Attaching Wood Trim To Concrete?
Old 08-13-2011, 06:05 AM   #1
henry0016's Avatar
Trade: mason
Rewards Points: 27
Was looking for any ideas on how to attach would trim to concrete?
henry0016 is offline
Old 08-13-2011, 11:01 AM   #2
WildWill's Avatar
Rewards Points: 504
Send a message via MSN to WildWill
Re: Attaching Wood Trim To Concrete?
I lay the trim on the concrete and drill very small holes through it and hit the concrete just enough to make a mark. I then remove the trim and drill those holes out to 1/8th" about 1 1/2" deep. I then tap wood shims into the holes. Now you can place the piece of trim back on the wall and use 4d hand finish nails through the tiny holes that you had made. Make sure when you pick the drill for the holes in the trim that it's not too big as to not grab the 4-6d nail that you'd use.
WildWill is offline
Old 08-13-2011, 11:34 AM   #3
Tile Contractor
MortarForker's Avatar
Trade: Tile Freak
Rewards Points: 75
Sweet..And I thought I was done learning..Thanks Wildwill..
MortarForker is offline
Old 08-13-2011, 08:01 PM   #4
dibs16's Avatar
Rewards Points: 486
Don't forget a little PL in there
Anthony
dibs16 is offline
Old 08-14-2011, 01:08 AM   #5
chief pencil holder
Scribbles's Avatar
Trade: Custom Cabinet Maker, Handrail
Rewards Points: 1,000
dont, the wood will rot
Originally Posted by Greg Di View Post
Nothing you do as a professional should be for free. It's just a silly way of groveling for business if you think about it..
http://sacramentomillworks.com
Scribbles is offline
The Following 3 Users Say Thank You to Scribbles For This Useful Post:
dprimc (08-14-2011), griz (08-14-2011), J F (08-14-2011)
Old 08-14-2011, 01:35 AM   #6
Hardly Working's Avatar
Rewards Points: 808
Use AZEK instead of wood for trim too.
Hardly Working is offline
The Following User Says Thank You to Hardly Working For This Useful Post:
Scribbles (08-14-2011)
Old 08-14-2011, 09:37 AM   #7
stp57's Avatar
Trade: carpenter/ handyman
Will priming the back of the trim help?
Steve
stp57 is offline
Old 08-14-2011, 10:20 PM   #8
WildWill's Avatar
Rewards Points: 504
Whoops, I didn't look at the OPs trade, I was thinking about interior trim. Seeing as he is a mason it's most likely outside. I would agree with others posting in here, go with Azek and be sure to account for expansion/contraction.
WildWill is offline
Old 08-15-2011, 07:18 AM   #9
SclafaniBuilder's Avatar
Trade: Builder
Rewards Points: 150
Ya, for some reason I was picturing it in a garage. OUTSIDE didnt even cross my mind. Too early..in..morning...
Composite material and PL. Stainless screws/nails.
It's kinda hard to say what you would need. Your description is very vague.
SclafaniBuilder is offline
Attaching Dywall to Concrete Block - not a basement jlang Drywall 6 02-07-2010 01:12 AM
Wood options over concrete Vader49 Flooring 8 06-30-2008 03:49 AM
ipe wood tiles, over concrete genecarp General Discussion 0 05-28-2008 08:10 AM
wood filler vs. caulk for trim fabiano Painting & Finish Work 13 07-29-2006 03:09 PM
trim coil over pressure treated wood?? Lt.H Windows, Siding and Doors 7 04-14-2006 12:12 AM
