Window Replacement On Slate Roof
Old 03-06-2018, 09:36 PM   #1
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 748
How would you guys do this? Iíve never had to work on a slate roof before. I know there are ladders you can hang from the ridge and such but those arenít useful here.
The scope of work is to cut the stucco all the way around the window for the new trim, pull the existing window, modify the opening as needed, flash and install a new window.
I just canít see doing that all from inside leaning out the opening...
Xtrememtnbiker is online now
Old 03-06-2018, 09:41 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 892
Re: Window Replacement On Slate Roof
I would probably put down some low density white styrofoam sheets and then some osb on that. Put some 2x in the spouting to keep it all from sliding.
Sent from my SM-T310 using Tapatalk
overanalyze is online now
Xtrememtnbiker (03-06-2018)
Old 03-06-2018, 10:31 PM   #3
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 11,192
https://www.amazon.com/gp/aw/d/B0102...uNL&ref=plSrch
A&E Exteriors is offline
Old 03-07-2018, 08:52 AM   #4
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,102
couple of ply wood sheets with foam glued to them... the foam will keep the sheets in place.
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 03-07-2018, 07:42 PM   #5
Rewards Points: 748
Thanks guys. Seeing as this starts tomorrow, foam and plywood it is.
Old 03-07-2018, 08:17 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,047
Starting a funky job on a Friday... Bless you, my son.
Tinstaafl is offline
overanalyze (03-07-2018)
Old 03-07-2018, 08:21 PM   #7
Rewards Points: 748
Sucks getting old huh pops? The days start to run together...
Yes, I confirmed it's Wednesday before saying that.
If all goes well, the guys replace that window and another one plus paint some columns. Hopefully I'm not being too optimistic...
Old 03-07-2018, 08:24 PM   #8
Capra aegagrus
Tinstaafl's Avatar
Old 03-07-2018, 08:27 PM   #9
tgeb's Avatar
Rewards Points: 926
Uhmm tomorrow is Thursday Goatman, but if you insist...tomorrow is payday, drinks on tinstaafl.
www.gebcon.com
tgeb is offline
The Following User Says Thank You to tgeb For This Useful Post:
Tinstaafl (03-07-2018)
Old 03-07-2018, 08:30 PM   #10
Always Learning
Rewards Points: 892
As I thanked this post I looked at the date and thought wait...tomorrow isn't Friday.
Sent from my VS988 using Tapatalk
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
Tinstaafl (03-07-2018), Xtrememtnbiker (03-07-2018)
Old 03-07-2018, 08:50 PM   #11
Radical Basement Dweller
Robie's Avatar
Rewards Points: 11,382
Don't forget....the clocks get set ahead one hour tonight.
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is offline
Old 03-07-2018, 08:57 PM   #12
Always Learning
Rewards Points: 892
Now that's funny...mean..but funny!
Robie (03-07-2018)
Old 03-07-2018, 09:40 PM   #13
MTRmatt's Avatar
Rewards Points: 4
That roof slate looks brittle and cracked already. Did you plan on replacing any slates? Usually i use a homemade wooden chicken ladder with foam under and then roof jacks, plywood, or planks can get screwed to them. Never liked the metal one as they get uncomfortable kneeling sitting laying on.
MTRmatt is offline
Roof Framer's Bible Framing A Bay Window Roof sbebuilders Framing 25 06-28-2015 08:28 PM
Working on my own roof red_cedar Roofing Picture Post 18 10-18-2013 06:47 PM
flat roof wide open and building flooded madrina Roofing 43 05-29-2013 08:11 AM
90 yr old window replacement? coworx Windows, Siding and Doors 3 04-26-2013 09:36 PM
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 09:50 AM
