Trade: carpenter
Bevel Edge Counter
whats the best way to cut a laminate counter bevel edge so i don;t see any seams?there will be 2 strips on the front edge,should i start at the bottom?
Trade: Residential Remodeler
Re: Bevel Edge Counter
I buy my beveled edge from Wilsonart. Cut a 1/4 inch groove in the front edge of the counter and install the front edge with the bevel with glue. Finish the top edge with 600 paper.
Still have all my fingers
Mike,
Assuming that the seams you are talking about is the black line of the laminate itself then the only way to hide it is with a miterfolded edge product. The company I use is Kuehn and they will make custom beveled edges out of just about any laminate out there. Without specialized equipment you would have a hard time doing it yourself. The turn around time from the factory is 5 days and it runs about $33.00 for a 12' length. Just be careful the stuff is about as sharp as a razor blade.
Killing the Earth, one raised panel at a time....... http://bergstromcabinets.com http://minneapoliscabinets.biz http://maplegrovecabinets.com |
Trade: carpenter
can i use regular laminate & maybe file the back edges a bit?
#5 | ||
Re: Bevel Edge CounterQuote:
I was referring to actually making the miterfold edging, not applying it. I assume we all have miter saws and tape.
You can use v-32 laminate to minimize the black line (dark colors also help hide the line) but as far as back beveling goes I doubt you would be able to keep it straight enough to look good.
#8 | |
to make a miterfold with a file.
Ahhh.... I see. In that case X2
Trade: carpenter
yeh,that miterfold is sweet.i.am using a black granite look laminate.I don't think the seams will be much of an issue. thnx.
Maker of fine kindling
Re: Bevel Edge Counter |
or a tourniquet
| Grout cracking at infinity edge of pool | Peregrine | Pool Construction & Enclosures | 11 | 05-16-2009 02:58 PM |
| drip edge ? | wellbuilthome | Roofing | 67 | 03-27-2009 07:13 AM |
| sistering joists... how to seal the top edge. | s. donato | Decks & Fencing | 6 | 01-26-2009 09:21 AM |
| installing bevel edge, what works??? | nwksremodeler | Kitchens & Baths | 6 | 01-06-2008 11:33 PM |
