Bosch Digital Mitre Finder
Old 02-08-2010, 03:03 AM   #1
rstarre's Avatar
Does anyone have a Bosch Miter Angle Finder. The cost about 140 dollars and was wondering if it works. I saw a trim guy using one once when they first came out about 5 years or so ago. Does it make difficult cuts easier? Or is it just an expensive unnecessary tool.
http://www.cpotools.com/bosch-daf220...ml?ref=bizrate
rstarre is offline
Old 02-08-2010, 07:30 AM   #2
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
Re: Bosch Digital Mitre Finder
I have 1 and I like it. Great for doing crown and setting up saws for proper angle.
I bought mine used for $85 on ebay a few years ago.
BACKWOODS is offline
Old 02-08-2010, 08:16 AM   #3
Robie's Avatar
I've had mine for 4-5 years and like it. I use it frequently. Well-made also.
Robie is offline
Old 02-08-2010, 08:34 AM   #4
KMac's Avatar
Trade: Finish Carpenter
I've had one for a couple years. I don't use it as much as I thought I was going to but it does get used.
KMac is offline
Old 02-08-2010, 09:40 AM   #5
You did what??
J F's Avatar
I've had a couple of them since they first came out, they rarely get used any more.
If you cut your crown on the flat they're great for figuring out the saw settings, but I cut pretty much everything nested on the saw (no 10" crown moulding).
I've found this starrett angle finder to be great...and it's much easier to fit in the tool belt. It gives you your miter saw settings for cutting 2 pieces to fit the angle or a single piece.
6" and 12" versions:
http://www.amazon.com/Starrett-505A-...8&sr=8-1-spell
http://www.amazon.com/Starrett-505A-...5640021&sr=8-4
J F is offline
Old 02-08-2010, 02:40 PM   #6
sledgehammer 20's Avatar
Trade: remodeling contractor
I had one a year ago, keep your money!
sledgehammer 20 is offline
Old 02-08-2010, 03:16 PM   #7
President of the world
world llc's Avatar
Trade: general contractor
i'v had mine a year and although i don't use it alot, i am glad i have it when i need it!
mostly used for finding funny angles and giving me compound miter settings for even stranger things!
the most usefull use was when we were installing this log like siding with mitered outside corners.... normally easy but the bottom 3 coarses were pitched out on a skirt so i had 15 degrees, 10 degrees and 5 degrees (on average) and because everyone wasn't exact, every cut was unique!! what a pain...
world llc is offline
Old 02-08-2010, 05:20 PM   #8
topsail's trimcat
woodworkbykirk's Avatar
lee valley has a much cheaper version which i had, only $25 but i had to can it because it wouldnt turn off, then add the cost of a $10 to replace the battery.
looking to get something that does the same but without batteries, ill prob break down and get the starrett
woodworkbykirk is offline
Old 02-08-2010, 05:51 PM   #9
I like Green things
WarnerConstInc.'s Avatar
I bought one, tried to use it and sold it.
I bought a Starrett, liked it better but, I sold it.
I just use the one that came with my saw, I picked up another one for 20 bucks so I can get multiple corners.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is offline
Old 02-08-2010, 05:57 PM   #10
You did what??
J F's Avatar
I still haven't used the one that came with the kapex, just used to the starrett...
p.s. warner, you're infringing on my copyright
J F is offline
Old 02-08-2010, 06:22 PM   #11
I like Green things
I look like a ninja with one in each hand!!
I like it, it pretty much relies on your lasers though. You find it, set it, line up lasers with the line on the tool.
It way easy. I picked up another one from a guy that had no use for it. I can keep ahead of myself as I go around a room.
I have pretty much stopped coping trim with these and that saw.
If you get 2, mark one with something obvious so you dont mix them up!!
J F (02-08-2010)
Old 02-08-2010, 06:59 PM   #12
Finish Carpenter
B-McNulty's Avatar
Trade: Finish Carpentry
I've had mine for 2 years and use it a lot installing crown. Also found these charts and they work perfect every time! I keep a copy of each in my phone for quick reference.
Bosch Digital Mitre Finder-crown-mitre-chart-45-degree.jpg   Bosch Digital Mitre Finder-crown-mitre-chart-38-degree.jpg
B-McNulty is offline
Old 02-08-2010, 07:03 PM   #13
I like Green things
Why set 2 angles when you can just set one miter?
JF, I have used my ts-55 and my mft/3 table to cut some really wide crown.
J F (02-08-2010)
Old 02-08-2010, 07:07 PM   #14
Finish Carpenter
B-McNulty's Avatar
I prefer to cut crown flat on the saw table, that's how I leaned to do it, and it works for me.
Old 02-08-2010, 11:55 PM   #15
smeagol's Avatar
Trade: new construction and remodeling
I use upside down and backwards and 12" dewalt nonslider miter saw(tighter tolerences).
Cutting on the flat must be difficult in older houses or existing built-ins when you have to adjust the spring angle for consistant reveals.
smeagol is offline
Old 02-08-2010, 11:58 PM   #16
M. A. Hansen Construction
M. A. Hansen Co's Avatar
Trade: Commercial Contractor
Use the tables and an angle finder workers every time no mater what situation!
M. A. Hansen Co is offline
Old 02-09-2010, 12:07 AM   #17
Al Smith
A W Smith's Avatar
sliding T bevel anyone?...........Anyone?
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 02-09-2010, 12:41 AM   #18
smeagol's Avatar
No it will not. Those tables are only for 2 specific spring angles.
smeagol is offline
Old 02-09-2010, 07:07 AM   #19
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
Construction Master Pro does this for you. You can enter any spring angle and then enter the angle of the cut you want... 90*, 89* 73* or whatever and it gives you your miter and bevel settings...
I was just using mine yesterday for some 6 7/8" crown with a 42* spring angle....
TBFGhost is offline
Old 02-09-2010, 07:52 AM   #20
You did what??
J F's Avatar
yeah, and I use a handsaw for all my cuts and hand nail whole houses of trim
t bevel and a speed square are great...unless you've got a need for speed (or have a not quite up to speed helper).
nothing wrong with the t-bevel, it would be nice if everyone knew how to use this method, but like most things, new tools/technology make things simpler/faster, which usually means a project progresses more quickly...and that means more moola in your pocket.
ya dinosaur
J F is offline
Digital angle finder RowdyRabbit Tools & Equipment 22 12-28-2009 04:49 PM
Bosch 12 dual mitre saw, transport lock wont hold? commen problem? woodworkbykirk Tools & Equipment 10 10-28-2008 09:18 PM
bosch angle finder, chestnut clamps summertime Tools & Equipment 9 09-27-2006 05:59 PM
