"L" Shaped Shower Curtain Rod
Old 06-30-2012, 03:39 PM   #1
General Contractor
JohnV's Avatar
Rewards Points: 27
Im looking for a "L" shaped shower curtain rod that doesnt need a ceiling support rod. My client really wants this to be super strong as she would like to hang dry clothing from it. All the store bought options arent what they claim. The rods are very weak. Any ideas on either a quality rod to purchase or bracket system of some kind? Thanx
JohnV is offline
Old 06-30-2012, 04:33 PM   #2
Ash@OTL's Avatar
Trade: remodeling/ home repair
Rewards Points: 160
Re: "L" Shaped Shower Curtain Rod
Try 1 inch galvanized pipe, 1 90 degree elbow, and 2 floor flanges. You must make sure to fasten to framing as the pipe is fairly heavy. I make clothes racks for a boutique like this and have never had a problem. Also use degreaser to clean the pipe prior to installation.
Ash@OTL is offline
Old 06-30-2012, 05:16 PM   #3
DavidC
DavidC's Avatar
Rewards Points: 2,006
Make it strong as you like, but that's a lot of leverage without the ceiling support rod. Hanging wet clothes can be a lot of weight. I would not go with out.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 07-01-2012, 08:15 PM   #4
AustinDB's Avatar
Rewards Points: 656
I back up DavidC's comment-that will be a lot of force torqueing the wall connnection. the wall connecdtion may need to be designed/installed before the drywall goes on-is the finish applied yet?
AustinDB is offline
Old 07-02-2012, 01:00 AM   #5
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,654
john does she want a shower rod or a way to hang clothes?, i have never seen this combo unit for sale, the only way this will work is to fab/build a custom piece?, now how bad do you want it ho, and blocking in the wall as stated in post #4
sunkist is offline
Old 07-02-2012, 04:39 AM   #6
Big Shoe's Avatar
Rewards Points: 1,858
Custom welded rod will work. $$$$
Expect the Unexpected
Big Shoe is offline
Old 07-02-2012, 10:00 AM   #7
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Pretty simple piece that any metal shop can bang out.
A 1 1/4" Marine Grade pipe would work well I think. Make sure they use a 306 or 316L stainless steel tubing and we often cram in a solid wood towel as well.
You might 'cheat' the install a touch out of level to compensate for the weight of the curtain. Before driving in any screws I'd have the curtain installed.
Budgetting $80 for materials and $200.00 in labour should cover it. There really is not that much work other than buffing out the weld.
If you visit a marine hardware store you could by the fittings and skip the metal shop but would have a raise fitting point at the 90.
The pipe and fittings here locally in Vancouver I source from one of three separate Marine Hardware stores. I like using the boat railings for shower curtain rods. My daughter can do chin ups on our shower curtain rod and I like the added safety that these bars do not pull off the wall like the cheap extension style.
Good Luck.
JW
JW
JohnFRWhipple is offline
Custom shower base - granite Charles_cz Tiling 16 01-08-2015 08:34 PM
Tub leaking past shower curtain when shower is on smuhhh Plumbing 8 10-21-2011 04:19 AM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 04:38 AM
Tiled shower leaks...Could use any advise at all... Jay22 Tiling 17 12-10-2008 06:15 PM
