In Your Opinion
Old 06-19-2009, 09:46 PM   #1
MikeReynolds's Avatar
Trade: residential and commercial construction
In Your Opinion
121499.1 If you had to put a harwood floor down, which way would you run it? Lets say that there is a full window wall on the south side and the dbl door on the north side. No other windows in the room at all with indirect light.
North-South or East-West and why?
I didnt put this in flooring because I wanted a broader range of answers from contractors as well as installers.
MikeReynolds is offline
Old 06-19-2009, 09:54 PM   #2
genecarp's Avatar
Re: In Your Opinion
As a rule i run perpendicular to the floor joists, that being said if conditions dictate going with the FJ, i will.G
genecarp is offline
Old 06-19-2009, 09:56 PM   #3
Re: In Your Opinion
Oh, sorry its a slab on grade so that wouldnt be a factor.
Old 06-19-2009, 10:00 PM   #4
LRG WoodCrafting
Leo G's Avatar
Re: In Your Opinion
I'd run it with the length of the room. You gonna tell me it's a square room?
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 06-19-2009, 10:01 PM   #5
KemoSabe
loneframer's Avatar
Re: In Your Opinion
Typically, perpendicular to the joists, but certain field conditions will over-rule. I like the boards to run in line with the longest distance. I hate long hallways with short boards across them.
loneframer is offline
Old 06-19-2009, 10:07 PM   #6
tgeb's Avatar
Re: In Your Opinion
I like it on the diagonal.
www.gebcon.com
tgeb is offline
Old 06-19-2009, 10:10 PM   #7
Re: In Your Opinion
No, its actually 8" longer East to west. But kinda square, at least to the eyes.
Old 06-19-2009, 10:11 PM   #8
KemoSabe
loneframer's Avatar
Re: In Your Opinion
Run it parallel to the door wall.
Old 06-19-2009, 10:24 PM   #9
Re: In Your Opinion
Actually I do too but in this case it wont factor in.
OK, lets drop the pretense and let me tell yall my rant.Years ago I had an old timer tell me that whenever possible run the floor with the direction of daylight. His reasoning was that any imperfections would blend in with the light and soften them. The seams are often invisible too if installed right.
Since then I have heard of installers who prefer to run from the main doorway perpendicular to make the room seem larger. When conditions allow of course. These rooms in question (52 of them) follow both patterns and they are slab on grade so joists are not a factor.
So. Lets rewind back to Jan. when I got a picture from the archy (I'll use that term loosely in this case) that showed just exactly that same orientation. When we had 6 rooms installed (with epoxy as spec'd of course) she wanted them torn out and turned the other way. Epoxy is not easy to get off either.
She said " Dont look at the pictures."
I said "Then why send them to me?"
To make matters worse I did a minor change to the exterior in Feb. and she wanted to know why it wasnt like her picture.
I was just wondering what yall thought about it.
Old 06-19-2009, 10:29 PM   #10
LRG WoodCrafting
Leo G's Avatar
Re: In Your Opinion
She's a looney woman who doesn't know what she likes until she sees something she doesn't like.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 06-19-2009, 10:32 PM   #11
KemoSabe
loneframer's Avatar
Re: In Your Opinion
She's a typical woman who doesn't know what she likes until she sees something she doesn't like.
Old 06-19-2009, 10:42 PM   #12
LRG WoodCrafting
Leo G's Avatar
Re: In Your Opinion
typical/looney woman, what's the difference? They talk about 1/2 shades of color, nit pik at things even the most anal woodworker doesn't care about and won't let it go ---- ever.
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 06-19-2009, 10:54 PM   #13
Re: In Your Opinion
This is the same archy that wanted me to put an 88" door in 88 1/4" of hallway. She had said if I was good enough I could do it. I told her sure I can. I'll just block behind the SR and screw the hinges to the block through the SR. Who needs a jamb anyway. Its only a waste of money. I probably didnt set the right tone from the get-go but she started it when she said IF I was good enough.
I'm usually fairly tactfull too.
need 2nd opinion on exterior stair trim issue jordanski Finish Carpentry 1 03-15-2009 05:15 AM
First Custom Made Vent...Opinion jcalvin Flooring 17 03-13-2009 07:38 AM
Want the Plumbers to give an opinion kycontractor Plumbing 0 02-20-2009 12:23 AM
What's your opinion? bert0168 Marketing & Sales 8 11-04-2008 06:17 PM
Your Opinion - Shake Conversion parkerfairfield Roofing 5 08-14-2008 07:36 PM
