Siding "shouse" - Architecture & Design - Contractor Talk
Siding "shouse"
Old 08-07-2016, 11:03 PM   #1
51carpenter's Avatar
Trade: Carpenter Contractor
Rewards Points: 282
Siding "shouse"
We're building a shop with a house on top, like a carriage house. 28x48, and 24` to the eave.
We're going with metal for the roof and siding. I'm trying to get ideas on siding, how to break it up. I've done wainscoat on some buildings like this, the tallest was 18` with a 3` wainscoat, it was level with the window sills.
If I have a bunch of 4x4 windows with the top at 6`8" to match the walk doors, and have wainscoat I don't think that 3` would be tall enough and I think it looks dorky if it runs halfway up the windows.
I've thought about a belly band. I also plan to have multiple colors. Roof color, siding color, wainscoat color, and possibly match all j metal trim and corner metal to the roof color.
Thanks for any ideas.
Professional wood welder
51carpenter is offline
Old 08-09-2016, 01:11 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 9,352
Re: Siding "shouse"
Well,there is a book out there,the title is What Not To Build,it warns two materials per elevation and two colors. With all the color changes you mentioned,it will violate at least one of the rules.I feel you may want to rethink all those colors,you're building a shop/ house,not a rainbow.
https://www.amazon.com/What-Not-Buil...t+not+to+build
fjn is offline
The Following 4 Users Say Thank You to fjn For This Useful Post:
SmallTownGuy (08-24-2016), Tom M (08-24-2016), Tom Struble (08-09-2016), wallmaxx (09-05-2016)
Old 08-09-2016, 05:53 PM   #3
Rewards Points: 282
Re: Siding "shouse"
Right on, thanks. That book looks interesting.
I'm just over thinking it, probably just go with a wainscoat, keep it simple.
Old 08-21-2016, 07:50 AM   #4
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
Re: Siding "shouse"
I see a lot of condos, townhouses, and other sardine type containers that intentionally throw a mix up of the most contrasting materials/colors. It seems though as they do that in order to not make the cramped and small look cramped and small.
Krok is offline
Old 08-24-2016, 01:16 AM   #5
Guest
191266's Avatar
Trade: Home Designer
Rewards Points: 28
Re: Siding "shouse"
It somewhat depends on the style of the building. Sometimes the "rules" need to be broken. Can you post some images of the floor plan and/or general elevations you have in mind?
I've been working on some plans for a garage with guest house above. It's an industrial modern, with some exposed block, stucco, and standing seam aluminum roofing & siding. The three materials blend really well and work with the clean, simple lines of the building.
191266 is offline
Old 08-24-2016, 08:16 AM   #6
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 838
Re: Siding "shouse"
I can offer no insight on colors and such, but I think the whole concept of having a residence above the biz is way cool. (How all small towns used to be).
Is this for your own use?
SmallTownGuy is online now
Old 08-24-2016, 09:39 AM   #7
Rewards Points: 282
Re: Siding "shouse"
This is going to be our shouse. I've changed the design, I think I've drawn it 3 or 4 times now.
I'll try and post a pic of my drawing tonight.
The new design is 28x40. 2 bed, 1 bath. 2, 6 3/4" x 24" x 28` glulams will carry the floor and will be pocketed into the exterior wall. TJIs will hang off the sides of the glulams.
The basement/shop area will have 12` walls and be open. I didn't want posts so that's why the glulams are so big.
I'm not as worried about the exterior finish now, since I took 4` off the height.
I'm thinking of using ICFs for the foundation, I've never used them and would like to.
The Following User Says Thank You to 51carpenter For This Useful Post:
Old 08-24-2016, 01:02 PM   #8
Guest
191266's Avatar
Rewards Points: 28
Re: Siding "shouse"
This sounds so similar to what I'm working on. 12ft ceiling so a car lift will fit in the shop?
I was also thinking about ICF, but I've settled on Omni block. It's like reverse ICF with the insulation inside the block, so you can leave the block exposed as the wall finish.
I'm excited to see your plan. I can clean up a few ideas and share if you'd like.
191266 is offline
Old 08-24-2016, 10:35 PM   #9
Rewards Points: 282
Re: Siding "shouse"
First time posting a picture, so bear with me if I messed up
Old 08-24-2016, 10:43 PM   #10
Rewards Points: 282
Re: Siding "shouse"
The top of the floor will be 12` and the bottom of my two beams will be 10` and the ceiling will be 11`.
I'll be able to have 10` tall garage doors so backing trailers in will be possible. That and it's easier to spin lumber around with more headroom. Our garage at or house we're in the process of selling only had 8` ceilings and I couldn't stand it.
Old 08-25-2016, 05:53 AM   #11
John the Builder
Rewards Points: 838
Re: Siding "shouse"
This to go up on some acreage I take it?
Old 08-25-2016, 12:34 PM   #12
Guest
191266's Avatar
Rewards Points: 28
Re: Siding "shouse"
I like the split bedrooms. I'd probably extend that hall wall over so the bath is screened from the living room a bit more.
Are there exterior stairs, or is this a sloped lot?
191266 is offline
The Following User Says Thank You to 191266 For This Useful Post:
j_sims (08-26-2016)
Old 08-25-2016, 01:02 PM   #13
Rewards Points: 282
Re: Siding "shouse"
I didn't label the stairs, but they are at the end of the house off the kitchen. The stairs go down under the closet for that bedroom.
We have 2 11 acre lots next to each other. This is going up on the end of them.
I might have a picture of the land on my phone.
I like the idea of extending that wall.
Old 08-25-2016, 01:08 PM   #14
Rewards Points: 282
Re: Siding "shouse"
The 1st picture is the spot I leveled, the second is looking down hill. I had better pictures on my last phone.
Old 08-25-2016, 01:43 PM   #15
John the Builder
Rewards Points: 838
Re: Siding "shouse"
Where is "here"?
Old 08-25-2016, 02:05 PM   #16
Guest
191266's Avatar
Rewards Points: 28
Re: Siding "shouse"
Wow. Love the view.
Is the area between the two bedrooms with the exterior door the entry, or a back door?
191266 is offline
51carpenter (08-26-2016)
Old 08-25-2016, 05:26 PM   #17
Rewards Points: 282
Re: Siding "shouse"
Thanks! The view is awesome.
We're in Jefferson City Montana.
Between the bedrooms is the entry, which will be on the uphill side, so the shop will be like a daylight basement.
Old 08-25-2016, 10:25 PM   #18
Guest
191266's Avatar
Rewards Points: 28
Re: Siding "shouse"
That makes sense. What style are you thinking of doing?
My brain thinks in modern, so my first thought on exterior finishes would be a small cantilever for a portion of the upper level. That would give you a nice visual break and a place to change materials.
191266 is offline
Old 08-26-2016, 08:13 AM   #19
Texan
j_sims's Avatar
Rewards Points: 68
Re: Siding "shouse"
I agree with joy about extending the wall.
What you're building is a fairly big deal here in Texas... Barndominiums
TEXAS Born, TEXAS Bred, When I Die, I'll be TEXAS Dead
j_sims is offline
The Following 3 Users Say Thank You to j_sims For This Useful Post:
191266 (08-26-2016), 51carpenter (08-26-2016), SmallTownGuy (08-26-2016)
Old 08-26-2016, 09:01 AM   #20
Rewards Points: 282
Re: Siding "shouse"
I agree on extending that wall by the bathroom, good idea!
I'm not sure on the style, it'll have a 5/12 roof and 2` eaves.
I don't think a cantilever or dormers are in our budget. We're trying to build this one cheap and go all out when we build a house in a couple years.
Staining Cedar T&G Siding j_sims Painting & Finish Work 1 05-31-2013 10:30 PM
fiber cement siding issues. chapstick Windows, Siding and Doors 36 08-30-2012 08:14 PM
Siding & Windows clemens0894 Windows, Siding and Doors 0 03-28-2012 08:55 AM
Need advice for Siding Jerdog44 Windows, Siding and Doors 5 06-04-2009 04:03 PM
siding an old house gtmstang Windows, Siding and Doors 14 12-20-2008 05:21 PM
