When Was This House Built??? - General Discussion - Contractor Talk
Old 01-15-2013, 09:01 AM   #1
tjfslaughter's Avatar
Trade: ducting
I am trying to figure out how old my house is. The town does not have a firm idea. They have it documented as 1927. Here are some facts:
1. It had gas lights throughout
2. At one point the gas lines were shut off and knob and tube was installed (the old gas lines were used to hold the new electric lamps)
3. There is chesnut mouldings throughout
4. Not balloon framed
5. Plaster walls with no metal lathe
6. Colonial Victorian in Maywood NJ
7. No heating oil tank
8. Forced hot air
I have tried to research this, the first census I have is in the 40's and Ironically I have met the grandson of that owner. I appreciate the help.
tjfslaughter is offline
Old 01-15-2013, 09:35 AM   #2
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,740
Re: When Was This House Built???
You may want to post some pictures. Some of the architectural details may offer some clues. Knob and Tube could date the conversion from anywhere from 1880 to 1930, but I don't think interior gas lighting was much earlier. 1850's to 1920's maybe?
Rustbucket is online now
Old 01-15-2013, 10:06 AM   #3
Trade: ducting
Here are a couple pics
When was this house built???-fireplace.jpg   When was this house built???-img_0427.jpg   When was this house built???-img_0444.jpg   When was this house built???-img_0870.jpg
Old 01-15-2013, 10:31 PM   #4
LCG's Avatar
Trade: Roofing/Siding/Seamless
Rewards Points: 272
1927 looks about right.
I say this because I have inspected at least 80-100 homes that were built between 1890 and 1940. Most of the homes that I inspected still had coal shoots. Some still had piles of coal, some had oil tanks, etc.
Looking at your pictures I would say that the 1927 mark looks to be pretty acurate.
LCG is offline
Old 01-15-2013, 10:47 PM   #5
slowsol's Avatar
Rewards Points: 2,234
My first thought was that the 1927 seems reasonable.
-John
slowsol is offline
Old 01-15-2013, 10:48 PM   #6
Trade: ducting
I talked to neighbor, he said his house was built in 1910 an his house was built after mine based on survey's and old title info.
Old 01-15-2013, 11:03 PM   #7
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Of say 1890 to 1910. The house I'm working on now is a 1850 and the gas lines were put in after it was build
jlsconstruction is offline
Old 01-15-2013, 11:04 PM   #8
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
the original house may have burned down, and the replacement built in '27
I have a home built in 1877 according to the deed, but I can tell it's not original...
-Steve
TimelessQuality is offline
Old 01-16-2013, 09:16 AM   #9
Trade: ducting
I am going to reach out to the local historical board.
Our First house was build on the old location for the fire house hourse stables. The barn for the horses was taken down and the beams used were re purposed as my sill plates and beams...
Old 01-17-2013, 08:37 PM   #10
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
When I was in school, one of the things we had to do was research an old property. One of the tricks is to look at deeds of sale and look for significant jump in value, meaning that a lot had a building erected.
The fact that it isn't balloon framed makes me think that it is later than 1920, unless it's timber framed with the interior walls being 2x material.
www.dominionmasonry.ca
dom-mas is offline
Old 01-17-2013, 08:56 PM   #11
rrk's Avatar
Rewards Points: 2,794
Looking at the picture it is balloon framed , no bottom plate at the floor
rrk is online now
The Following 4 Users Say Thank You to rrk For This Useful Post:
glkirk (01-21-2013), hdavis (01-22-2013), WarnerConstInc. (01-17-2013)
Old 01-21-2013, 08:49 AM   #12
Trade: ducting
Its not balooned framed. Between the first floor and second and second and attic there is a pair of full 2x4's between the studs.
The goofy thing is that the first floor studs do not line up with the second floor.. Its all full 2x4 4x4 6x4 construction. The corners of the house are 6x4.
Old 01-21-2013, 10:04 AM   #13
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Are the 2x4's not ledgers for the floor system to sit on? If not how is the floor system attached?
It sounds like a vernacular build. Built however the builder thought was best. I remember an historical preservationist once saying that using a building style to date a building is pretty vague because maybe an older homeowner built it and used the methods he'd seen used as a kid. Or a style was revered by a builder because it's how his father built and he wasn't going to change what worked etc....
I would say that a building being balloon framed can give you a range of 1850's to 1940's but the fact that it isn't balloon framed doesn't help to narrow the date unless it's platform framed
dom-mas is offline
Old 01-21-2013, 10:31 AM   #14
Trade: ducting
I attached an image. I have already padded out the walls to 5.5". As you can see the floor joist (for the attic) are sitting on top of 2- 2x4's but there is no band joist. Its the same way between the first and second floor.
I really appreciate everybody's input. I added a crappy cell phone pic of the stairs. The post is solid Chesnut (need to start sanding on it...)
When was this house built???-houseframing.jpg   When was this house built???-stairs.jpg
Old 01-21-2013, 10:49 AM   #15
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Man.... I love those floors.
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
Old 01-21-2013, 10:55 AM   #16
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
The newel posts scream 192o's to me
there's another wall system on top of that floor you showed the pix for?
dom-mas is offline
Old 01-21-2013, 11:05 AM   #17
Trade: ducting
Both the second and attic floor uses the same system. The subfloor is tongue and groove heart pine. Maybe the poster that said the house was rebuilt in 1927 may be onto something...
Old 01-21-2013, 11:11 AM   #18
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
tongue and groove. I'm guessing laid on the diagonal?
An aquaintance of mine was into architectural salvage and some of his biggest selling stuff was actually old subfloor and wall planking, 25'+ lengths, pine. He'd sell it to restaurants who wanted a southwest feeling.
dom-mas is offline
Old 01-21-2013, 11:15 AM   #19
Trade: ducting
not diagonal on the floor. The sheathing is diagonal...
Old 01-21-2013, 11:20 AM   #20
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Really? i'd say that 90% of the subfloors I've seen from the 1890's-1940's were laid diagonally. Rarely see the wall sheathing diagonally.
I'm also surprised that there is only an exterior layer of wall sheathing, typically I see an inner and outer. Easy to hang pictures so long as the fastener is long enough to go through plaster, lath and furring strips
I've only done work in the Ottawa area though
dom-mas is offline
Flip this house still a joke BCConstruction General Discussion 9 09-01-2012 12:55 PM
Pipes to Attic? Old House Mystery. JRSeifert General Discussion 20 10-15-2011 05:15 PM
Extreme Makeover House Bergstrom Finish Carpentry 6 10-10-2009 10:49 AM
Haunted house Michaeljp86 General Discussion 7 06-20-2009 12:49 AM
The House of Tomorrow from the Recession Today NC2X4 General Discussion 11 02-28-2009 05:05 PM
