Finding Detailed Diagrams Of COMPLEX Roofs
Old 01-06-2011, 08:47 PM   #1
Xact_Imaging's Avatar
Trade: Roofing
Question
Hey Guys!
I'm hoping you can help me with my first Question.
I need to find either blueprints or very detailed sketches of some complex roofs. Only the most complex because this really tests our abilities.
Reason: We are near completion of our new roof diagramming service and need this for testing. We have compared ours to to the major companies, but this does not garuntee accuracy; Just that we are doing it the same way as the BIG #1.
Also, if anyone cares to share... What features are the BIG companies missing that would benefit you?? Like the height from ground to roof line on the 4 corners of a home. 2 story? Downspout measurement?
Thanks
Xact_Imaging is offline
Old 01-07-2011, 08:49 PM   #2
GettingBy's Avatar
Rewards Points: 6,486
Re: Finding Detailed Diagrams Of COMPLEX Roofs
Using this
http://en.wikipedia.org/wiki/Descriptive_geometry
you can get a view from any angle of any complex or simple shape.
With the computer doing the calculations it should be easy. By hand, it's awful.
The best direction to view
Two skew lines (pipes, perhaps) in general positions in order to determine the location of their shortest connector (common perpendicular)
Two skew lines (pipes) in general positions such that their shortest connector is seen in full scale
Two skew lines in general positions such the shortest connector parallel to a given plane is seen in full scale (say, to determine the position and the dimension of the shortest connector at a constant distance from a radiating surface)
A plane surface such that a hole drilled perpendicular is seen in full scale, as if looking through the hole (say, to test for clearances with other drilled holes)
A plane equidistant from two skew lines in general positions (say, to confirm safe radiation distance?)
The shortest distance from a point to a plane (say, to locate the most economical position for bracing)
The line of intersection between two surfaces, including curved surfaces (say, for the most economical sizing of sections?)
The true size of the angle between two planes
GettingBy is offline
Tags
diagram , eagleview , geo estimator , geoestimator , measure
best book for stick building roofs JT Wood Framing 33 01-11-2011 05:41 PM
Painting Shopping complex DenverPainting Painting & Finish Work 11 02-21-2010 06:13 PM
How detailed are your contracts? healthyhomes General Discussion 19 12-24-2009 06:07 PM
How Detailed is Your Estimate? Zatol Roofing 31 11-26-2008 10:22 AM
