Baseboard To Metal Studs?
Old 06-01-2007, 06:51 PM   #1
MHMConstruction's Avatar
I'm running baseboard on a commercial remodel, and the new walls were all framed with metal studs/tracking.
what's the best way to fasten? I don't think my usual 2" finish nails in my little Porter Cable gun will do it.
or will it?
anyone?
MHM
MHMConstruction is offline
Old 06-01-2007, 07:32 PM   #2
AtlanticWBConst's Avatar
Re: Baseboard To Metal Studs?
or will it?
anyone?
MHM
Use trim head screws.
Links:
http://www.mcfeelys.com/screwlist.asp?sclass=tst
http://www.rockler.com/product.cfm?page=1355
- Build Well -
AtlanticWBConst is offline
Old 06-01-2007, 07:36 PM   #3
Fentoozler
Celtic's Avatar
Glue and shoot the nails at an angle...one this way / ; next this way \ .
Celtic is offline
Old 06-01-2007, 08:04 PM   #4
Carpenter/fencing
nywoodwizard's Avatar
Ditto,the finish nails act as clamps until the clue dries.
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 06-01-2007, 08:40 PM   #5
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
ET&F makes nail guns specifically for trim carpenters and steel framing, I own two and they work great
Chris
Chris Johnson is offline
Old 06-01-2007, 09:39 PM   #6
KentWhitten's Avatar
That's what we're doing on this job I'm on is brad nails opposing and glue. I'd like to see the gun and nail in action. I know they make framing guns for sheathing. Didn't now about finish nailers though. What about heavy gauge steel?
Salmon Falls Cabinetry
KentWhitten is offline
Old 06-01-2007, 09:58 PM   #7
I'm a Mac
We use them on Structural Steel Framing Studs. Most of our studs are 18 & 20 gauge, occasionally at point load locations you get 12's and 14's, the ET&F gun works down to 16 gauge I believe. If you have a White Cap or ORCO nearby they deal with ET&F or for that matter any tool jobber should be able to get them for you, as a first time purchase get the free case of nails with the gun "Remind" them of the free nail deal, they may "Forget"
Chris
Old 06-07-2007, 11:35 AM   #8
only126db's Avatar
Trade: Finish Carpenter
There are special nails with very sharp points and made of harder metal used for metal studs that work in my normal nail gun(senco), you will get less bent nails, but still use some liquid nail on back side of any trim when installing where there are metal studs. Also you may get lucky and there is some kind of wood backing, happens sometimes.
only126db is offline
Old 06-07-2007, 10:57 PM   #9
Trimcat's Avatar
Trade: Trim contractor
Send a message via MSN to Trimcat
Trim screws work, but are tedious. Go with the nails and glue method
Trimcat is offline
Framing with metal studs Rich Construction 39 12-16-2010 10:53 PM
Cabinets mounted to metal studs dayspring Finish Carpentry 3 06-14-2007 10:03 PM
Baseboard to Metal Studs? MHMConstruction Remodeling 17 06-03-2007 12:06 PM
Metal Studs Vs. Wood Studs Towatei & Co. Drywall 7 05-12-2007 11:03 PM
