Trim Detail For Glazing On House - Architecture & Design - Contractor Talk
Old 01-24-2017, 08:42 AM   #1
tyoung's Avatar
Trade: commercial
Rewards Points: 16
Hello-I am installing a glass transom and glass window on a house both are covered under a porch. Does any one have a few details for trimming out the framing for the glass install? The glass company is just bringing glass no frame. Thanks!
tyoung is offline
Old 01-24-2017, 12:40 PM   #2
tyoung's Avatar
Trade: commercial
Rewards Points: 16
Re: Trim Detail For Glazing On House
anyone have any good details? Thanks
tyoung is offline
Old 01-24-2017, 12:55 PM   #3
Railman's Avatar
Trade: Railing
Rewards Points: 459
It depends on the sizing of the glass, & rgh opng. I always allowed framing for a full wall wdth x 3/4" flat jamb, + 3/8" to 1/2" wiggle, plus glass size. I also used glazing tape on both the inside, & outside of glass, applied to the stops. Then I applied the stops on both sides.
The other common way to do it is to use rabbited door jamb stock, with a stop on the outside. This gives a cleaner look on the inside than a flat jamb with stops.
The problem with using door jamb stock is that you have to be real carefull when you nail the casing wrap, because the glass is only about 1" from the casing! I bought a couple 6 ft leaded glass transoms as a result of that!
Also...You need to set the glass on rubber glass blocks set at about 1/4 width in from the outside of glass. 1/4 gives a perfect balance on the glass.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
Rio (01-24-2017)
Ben Moore Aura as a trim paint?? Dorman Painting Painting & Finish Work 10 03-19-2013 09:35 AM
200 year old house resto/reno blackbear Carpentry Picture Post 38 08-27-2012 09:25 PM
Historic Brick House (Findlay, Ohio) WerkBrau Excavation & Site Work Picture Post 12 07-02-2012 04:54 PM
Beach House Mitch M Painting & Finish Work 8 05-01-2011 07:16 PM
Floating house, house floats up during hurricane medusa General Discussion 62 01-03-2011 08:08 PM
