Paper Specs For Brochure Printing
Old 01-04-2008, 09:43 PM   #1
plazaman's Avatar
Im about to have my marketing brochures printed and wanted to know what kind of specs should i look out for? Gloss? lbs paper? etc....
Thanks
plazaman is offline
Old 01-06-2008, 12:36 PM   #2
plazaman's Avatar
Re: Paper Specs For Brochure Printing
anyone?
plazaman is offline
Old 01-06-2008, 12:53 PM   #3
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
It depends upon what you want. What are the choices?
Mike Finley is offline
Old 01-06-2008, 02:40 PM   #4
RobertCDF's Avatar
Trade: Custom deck builder
100LB + gloss looks nice. Get a UV coating as well. I am real anal about paper stuff anything that goes out from my business is on the brightest paper and envelopes I can find. Estimates, ref sheets and other stuff in my folder are printed on a laser with 28LB super bright paper. Anything printed by a pro printer is at least 100 LB and full gloss and uv coating.
RobertCDF is offline
Old 01-07-2008, 12:39 PM   #5
Bah Humbug!
Grumpy's Avatar
I do my own on my color laser printer and I use bright white 24#. If you buy the cheap stuff generic brand it's not much better than a 20#. However if you buy a name brand like HP you get a nice paper which won't bleed through.
If you are hiring a professional print comany they should make recomendations and show you samples.
Grumpy is offline
Old 01-07-2008, 12:56 PM   #6
fathersonfab's Avatar
Trade: General Contractor / REO Repairs
I've seen a few questions about printing and thought I'd pass on a link to my printer. I've used them for business cards and flyers in the past and they are great. Everything I've had printed has been very high quality... and they are fast and cheap. They are the only printer I will use.
They are a bulk printer and run 24hours a day. which means they gang all the jobs together and run them at the same time which saves allot of money.
You can email your job to them and they will ship it back UPS usually with in a week.
The only down side is they have a HUGE minimum printing. I usually get full color front and back business cards (4 over 4)... minimum qty is 5000 cards... but it only cost $99.... so i don't feel too bad throwing away a couple hundred cards!!
Here is the link.... http://americasprinter.com/
Hope that helps.
"I cut it twice, but it's STILL too short!" singerREO.com
fathersonfab is offline
Old 01-07-2008, 02:41 PM   #7
Carport King's Avatar
Trade: Aluminum Contractor
Nothing less than 80# should be 100# and 4 color process.Choose your colors and always use the same high quailty printer.Hire the best and hire a designer/layout firm for everything you print including newspaper ads.If you were to put all your ads or printing on a wall would it all blend or does it look like a mish/mash of different colors and layout.Do your homework, this is what makes the phone ring and sets you apart from everyone else.Good luck
Carport King is offline
Type of Paper Under Hardwood CharlieDaw Flooring 2 04-12-2007 10:43 PM
Wood Floor and Rosin Paper over Radiant cyepsen Flooring 2 03-08-2007 09:50 PM
Paper Adhesive tape. jstrand23 Drywall 1 03-07-2007 06:02 PM
commercial wall paper removal rservices Wallpaper 1 06-28-2006 09:58 PM
why primer is bubbling up over wall paper Zeebo Painting & Finish Work 2 07-10-2005 10:11 PM
