General Contractor
Blind Shelf Supports
Does anyone know where I can find "blind shelf supports" that can hold a shelf 12" deep by 180" long?
Or even some sort of concealed system that I can install on a concrete block wall. |
Trade: Finish Carpentry
Re: Blind Shelf Supports
Funny you should ask, I just had a customer request the same thing. I ended up getting a bunch of 1/4" steel L-brackets made up at the local machine shop. There was no drywall at the time, so we dadoed the studs, mounted the brackets flush, and added some more 2x4 for drywall attachment. When we install the shelves I plan on sandwiching the brackets between two 3/4" oak planks and running 1 1/2" trim around the face.
I don't know if this will work for you, obviously it won't if the drywall is already up. If you do end up using steel brackets, get 5/16" or 3/8", I thought 1/4" would be plenty but it still has a little wobble to it. Another idea I was considering was using threaded rod or lag bolts and epoxy.... Maybe someone can chime in with a better way, but that's what I came up with. |
Trade: Historic Restorations
Try leevalley.com they have them
Re: Blind Shelf SupportsLast edited by Dustball; 02-17-2008 at 05:43 PM. |
But he said "concrete block wall". The only thing I would be comfortable with supporting a shelf that long and considering the potential weight it could be loaded with, would be to have steel dowels sticking out of the blocks, but that would have to be installed as the wall was being laid up, so the ends of the dowels could be bent and buried in a full cell of mortar. Then you could either laminate a shelf around them, or if using a large solid timber, bore ovrsize holes in the rear, pump them full of epoxy, and push the shelf over the dowels, supporting until the epoxy dried.
| Windows - Blind Inside? | MHMConstruction | Windows, Siding and Doors | 12 | 02-20-2010 01:50 PM |
| Corner Book shelf | Higgs | Finish Carpentry | 9 | 01-31-2008 08:01 PM |
| Windows - Blind Inside? | MHMConstruction | Remodeling | 9 | 10-06-2007 04:53 PM |
| Tile shelf | ODDBALLS | Remodeling | 4 | 09-26-2007 11:09 PM |
| Adding a brick shelf | mant | Masonry | 4 | 01-06-2007 09:36 PM |
