When Trees Were Trees
Old 03-31-2008, 05:37 PM   #1
DavidC
DavidC's Avatar
It's not the first time I've seen it. In fact it's fairly common around here. But this time it is in my house and I had time to just look at it and be awed a little.
Doing a kitchen remodel for the wifey. Stripped a wall that used to be the exterior of the original house, built around 1865. Since then the house has been added on enough to engulf most of the original structure.
I think this type of construction was called plank construction. Basically slabs of trees are stood up side by side and another row offset on the other side. Each slab is full 2" thick, making a 4" nearly solid wood wall. And they all go from foundation to eaves.
The one that really caught my eye is 21" wide with no bark edges. I mused for awhile thinking how that plank came from inside a tree, probably the product of a saw pit. The house being as old as it is, is predated by the amount of time required to grow trees that size. That board was likely a sapling before the Revolution.
One thought was to salvage that board and make something out of it to display in the house. Then I realized I would be to intimidated to saw it down.
Good Luck
DavidC is offline
Old 03-31-2008, 05:53 PM   #2
bobdog's Avatar
Trade: master plumber
Re: When Trees Were Trees
I go ga-ga over a 15"or 16" board. I cant imagine a 21".Are the growth rings compact or "wide"?
bobdog is offline
Old 03-31-2008, 07:16 PM   #3
Bet the rings are tight....
and I'd bet it was already a
good sized tree way before
the Revolutionary War!
neolitic is offline
Old 03-31-2008, 07:26 PM   #4
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
I salvage this kind of stuff any time I can get my hands on it I found several 27" wide boards on a preservation job I did a few years back. They were about 6' or 7' feet long. When I got them home and cleaned them up, I found they were Oak. I made some nice stuff with those boards, beat the st out of a set of planer blades though.
I've never seen the type of wall construction you're talking about. Any pic's?
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 03-31-2008, 07:39 PM   #5
"Palisade" is the word that comes to mind,
but I'm sure there is another term for it...
Maybe later when I'm not thinking.
neolitic is offline
Old 03-31-2008, 07:52 PM   #6
Morning Wood's Avatar
Trade: Pretty much anything with wood
Cool. But tough to insulate.
Morning Wood is offline
Old 03-31-2008, 07:56 PM   #7
DavidC
DavidC's Avatar
When we first moved in I set up the laundry here for the misses. I had already figured out the construction technique when I tried to insulate the walls with cellulose. But I couldn't figure out why there was no meat to anchor the pipes to the wall until yesterday.
[IMG]file:///C:/My%20Documents/My%20Pictures/2008-03-31/DCP_0002.JPG[/IMG]
I tried everywhere except the center of the opening for the original back door.
Here is the section with the 21" plank. Aside from this there are 2 at 17" and another at 16".
[IMG]file:///C:/My%20Documents/My%20Pictures/2008-03-31/DCP_0003.JPG[/IMG]
21" 17"
According to my wife's Dad a back porch was here originally. I'm guessing it was closed in because they had plastered.
I can't say about the rings until I cut some out. The plan is to widen an opening to about the right side of this pic. There won't be much of interest to salvage unless I can't resist.
For this type of construction they set another row of planks on the other side, offsetting the gaps. Some gaps are small enough to make me beleive they are just shrinkage but some are a couple of inches elsewhere.
Good Luck
DavidC is offline
Old 03-31-2008, 08:08 PM   #8
Teetorbilt's Avatar
I have done a few old FL homes where there were true 2X4's. The exterior walls were 3/4" on the diag and 3/4" horizontal siding. The interior walls were 3/4" diag. opposite to the exterior with 3/4" vertical panelling. Everything is Dade County pine which is harder than a whores heart. Small wonder that they're still around. Even the termites find better feeding grounds.
Albert Einstein
Teetorbilt is offline
Old 03-31-2008, 08:13 PM   #9
DavidC
DavidC's Avatar
Currently seeking advice on how to post pics.
Good Luck
DavidC is offline
Old 03-31-2008, 08:19 PM   #10
Restoration Crazy
Good Luck
This should do it. PM me if you need some more help.
http://www.contractortalk.com/f45/how-attach-photo-post-6001/
Facebook | Twitter
Old 03-31-2008, 09:04 PM   #11
Moderator
Double-A's Avatar
Here is another.
http://www.contractortalk.com/f45/how-post-picture-image-36658/
New York Times, July 20, 2006
Double-A is offline
Old 03-31-2008, 10:20 PM   #12
cleveman's Avatar
Trade: custom home building
What if you click on "manage attachments" and nothing ever happens?
cleveman is offline
Old 03-31-2008, 10:29 PM   #13
Palisade Point Const.
TempestV's Avatar
I tore down an old grainery last summer that had some 25" wide boards used for plank siding. That's the largest I've ever seen.
TempestV is offline
Old 04-01-2008, 09:43 AM   #14
still learnin'
dutchlegacy's Avatar
Trade: General Contracting
the coolest find I've had so far was on a tear-down here in Ohio. We opened up the walls to find true 2x4 wormy-chestnut studs. I almost peed my pants when the HO said I could have them. The gables were 5/4 material, stacked one on top of the other from ceiling to gable peak. I still have the stuff, and was thinking about making some flooring out of it one day.
dutchlegacy is offline
Planting Trees daworz Landscaping 8 04-24-2007 06:57 PM
Help:what trees or srubs you recomended? milos Landscaping 1 03-25-2007 07:25 PM
moving apple trees calypso Landscaping 15 02-20-2007 01:08 PM
Trees Cole Landscaping 7 03-09-2006 10:47 AM
Queen Palm Trees Nathan Landscaping 3 12-11-2003 02:16 PM
