hurtlocker
Trade: homebuilder remodeler carpenter
Walk In Shower Opening
What is the average size
What would be a minimum |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Trade: carpenter
Rewards Points: 2,000
Re: Walk In Shower Opening
I think 24" is pretty standard. There may be a minumum in your building code. I can't recall ever going smaller than that.
Advertisement |
Trade: Remodeling contractor
Rewards Points: 250
I would GUESS 30" to be most common. I did one that was only 24", but the door to the bathroom was only 24" also!
Gonna die a glass guy
Trade: Skylights and Glazing
Rewards Points: 250
24" open is a code minimum I believe, At home I went 27" thats all I could fit. I think Neo-angle pans and enclosures you end up about 28-30 standard
I have done doors as wide as 36" and only one ever at 24" ,thats really small. I'm a bigger guy shoulder wise anyway and the 27" open is comfortable. I don't have any bruises Last edited by ccappaul; 12-19-2010 at 08:28 PM. |
Carpe Diem
Trade: Smile 4 Tile
Rewards Points: 1,114
Round here, newer homes offer a standalone shower in 32" x 32". That's one of those one piece fiberglass units. I don't see anything else smaller without having a size limit to where it's being installed.
Angus |
hurtlocker
Re: Walk In Shower Opening |
Rewards Points: 250
Re: Walk In Shower OpeningMine is a walk in No door 27 " clear opening, No Threshold about 5 foot by 4foot floor area , 2 heads and fold up shower seat, built in 3 shelf soap ummmm cabinet? without doors ![]() I had to suck 1/4 inches everywhere to get the 27" but i didn't want to go any smaller Did I say threshold thats door talk ![]() Last edited by ccappaul; 12-19-2010 at 09:00 PM. |
Carpe Diem
Trade: Smile 4 Tile
A usable 32" x 32" is about the smallest I'd ever build. Anything smaller and that's the point where I'd start looking at alternatives.
Angus |
Trade: Bathroom Remodeling
Here are some of the code requirements for showers - shower size code requires a minimum 900 sq inches (30"x30") (36x36 is recommended smallest size)- shower seats can't infringe on the 900 square inch rule, if it's neo angle shower you have to be able to get a 30" disk inside shower so this makes neo angle showers larger then the 900 sq inch requirement - I think the math works out to they are always going to be a min 1300 sq inches, but don't quote me on that one, gotta have 24" in front of a shower entrance, door has to open outward, tempering requirements of course, however I've never seen any code requirements on size of door. Code is concerned with safety, as long as the door opens outward and a person gets through it to get inside, I guess they figure you can get out.
ADA requirements are different. Don't forget, local code supercedes everything, so check with your building dept. If you are looking for common sense measurements - best shower door openings are between 28"-30" wide, that's what we shoot for when it's up to us. |
The Following User Says Thank You to Mike Finley For This Useful Post: |
katoman (12-19-2010)
hurtlocker
There is no door
No local building requirements |
Trade: carpenter
The Following User Says Thank You to katoman For This Useful Post: |
ccappaul (12-19-2010)
Rewards Points: 250
Must be doing this at your own home
![]() Like My shower has glass block shelving and being a glass guy i know they they should be tempered if not for code at least for my own stupid arse safety. Like I wondered about not having a curb but I didn't ask. If you only weigh 120 soaking wet, and your wife is smaller than you are a 24 " opening is going to work great, If on the other hand you are 6'6" 280 you should probably go a little bigger |
Carpe Diem
Trade: Smile 4 Tile
No, there are areas of the country that don't need permits....for anything.
Angus |
The Following User Says Thank You to angus242 For This Useful Post: |
Fire up the BBQ
![]() Trade: GC
Rewards Points: 458
You guys doing walk in showers ever think about making them to ADA code for future sale? Just asking.
Carpe Diem
Trade: Smile 4 Tile
In a perfect situation, that would be nice. But like Mike said, a lot of curbless stuff is a bitch to pass inspection. It's too big of a pain to make a standard offering.
But these new linear drains are helping ![]()
Angus |
griz (12-19-2010)
hurtlocker
2' opening is what I have it designed for now I was thinking about squeezing a couple more inches out of it
But I think i will stay with 2' BTW almost all my houses have a walk in pantry with a 2' door Even the chubbies seem to squeeze into those with no problem That is why i was thinking about shrinking the shower opening down a bit |
hurtlocker
I Have also had people complain that the opening was to large because
it took a while to heat up the shower area |
#18 |
Trade: Home Renovations & Repairs
Rewards Points: 252
Did a walk in shower stall in March where the elderly couple tried to persuade me that an 18" opening was plenty wide enough. I gave them the blurb about resale, larger people, ADA compliance, etc etc but they were not interested ... until I spoke to the building inspector who advised that although there wasn't really a code as such there was common sense which was to go no narrower than 24", which is exactly what I had suggested.
I used 2x4's to create a mock up of the opening at 18" and then 24" and sure enough they bumped their shoulder every time at 18" ... when I explained that 2x4's are a lot softer on a naked shoulder than 10mm glass they agreed to go with 24" ;-) Likewise there was no door ... a 36" glass screen & then a 24" opening.
Renovations & Repairs. Bathrooms, decks, tile, paint & much more. North Vancouver to Whistler and between. TOLL FREE 1-877-804-3326 http://www.adventhomesolutions.com |
#19 |
Trade: remodeling/specializing in kitchen & baths
Rewards Points: 578
Its not a bad idea to size the openings to match a stock door ( 24" or 27" ) so you don't have to jump thru hoops when they call you back to door the shower cause the wife gets too cold. You do realize ADA compliance does not apply to residential construction of single family homes right?
#20 |
Rewards Points: 430
With people being as big as they are nowadays, a 2'6" wide door is the minimum, even for a pantry, in new construction and 2'8" for all passage doors. I've had to adjust a couple of things in the last half dozen houses to allow for this. The smallest door always seems to be a walk-in pantry. The ones designed in a corner have to be made bigger which cuts down on the wall space left for cabinets but I think it's worth it. I apply the same logic to shower entrances. To use a bypass shower, this means the shower has to be 5 foot wide to get a (close to) 30" opening. The plan my wife has picked out for our next home has two 27" doorless openings to the master shower. I will adjust the building width in the area to allow for 30" openings, although I really don't understand the two openings unless the designer did it for symmetry purposes.
AdvertisementLast edited by txgencon; 01-29-2011 at 10:28 AM. Reason: sp |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Custom shower base - granite | Charles_cz | Tiling | 16 | 01-08-2015 08:34 PM |
Walk In Shower Ideas | PacNWStructures | Remodeling | 20 | 11-20-2011 01:07 PM |
Strange shower leak - need help | JSMHDM | Plumbing | 13 | 12-06-2010 04:38 AM |
tub spout to shower wand | lshomesolutions | Plumbing | 1 | 06-08-2010 08:42 PM |
Tiled shower leaks...Could use any advise at all... | Jay22 | Tiling | 17 | 12-10-2008 06:15 PM |
Go to Page... |
