Advice On Setting A Mantle Beam...
Old 03-15-2010, 09:46 PM   #1
slowsol's Avatar
Trade: General Contracting
In a few weeks I need to set a 6"x6"x6' hand hewn beam as a mantle. The wall is already blocked and drywalled.
What is the best method for holding this thing up? I worked for a builder a while ago that would lag a pieces of 3"x3" angle iron to the wall and epoxy stone mantles that had a slot cut into them to the angle iron. Is this an acceptable way for the beam also?
-John
We'll have to grab a longer board. I forgot to put the wood stretcher in the truck today.
slowsol is offline
Old 03-15-2010, 09:52 PM   #2
KemoSabe
loneframer's Avatar
Re: Advice On Setting A Mantle Beam...
In the past, I've seen rebar drilled into the block and epoxyd in, then the back of the timber is drilled and set on the rebar with construction adhesive.
loneframer is offline
Old 03-15-2010, 10:37 PM   #3
pinwheel's Avatar
That's exactly how I've set them before. Completely invisible.
pinwheel is offline
Old 03-15-2010, 11:22 PM   #4
Rising dove tail brackets.
neolitic is offline
Old 03-16-2010, 09:50 AM   #5
wannaBelkhuntin's Avatar
Trade: Trim Carpenter/Electrician/Tile Setter
For an old hand hewn beam like that I drill 3/4" holes about 3" deep and then use 6" timber screws to attach it, then I use Walnut pegs left about 1" proud. Pegs would be common on something like that, plus I can move it after the HO looks at it and decides she would like it a little higher. I have done triple 3" slab Cherry mantles by drilling holes in the top or bottom and using timber 6" screws at an angle and then plug and sand the holes. The timber screws are quite a bit stronger than the cheap lag screws you get now days, I have watched a few masons stepping on the mantles and have never had a problem with this style install. Plus it is easy.
wannaBelkhuntin is offline
Old 03-16-2010, 12:02 PM   #6
UpNorth's Avatar
Trade: Engineer & Ret. GC
Hand hewn is nice, but the side going against that nice flat wall should be surfaced.
Nice job for a big router, a sled, and a large mortising bit. A large 14-degree dovetail bit is used to edge the cleats, and also to finish the mortises in the beam's wall-side.
Neo's suggestion is a good one. I have used variations of this, one just yesterday, to hang a mirror with heavy white oak frame.
A sketch of what might work is shown, attached. Use collar templates and patterns. One large piece of ply for the 4-hole pattern for the mortises, works also to mark the wall for attaching the cleats. Fix the cleats with anchors of your choice.
UpNorth is online now
The Following User Says Thank You to UpNorth For This Useful Post:
thezoo (03-21-2010)
Floor beam Adam_James Remodeling 1 09-12-2009 04:38 PM
Lam beam question brian1780 Framing 18 08-24-2009 09:35 PM
Embedding W10 beam in concrete footing Greg Di Construction 31 02-20-2009 08:45 AM
Need help on beam advice for a loft mcu Framing 16 11-08-2008 02:40 PM
Beam Specs ophnurse Framing 19 10-02-2007 08:21 AM
