Building Shed Dormer / Design - Architecture & Design - Contractor Talk
Old 07-25-2017, 04:39 PM   #1
bmbcontracting's Avatar
Trade: Interior remodeling
Rewards Points: 88
Seeking some advice for bearing the load of a 30'x22' shed dormer.
The original pitch of the roof is 15/12 with 2x4 rafters. The new shed dormer is the entire length of one side of the house and will have 8' ceilings, if my math is right it will end with a 5/12 pitch.
The home own doesnt want cathedral ceilings so that raises the question if this build will need a structural ridge beam or a ridge board with upper 1/3rd collar ties and ceiling joist.
The main issue with the ridge beam we are having is that the load path in the house is not centered. There are two off set 8"x 8" railroad ties in the basement establishing the load path.
What I would like to do is run two new 6"x6" bearing post up from the basement with new footings. I am in Wisconsin so snow loads have to be considered heavily.
An engineer said sistering up floor joist on the second level under bearing ridge beam post would be sufficent because the main level bearing wall is on 13" offset from being centered.
Ill attach some rough plans. The dormer is over the bathroom area and will have 2x10 rafters. The original roof will have feathered out to 2x8 rafters. This is a 1889 Victorian house.
The pictures will be in the order:
*Basement
*Original first floor layout
*New first floor layout with opened up wall between kitchen & dinning with ridge post
*Dormer layout with LVLs. (dormer is over bath side of house)
Again since this wont be cathedral ceilings, is the ridge beam 100% necessary?
Building Shed Dormer / Design-basement.jpg   Building Shed Dormer / Design-first-floor-layout.jpg   Building Shed Dormer / Design-remodeled-first-floor.jpg   Building Shed Dormer / Design-dormer-layout.jpg
bmbcontracting is offline
Building with Adobe as a Cost Effective Solution for Home Construction? tierraconcepts Green Building 14 09-19-2015 05:52 PM
Dormer Shed Roof, Barrel Roof, CutIn Dormer, Eyebrow Dormer sbebuilders Framing 33 04-18-2013 05:29 PM
Fixing this rock shed topps Masonry 43 02-23-2013 09:56 PM
building an open wall shed off a steel building. mbobbish734 Construction 8 02-04-2013 11:07 AM
Building a shed antonioooooooo Carpentry 8 03-30-2010 06:16 AM
