General Contractor
Best Blade To Cut Jatoba
I am doing a finish job in 5/4 Jatoba and wondering what the best blade is to use on my 12" Comp-sliding-mitre saw?
I have a 12" Freud 96T LU85 industrial and wondering if it is to thick (.118) Is a sharp thin kerf blade better? I also have a thinner 96T Rigid R1200 and a thin 80T D1280X Another carpenter has the thinnner 96t blade and it cuts better but maybe I just need to sharpen up? I am wondering which of these should be the best for what I am cutting so I can get it sharpened rather than sharpening everything right now. I am hoping the LU85 is the blade so I can use it for all but it does not seem to bee cutting the Jatoba very well. I used it for about 3 solid months cutting Alder and that is about it? thanks
topsail's trimcat
Re: Best Blade To Cut Jatoba
with my experience with jatoba, you definitely want a fresh blade, either new or resharpened. between the high density and residue/gums in the jatoba it will gum up and dull the blade, if the blade is gummed up it will burn the wood and its hard to get out
I like Green things
Matsuh!ta!!!! Bomb ass blades. $$$$
| Saw Blade Size | Thunder Tile | Flooring | 4 | 10-26-2008 05:41 AM |
| XLM Decking -what blade do I need? | soilman | Decks & Fencing | 9 | 05-03-2008 06:16 PM |
| Best Utility Knife | Journeyman T | Tools & Equipment | 48 | 02-20-2008 08:54 PM |
| So what diamond blade DO you use? | lukachuki | Masonry | 15 | 01-03-2007 01:24 PM |
| Very small/thin table saw blade | Woodcrafter74 | Tools & Equipment | 25 | 12-28-2005 07:25 AM |
