10" Miter Saw Good Enough?
Old 03-15-2010, 12:48 PM   #1
Geek Carpenter
Brandito's Avatar
Trade: Union Carpenter
ok first time posting a question of my own here, feel a bit like a n00b
here's the question, i did framing throughout my apprenticeship and decided to ask for a miter saw a couple christmas's ago so i could do trim work if the opportunity arose. i figured a 10" would be enough for interior trim work. i'd like to diversify my skill set a bit more.
i've not gotten to use it a great deal, which i planned for by getting the 10" instead of a 12". it's not a slider either, it's actually a dw713. my question is how good did i do? mind you this saw really only was intended for interior trim, and i've used it to trim a shed i built recently.
it seemed like a 12" might be overkill for interior trim at the time, but it seems most of you guys use 12's as well as 12" sliders so i'm beginning to second guess.
seems like the few times i've worked around the trimming crew that they had smaller 10" saws mostly which is what i really based my decision on. as a framer it's rare that i'm in a building long enough to see any trim guys go to work.
so what will my limitations be as far as material? i just don't have the experience with trimming to know how much, if any, my saw might limit me cut wise.
Brandito is offline
Old 03-15-2010, 01:08 PM   #2
pinwheel's Avatar
Re: 10" Miter Saw Good Enough?
Standard base, casings, base shoe, ect, you'll be just fine. Wide base or wide crown is a different story.
pinwheel is offline
Old 03-15-2010, 01:44 PM   #3
Geek Carpenter
Brandito's Avatar
that's kind of what i figured. so it sounds like i'll be fine for basic trim, which is what i figured when i got the saw.
thanks for the quick reply!
Brandito is offline
Old 03-15-2010, 02:02 PM   #4
AndersonsWworks's Avatar
Trade: Custom Cabinetry
Is it a compound saw? If not you are pretty limited on the width of the trim. I use a 10" compound miter and can do 4 1/4" base pretty comfortably but sometimes I wish I had a 12".
Rocky
AndersonsWoodworks.com
AndersonsWworks is offline
Old 03-15-2010, 02:21 PM   #5
Sweeper of fine saw dust
chris klee's Avatar
Trade: Project Manager by day, Cabinet maker for fun
i had a 10" delta before i started doing trim and stuff, and used it for a couple years in.
for 90" of the trim i do, i could use a 10" compound. the 12 makes 5-1/4 base alot easier. i think the 10" dewalt will cut that standing up iirc.
either way, if your new to trim you will wear that thing out about the time you need a better saw.
chris klee is offline
Old 03-15-2010, 02:31 PM   #6
Geek Carpenter
Brandito's Avatar
Rocky
yes it's a CMS
good to hear! i'll have to check that 5 1/4" base stat though.
Brandito is offline
Old 03-15-2010, 02:35 PM   #7
I like Green things
WarnerConstInc.'s Avatar
I use a 260mm saw. It will do whatever I need it to.
Slides just give you more cross cut capacity.
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is online now
Old 03-15-2010, 03:39 PM   #8
Rustbucket's Avatar
Trade: Remodel/Deck
I started out with a 10" CMS back in the early 90's. It was a Craftsman with cast iron base. I swear it is heavier than my 12" SCMS Milwaukee! I still have it, and still use in now and again. Worked great for what I used if for back then. Combined with my worm drive, I built a lot of decks, fences and trellises, and did a lot of trim with it back then. It won't handle larger trim, as many have mentioned. But, for the stuff that goes into most average homes, it worked fine.
Rustbucket is online now
Old 03-15-2010, 09:20 PM   #9
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
....I have a dual bevel 10" Delta Saw I use ALOT. But for the larger jobs I take my 12" Slider...
10" CMS
12" Slider
TBFGhost is online now
Old 03-15-2010, 09:24 PM   #10
I like Green things
Are your saws doing the nasty again?
Old 03-15-2010, 09:45 PM   #11
RobertCDF's Avatar
Trade: Custom deck builder
Glad to see censorship has come to tool pics as well... My wife will finally stop yelling at me for looking at pictures of saws...
RobertCDF is online now
Old 03-15-2010, 10:24 PM   #12
topsail's trimcat
woodworkbykirk's Avatar
when i was a 2nd yr apprentice i bought a hitachi 10" compound mitre. it was good at first, fine for 4" wide mouldings but that was it. as i started doing crown more often the saw had to go i sold it off and bought a Bosch 12" dual compound mitre saw. love my bosch super accurate since i only use it for trim but hard on the lower back its the heaviest non slider on the market. the next saw will be a 10" dual compound slider either makita or another bosch, not as heavy with greater cut capacity only thing is ill have to switch to cutting crown on the flat as opposed to upside down and backwards as i was taught
if you can handle having two saws, keep the 10" for framing use it for a cut station and for decking. get the 12" for trim but avoid dewalt, ive found their bearings get bad too quick which leads to blade wobble and sloppy joints
woodworkbykirk is offline
Old 03-16-2010, 12:16 AM   #13
Geek Carpenter
Brandito's Avatar
i've never used a miter saw for framing, just don't really see that around here.
good advice though guys.
say i were to go larger, 10" slider or 12" non-slider? and how important do you guys think it is to go for dual bevel? i know dual bevel would likely come in handy, i don't guess it would hurt, well except the wallet
Brandito is offline
Old 03-16-2010, 09:33 AM   #14
chris klee's Avatar
For a saw that can cut 5-1/4 base, I hardly use it. On the 10" I used to have, I used the bevel everyday. It was only single, and flipping 15' base around to get the right miter sucks.
Old 03-16-2010, 05:04 PM   #15
Warren's Avatar
Trade: framing/remodeling
I have owned both miter saws and slide saws. Currently I have a 12 inch milwaukee slide and a Dewalt slide. We do mainly framing and occasionally exterior trim. We rarely use the slides for framing. For exterior trim however it is a must. Most framers eventually will end up doing a decent amount of exterior trim and therefore I think the slider is necessary.
Warren is offline
Old 03-16-2010, 09:18 PM   #16
Fyrzowt's Avatar
Trade: Cabinets and doors
Those are the 2 saws I have - a 10" Makita slider and a 12" Bosch non-slide. I always go for the 10" unless I'm doing crown. The 12 has a taller fence for crown.
The 10" cuts a wider board, and I feel that the smaller blade is more accurate.
I prefer the dual bevel saws.
Fyrzowt is offline
Old 03-16-2010, 09:27 PM   #17
topsail's trimcat
flipping long stock around also sucks if your in tight quarters and run the risk of dinging painted ceilings. also if your like me and have chewn up shoulders spinning long stock puts alot of tension on the rotator cuff
Old 03-17-2010, 01:41 PM   #18
Geek Carpenter
Brandito's Avatar
can anyone recommend a good book for finish carpentry?
saw in a few threads some books guys recommended for framing, and picked, "A Graphic Guide to Frame Construction"
has a lot of good stuff in it i can reference when i just haven't done something before, wondering if anyone might know of a similarly good book for finish carpentry.
i till have all my workbooks from my apprentice training as well as our huge text book. the text book doesn't detail a lot but it's got some good stuff in it too. i've looked back a few times through my old work books to refresh myself on something i haven't done in a while. they don't have much info in them though as they mostly contained details on what the shop projects for that week of classes would be.
Brandito is offline
Old 03-17-2010, 07:45 PM   #19
chris klee's Avatar
That's why I got a dual bevel saw. My shoulders would always Hurt. Not as much after getting the 12" dual bevel.
Old 03-17-2010, 08:03 PM   #20
Fyrzowt's Avatar
Taunton's "Finish Carpentry" is a good one, put out by Fine Homebuilding.
It's broken down into different chapters - each chapter is written by a different carpenter, and on different subjects, such as Crown, Windows, Paneling, etc.
I've enjoyed reading/re-reading mine.
About $18 in the US, $26 in Canada
Fyrzowt is offline
Solving the Housing Crisis, this is lengthy but good reading PMI General Discussion 11 03-17-2011 03:50 PM
i need help finding some good slogan and catchy words. saeed Marketing & Sales 14 11-03-2008 08:24 PM
Good resi guy for electrical in MI Bkessler Help Wanted or Looking For Work 0 10-03-2008 08:21 PM
Is that marketing tool a good idea or a cheap one? WaltG Marketing & Sales 5 03-20-2007 10:15 PM
