is more bearing surface to rest the cabinet's weight on.
Morning Wood is offline   Reply With Quote
Old 08-31-2009, 08:01 AM   #15
jtpro's Avatar
Trade: Construction Assistant Superintendant/Remodeler
Personally I don't see getting rid of something still usefull
Nice design. Simple, easy to break down, allows for variations.
jtpro is offline   Reply With Quote
Old 08-31-2009, 11:11 PM   #16
Moderator
Double-A's Avatar
I think you've been sniffin the vacuum too much.
Let 'em have fun, sheesh.
New York Times, July 20, 2006
Double-A is offline   Reply With Quote
Built-in Bench Experiment BuiltByMAC Decks & Fencing 44 06-26-2009 05:41 AM
2 step drywall bench plastersurgeon Tools & Equipment 6 05-08-2009 01:14 PM
shower bench that has benn hot mopped careys Remodeling 25 03-15-2009 05:44 PM
building a shower bench when using backer board on walls? wopachop Ceramic & Stone Tile 33 03-06-2009 05:12 PM
metal break acessories Bill Contractor Swap 3 11-12-2008 08:24 AM
