Bamboo Plywood
Old 02-25-2009, 08:38 AM   #1
brailediver's Avatar
Trade: Carpentry Contractor
Bamboo Plywood
Any one have any experience with cutting scarf or miter joints? Recommendations on saw blades, router bits, etc.?
Thanks,
Gene
brailediver is offline
Old 02-25-2009, 09:00 AM   #2
KMac's Avatar
Trade: Finish Carpenter
Re: Bamboo Plywood
I have not used bamboo ply before but I'm ordering 20 sheets next week for a job. I'm curious how it's going to be to work with it myself.
KMac is offline
Old 02-25-2009, 01:22 PM   #3
romoranger's Avatar
Trade: remodeler
Re: Bamboo Plywood
not sure about ply but I worked with bamboo flooring recently. When the stuff tears out its gets "stringy". I just used a 60tooth blade when I was making miter cuts, cut fine. I tried using a chisel in one spot to scrape an area down, bad mistake. stringy and then some.
and I do agree with d. foster, it does dent easy. I had the same problem with the bamboo floor I installed. After it was installed the property owner rolled a 600lb steel cabinet over it...you were able to see dents from the casters the entire way across the floor. I told him he didn't want that floor, but he "apparently" is always right (but just never correct )
romoranger is offline
Old 02-25-2009, 02:49 PM   #4
LRG WoodCrafting
Leo G's Avatar
Re: Bamboo Plywood
That'll be a good bank roll.
Bamboo is a grass, it is stringy for that very reason. Normal woodworking tools should do fine. Use a 60-80 tooth for the tablesaw and a trim blade for the chopsaw. It will glue fine with normal glues.
Buying small quantities I was paying about $240 for a 4 x 8 sheet of 3/4", $145 for a 1/4" x 4 x 8 and $96 for the solid 13/16" x 12" x 96"
What are you getting it for?
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 02-25-2009, 03:12 PM   #5
KMac's Avatar
Re: Bamboo Plywood
I'm getting 4 X 8 3/4" for $185 - the 1/4" is going for $170. I'm super excited about this job - the whole green thing is good for business plus I've been floundering a bit recently - this will set me up for a month solid - everything is signed and pick the check up next week - thank god
I'll take lots o' pics!
KMac is offline
Old 02-25-2009, 05:43 PM   #6
D.Foster's Avatar
Trade: Carpentry & Remodeling
Re: Bamboo Plywood
Bamboo dents like crazy!!! We pot down a bamboo engineered floor and the clients high heels were tearing it up! We thought it was us so we replaced some boards(after appliances were in). Then there were more and more. they should not have that in a kitchen
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 02-26-2009, 12:02 PM   #7
LRG WoodCrafting
Leo G's Avatar
Re: Bamboo Plywood
He KMac, who is the maker of the plywood, Plyboo, Teragren, someone else?
I get mine form Atlantic Plywood and they carry the Teragen plywood.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 02-26-2009, 12:25 PM   #8
KMac's Avatar
Re: Bamboo Plywood
This is from a company called cali bamboo ( www.calibamboo.com ). They are supplying a local building supplier of mine who had a few sheets in stock I was able to check out. I don't know if cali bamboo is getting plyboo in bulk and reselling it or what their deal is. I called them directly and spoke with their B2B guy who gave me a price of $165/sheet for 3/4" before he realized they were supplying my local building supplier and then told me i would have to deal with them and pay their price ($185).
KMac is offline
Old 02-26-2009, 02:47 PM   #9
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Re: Bamboo Plywood
I did a whole kitchen a couple years ago with bamboo.
I like it. The finished veneer is 1/8" thick front and back with 1/2" core. You can't sand through that.
The material seems to be real flat and stable so larger doors are not a big stress sandwich.
Some guys just sand up the edges real nice and let the cross bands show. That looks nice but a lot of sanding. We found a good edge banding that didn't splinter up at the ends.
I remember paying about $180 for 3/4" from plyboo through our local supplier.
Cutting it is no different than cutting veneer plywood. It will splinter on the crosscut without a good blade.
Gus Dering is offline
What nailer to use for Bamboo Flooring aaks38 Flooring 24 10-25-2011 10:25 PM
Plywood direction effect on floor bounce over I-Joist personalt Framing 25 12-31-2008 05:28 PM
Installing Bamboo flooring in a motorhome sanantoneo Flooring 4 11-19-2008 06:40 PM
Bamboo on stairs with warped stringers tgeliot Flooring 6 11-02-2008 12:35 PM
Plywood w/one hour fire rating fireguy Commercial Construction 8 09-18-2008 06:44 PM
