Window Experts
Old 07-30-2009, 11:13 PM   #1
HomerJ's Avatar
Trade: Remodeling Specialist - General Contractor
Window Experts
I have a client who's insisting we somehow insulate the bottom of this window because it's exposed to the exterior elements.
http://web.pella.com/products/window...etailpage.aspx
(Pella bow window with 5 casements. Unfinished wood interior with enduraclad white aluminum exterior and plywood bottom. Width is approx. 110")
He believes it's silly to buy a new window to increase energy efficiency, and not insulate the bottom of it
There's nothing in the installation instructions about insulating the bottom. All the other instructions have been followed to the letter.
http://web.pella.com/products/instal...s2009/80AT.pdf
He suggested covering the plywood bottom with 1/2 insulation sheating. (the pink stuff) then covering the bottom with aluminum. I think that could interfere with the frame expander and cause water to collect inside.
We built wooden knee braces to help support the window along with the cables. We were going to wrap those with aluminum, then insultate and wrap the rest as stated in the installation instructions.
Would you instulate the bottom of this window, and if so, how?
HomerJ is offline
Old 07-30-2009, 11:38 PM   #2
Official CT Greeter!
CScalf's Avatar
Trade: General Construction
Re: Window Experts
I wouldn't do anything unless pella says to do it, call them and see what they say, if something goes wrong you will be liable for it, I would just tell harry homeowner that you can only perform a proper installation by following the guidelines set forth by the manufacturer of the said window.
that should shut him up, if not buy a ball gag...
"Your problem does not constitute an emergency on my part"
CScalf is offline
Old 07-30-2009, 11:40 PM   #3
oldfrt's Avatar
Re: Window Experts
I've done quite a few bays and bows and found that the best way to finish the bottom is to frame a return underneath for support and insulation purposes.
I don't trust the cable systems and ,but will use them in conjunction with the framing method.
It's costly and time consuming,but overall,the safest way to go.
oldfrt is offline
Old 07-31-2009, 12:38 AM   #4
Tom Struble's Avatar
Trade: siding
Re: Window Experts
so if you do nothing theres just exposed ply wood?
i insulate and cover the bottoms of those kinds of windows all the time,never had a moisture problem
Tom Struble is offline
Old 07-31-2009, 08:32 AM   #5
President
Jake Stevens's Avatar
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
Re: Window Experts
We install about 20 or more bow and bay windows a year and we always insulate under the window. We use a 1 1/2" Blueboard with a 2" X 4" set in about 1" from the edge of the window so to have something to nail our trim on and a 2" X 4" up against the house to nail on.
Note; We rip the 2" X 4" in half
Jake Stevens is offline
Old 07-31-2009, 09:17 AM   #6
Al Smith
A W Smith's Avatar
Re: Window Experts
Don't know about Pella's but the Andersen's have a void between the finished grade seat board and the rough cdx bottom that you are supposed to insulate. However. Providing what is essentially an insulated shelf with knee brackets for your window to sit on should not void any warranty. As far as the cable system goes. They come with the window. and are adjustable If you throw the kit out expect call backs for stuck casement flankers. I have seen scores of effed up bays improperly installed by "contractors" who thought they were engineers and knew better.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 07-31-2009, 09:22 AM   #7
HomerJ's Avatar
Re: Window Experts
I can see the value in insulating the bottom, and we won't leave him with exposed plywood.
However, the factory supplied frame expander doesn't extend low enough to cover 1/2 sheathing, or any additional framing.
Looks like we'll have to build a frame underneath to accomodate the insulation as some have suggested.
In order to do that, we'll have to wrap that framing with aluminum, and caulk the edges where it meets the factory supplied frame expander.
Thanks for the input.
HomerJ is offline
Old 07-31-2009, 09:34 AM   #8
DavidC
DavidC's Avatar
Re: Window Experts
We insulate under ours with double 3/4" dow board and cover with coil stock. Knee brackets go solid to the ply bottom and insulation trimmed around them.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 07-31-2009, 09:58 AM   #9
thermax's Avatar
Trade: windows and siding
Re: Window Experts
who not just order an insulated seatboard?
thermax is offline
Old 07-31-2009, 10:06 AM   #10
Al Smith
A W Smith's Avatar
Re: Window Experts
I gotta say, that's one ugly ass dog in the Thermo Tite window banner ad at the bottom of this page. That is a dog. right?
Al Smith
Old 08-01-2009, 07:57 AM   #11
Trade: siding
Re: Window Experts
you could step the framing for the bottom back alittle to give you a place to seal the trim to the window cladding
Old 08-01-2009, 02:20 PM   #12
HomerJ's Avatar
Re: Window Experts
Yes. This is how we're going to handle it.
Thanks again to all for their input.
HomerJ is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
12 foot Bow window leaking jkfox624 Carpentry 12 06-21-2009 11:17 AM
Window insida Tile Shower orson Remodeling 13 12-24-2008 10:45 PM
Reno Window Screw Up Bummie Windows, Siding and Doors 15 12-22-2008 10:33 PM
