Demolition A House With LEAD?
Old 03-22-2012, 11:53 AM   #1
adam477's Avatar
Trade: general contractor
Hi guys
I just bid on a job that involves gutting down a 1950 home and rebuilding a new one. Of course any home before 1978 gets special treatment. I will need to get the house tested for lead & asbestos. But considering this is an OLD house of course lead will be a major problem when demo.Even a small paint job is a hassle already considering all the extra steps that we have to do so not to get fined by the city. I can't imagine taking down a house that might be contaminated with lead. Anyone out there do their own demo or have a sub it out to a demolition company? I've demo a house before but not since the new law came out. I would save alot of money doing it myself but I don't know how to go about it...there will be alot of trash bags to consider and extra precaution. Would it be wiser to just call a demo company to take care of it for me? Any tips or advise how to do this myself would be greatly appreciated.
THank you
adam477 is offline
Old 03-22-2012, 12:46 PM   #2
Dan_Watson's Avatar
Rewards Points: 2,466
Re: Demolition A House With LEAD?
I am sure someone will come through and confirm, and you should get something in writing but I believe if the entire house is being demolished RRP does not apply.
Dan_Watson is offline
Old 03-22-2012, 01:52 PM   #3
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
That cant be right can it? if so thats makes the RRP rule even more stupid than it currently is. How they could allow a house with lead in it to be pulled down with zero containment but you cant change a window without a **** load of work to contain the lead
www.bcconstructionllc.com
BCConstruction is offline
Old 03-22-2012, 03:16 PM   #4
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 68
Demoing the entire building & building new doesn't count under the RRP - remember RRP only covers renovations, repairs & painting & is essentialy to protect the occupants only
SLSTech is offline
Old 03-22-2012, 03:42 PM   #5
VinylHanger's Avatar
Rewards Points: 7,278
What he said.
VinylHanger is online now
Old 03-22-2012, 05:01 PM   #6
The Sheriff
Jaws's Avatar
Rewards Points: 4,358
Inspectors here want to see precation taken for demoing a house with lead. Meaning a lead test . Demoed a 70 year old house for a boat ramp recently . It was negative, I showed results to inspectors office. If positive, a tent??? Or what?
Jaws is offline
Old 03-22-2012, 08:12 PM   #7
Palisade Point Const.
TempestV's Avatar
Rewards Points: 1,632
They are worried about distributing lead dust around the house, where children might come in contact with it. When you haul off the whole house, then you don't have to worry about dust inside the house anymore.
Now, if you are just gutting the house and not completely removing it, then RRP becomes an issue, even if you are gutting it to bare framing.
If you had to follow RRP on a complete demo, I would think it would be the exterior of the house that you would have to protect. Everything inside the footprint gets hauled away, but stuff could fall into the yard, and leave behind dust. You could set the job up just the way you would if you were removing lead painted siding, and that would probably cover it.
TempestV is offline
Old 03-22-2012, 08:35 PM   #8
bconley's Avatar
Trade: Kitchen and bath design+remodel
Typically you do have to have pre demo asbestos survey so you can dump.
bconley is offline
Old 03-22-2012, 09:54 PM   #9
adam477's Avatar
thanks for your help guys...i would prolly do the job myself to save some money i know if i sub it out it could easily be 10k + here. To make things more difficult its a stucco house so more precautions. I guess I'll never know the extent of it til I get it tested. I don't know about different areas but here I will need to do the recycle thing with the city. Application where i have to determine what and how much i will be recycling, keep all the receipts and show to the city after all is done or pay a fine. If I rent a dumpster, they'll just throw everything in together and not separate it.
adam477 is offline
Old 03-22-2012, 09:59 PM   #10
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Thats good advice.
ohiohomedoctor is offline
Old 03-23-2012, 06:42 AM   #11
Aframe's Avatar
Trade: Carpenter/GC
Rewards Points: 550
That was probably due to proximity to water. Just guessing
Aframe is offline
Old 03-26-2012, 06:29 PM   #12
FStephenMasek's Avatar
Trade: helping people avoid problems with toxic materials
Rewards Points: 268
Where are you located?
The lead inspection for that project will be needed for OSHA compliance, and will show what waste needs to be "profiled" for proper disposal.
An asbestos survey will also be needed.
There may not be all that much lead. The oldest residential building we've inspected with no LBP was built in the middle-1950s.
President Masek Consulting Services, Inc. http://www.masekconsulting.net
FStephenMasek is offline
Old 03-28-2012, 09:13 AM   #13
adam477's Avatar
I am in california..
Wow hopefully i am lucky and the the test would come out negative..
I am in the process of getting quotes for the tests... So far the price range from $900 to 1,600 just for asbestos. N lead would cost additional 600.
I wonder can i buy the kit n have test it myself ?
adam477 is offline
Old 03-28-2012, 06:49 PM   #14
Rewards Points: 268
Originally Posted by adam477 View Post
I am in california..I wonder can i buy the kit n have test it myself ?
You can not test it yourself - California has had a certification for lead inspectors/risk assessors since 1993, and one of them needs to do it. I see that you are in Oakland. Prices for consulting in the SF Bay area are substantially higher than in southern California. Perhaps due to the higher cost of housing?
Old 04-04-2012, 06:19 PM   #15
adam477's Avatar
Update guys..I got the asbestos/lead report and unfortunately lead is found above OSHA level but not EPA...but yahoo no asbestos.
Lead-Based Paint:
Chip samples were collected of the various paints scheduled for disturbance to
determine risk potential and OSHA compliance for demolition purposes. Four (4)
various paints were identified as representative, recognizing that samples may be
multi-layered:
Sample Location Color % lead EPA lead? OSHA lead?
L101 Interior wall (drywall) Yellow 0.017% No Yes
L102 Interior trim (wood) White 0.067% No Yes
L103 Exterior wall (wood) Yellow <0.006% No No
L104 Exterior trim (wood) Blue/grey <0.006% No No
None of the paints were found to be above the EPA definition of lead-based paint.
Two were above the laboratory detection limit, and therefore are above the Cal-OSHA
level of detectable lead content. Contractors should be advised of the lead content of
adam477 is offline
Old 04-10-2012, 07:22 PM   #16
Rewards Points: 268
1) You did not get a real lead-based paint survey if you got just scrape samples! Where was their XRF?
2) What about ceramic tile glazes which may contain lead? If any is present, it should have been tested.
3) The main issue with OSHA and levels above zero, but below 1.0 mg/cm2, is exposure assessment. Buy a personal pump and a box of lead air sample cassettes (total $300), run samples every now and then by worker category (training, task) and material, and keep the data organized. The samples are analyzed by a laboratory (non-rush $8 each). Then read the Cal-OSHA regulations.
EPA Backs Off Lab Testing for Lead greg24k General Discussion 3 09-28-2011 06:17 AM
Job site meeting / weekend house Gus Dering Carpentry 22 05-27-2011 07:39 PM
Floating house, house floats up during hurricane medusa General Discussion 62 01-03-2011 07:08 PM
Flaking lead paint in an unused room: how dangerous to rest of house? LetItBeLEED Painting & Finish Work 6 07-25-2009 06:33 AM
Lead base paint removal wood house. welovepainting Painting & Finish Work Picture Post 10 08-25-2007 02:31 AM
