Trade: Finished /Remod/Decks/ done it all /whatever pays
Biscuits Or A Routed Glue Joint?
Piecing some maple together yesterday and thought about it. Ive used both. Biscuits are a lot easier and I dont worry about a joint being too tight that the wood might split but a glue joint seems to have a more solid connection .
Any preferences? |
Trade: Carpentry & Remodeling
Re: Biscuits Or A Routed Glue Joint?
What kind of joint?? Edge, butt, Case? If it is an edge joint you really dont need anything except two true edges,glue and clamps. Anything else would help with allignment or create more surface area, but a good glue joint is stronger than the wood fibers already.
Do what you would do, as if i won't Do anything after you Did It! |
Trade: siding
i see Gary Katz sometimes uses splines in his casing details but i think mostly for alignment
#4 | |
Re: Biscuits Or A Routed Glue Joint?Quote:
Edge piecing, needed 26 inch wide maple plank. Ive been pretty happy with biscuits so far. Took it to my buddy at a millworks shop he works at. Ran it through a Sandya machine. Nice 80G piece of equipment there. |
Trade: siding
looks like a beut
I like Green things
You need to get you some better clamps there Mister.
My buddy has the Sandya digital drum sander, sweet little set up. I think that is his priceiest machine, unless you add up all the cutters and heads plus the cost of the shaper!! Just get a Domino!! |
#7 | |
Trade: trim carpenter
Looks like yours are--))()--vs.--)()(... but that is better than )))). Maple likes to move seasonally in width more than most woods, so fasteners should be in slotted brackets, or the panel should float in a frame or be fastened at just one edge, etc. to allow movement. If it were fastened along both edges, it is likely to crack. |
| The Following User Says Thank You to basswood For This Useful Post: | RizzoMaryland (03-23-2009) |
#8 | ||
#9 | ||
Yeah, I know,..but its all I got. So far they have done well. I have a few I-bar clamps that I used to hold the last piece on.
Wish I had 80 Gs period. ![]() Quote:
#10 | |
#11 | |
I use wide pieces to join to keep from having so many seams. Also, do you think sealing the end grain before installation would help in absorbing moisture? |
Maker of fine kindling
Sir Bass is not predicting imminent failure. He is saying that it would be best to plan for a little movement in your fastening technique.
As one example, you could use a drawer front adjuster screw that has a washer head on it through a 5/16" pilot hole. Then the shaft of the screw has a little room to move before there is a shearing action taking place. He mentioned a slotted hole of some kind. I'm sure there is a host of ways for you to go but the comment is all about implementing one to avoid a problem down the line. There may be better ideas that can be shared if we knew what you were up to. It's all good |
Took everything that was said into consideration when I mounted it today. Left about an 1/8 inch off the sheet rock on the sides and back and pre drilled a hole, a little bit bigger than the screw, through the bottom plywood to attach the top with. It wasnt slotted but do I see the point now, I may try the drawer front screws next time.
Thanks |
Capra aegagrus
Re: Biscuits Or A Routed Glue Joint? |
Trade: siding
I have stopped using biscuits and a glue joint for a lot of my glue ups. Clamps and glue work great. I hardly ever glue boards up that are more than 3" wide. I will rip anything down to 3" or less. There's too much movement in the wood with wide boards. Glued up edges are strong. I glued up some maple this last week into panel about 30 inches wide. I cut about an inch of each side and I could get those strips to break, let alone on the glue joint.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas |
Home Depot aisle walker
Trade: home remodeling
Cope the joints, according to the majority here its the best way to do crown so it must be the way go period. Coped joints dont open up
#18 | |
Sealing the endgrain is a great idea. It will slow the change down and help prevent "split ends." |
#19 | |
| Tub-Tile joint, grout or caulk?? | Aframe | Ceramic & Stone Tile | 11 | 06-27-2011 02:55 PM |
| Help glue removal | isaac | Finish Carpentry | 2 | 12-12-2008 12:49 AM |
| joint compound under carpet for gaps. | mechanix | General Discussion | 3 | 12-10-2008 03:49 PM |
| Rubber expansion joint? | wellbuilthome | Masonry | 4 | 10-25-2008 09:38 PM |
| Butt Joint problems | AARC Drywall | Drywall | 10 | 09-14-2008 03:40 PM |
