What Winter Boots You Use When Work Outside?
Old 10-28-2017, 05:18 PM   #1
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,437
I use "Kamik nationplus" 200g. For around town I have Bugaboot 200g.
Kamik serve me well to 20F when work outside. However just worked at my car in 33F and get frost bite. Didn't move clearly because was working at timing belt. Across internet for walking job in very cold weather they recommend 600g boots. Insulation obviously is trade with ability to move easy.
tipitop is offline
Old 10-28-2017, 05:46 PM   #2
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,678
Re: What Winter Boots You Use When Work Outside?
When I was an auto tech, I found a mat or even cardboard under my feet in the winter helped my feet stay warmer, when standing in the same spot. Of course that is in Cali and a cold shop would be 50* Fahrenheit, before the heater warmed things up.
For cold days spent treking I have a pair of Cabela's Miendl 800gram boots. They work great for hiking in the woods, even while wearing snow shoes.
Usually though I just wear a pair of hiking boots and thick socks. Good to 20* if I stay moving. Also have a pair of Neoprene Muck Boots for wet conditions.
Peter_C is offline
Old 10-28-2017, 06:03 PM   #3
Bull Trout's Avatar
Rewards Points: 1,024
I'm a little concerned with how clearly I understood tipi without Mike translating
I find the problem with insulated boots is they make my feet sweat, and once I stop moving or slow down the moisture becomes cold, and then my feet get cold. I use sock layers to regulate foot temperature, for me two layers a light weight merino wool sock under a heavy weight merino wool in leather boots with a gortex liner keeps my feet dry and warm to about -10, if I'm not going to be moving much, or exposed to more wind, ill do a mid weight under a heavy weight.
Bull Trout is online now
Old 10-28-2017, 06:11 PM   #4
FrankSmith's Avatar
Rewards Points: 4,620
800 gram Rocky boots. Unless I a sitting or on a plank my feet are never cold. They aren't too bulky either.
FrankSmith is offline
Old 10-28-2017, 07:14 PM   #5
Hack
asevereid's Avatar
Rewards Points: 604
KEEN Abitibi, thermal lined. Good for me to minus 25c...with the right socks.
Sent from my SM-G530W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 10-28-2017, 08:10 PM   #6
tipitop's Avatar
Trade: carpenter
Worth try it. I tried past year cabelas 1200g. Definitely not handy for walking.
tipitop is offline
Old 10-28-2017, 08:59 PM   #7
LRG WoodCrafting
Leo G's Avatar
Trade: Woodworker Extraordinaire
Rewards Points: 11,595
I try my best not to work outside in the winter. Only work done is snow blowing. Just wear my steel toed work boots. Always warm enough for 2 hours.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 10-28-2017, 10:18 PM   #8
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
I'm with leo I move inside when it gets cold got a customer dragging their feet on an outside CCTV job which I want to get off the books before it gets too cold.
I find doubling up socks can help
Sent from my XP7700 using Tapatalk
SectorSecurity is offline
Old 10-29-2017, 03:35 AM   #9
Safety Third
shanewreckd's Avatar
Trade: Concrete Carpenter. Concreepenter? Carpencrete?
Rewards Points: 196
I wear these Dakota's. They're rated to -100C. I've worn them comfortably down to about -40 or so. They're heavy as hell on your feet but I haven't found anything that'll keep me warmer up here
shanewreckd is offline
The Following User Says Thank You to shanewreckd For This Useful Post:
asevereid (10-29-2017)
Old 10-29-2017, 05:22 AM   #10
builditguy's Avatar
Rewards Points: 406
I'll have to admit. I clicked because it was Tipi. Love his posts. Like a crossword. A challenge.
Since I'm not in Minnesota, I can't really add any input.
I will say. 26 degrees right now. I always wear the same boots. Non-insulated Thorogood, now. Was RedWing, but since Thorogood are made in USA, now, Thorogood.
I'm sure I don't see the temps you see in Minnesota.
My feet get hot in non-insulated, so no insulated for me.
builditguy is offline
Old 11-01-2017, 09:42 PM   #11
Master Mason
RacinMason's Avatar
Trade: Masonry
Rewards Points: 110
I've always had god luck with Redwing boots, plus they're comfy right out of the box.
650cc on the track
800cc on the snow
1000cc on the street
RacinMason is offline
Old 11-01-2017, 11:15 PM   #12
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,244
Merrell lowcut running shoes. If that won't keep me warm then I go where its heated. Solves a lot of problems in my world. It took 18 years of construction to figure that out though.
Anthill is offline
The Following User Says Thank You to Anthill For This Useful Post:
jhark123 (11-02-2017)
Old 11-02-2017, 09:11 AM   #13
Fishindude's Avatar
Trade: Industrial
Rewards Points: 396
We don't get much of the extreme cold in the midwest. Rubber slip overs, over my standard red wing work boots do the trick in most instances, and it's nice to take them off and have clean leather boots to get in the vehicle at days end.
Fishindude is offline
Old 11-03-2017, 08:08 PM   #14
PlumbersDenver's Avatar
Trade: Plumbing, Heating & Air Conditioning
Rewards Points: 12
My go to are the Chippewa Bay Apache Waterproof & Insulated 8" Lace-Up Work Boots from Sheplers
PlumbersDenver is offline
Old 01-04-2018, 08:18 PM   #15
tipitop's Avatar
Trade: carpenter
Well my choice went to baffin impact. My big smile say everything, South St Paul 1/4/18 10 am -5F. Worth to notice my 400 g prima loft under armor jacket https://www.amazon.com/Under-Armour-.../dp/B00E8YD83K
Smail was helped by yard worker who suppose to help me instead just jump at top of his toes all time.
tipitop is offline
Old 01-04-2018, 08:26 PM   #16
Radical Basement Dweller
Robie's Avatar
Rewards Points: 11,532
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is online now
Old 01-04-2018, 08:27 PM   #17
Robie's Avatar
For cold weather and a little snow, my L.L. Bean's fleece lined zip up 10" boots.
For today's blizzard weather, Wolverine's rubber and leather boot with Thinsulate lining.
Robie is online now
Old 01-04-2018, 08:29 PM   #18
Robie's Avatar
Great ultra-cold boot...
Robie is online now
Old 01-04-2018, 08:29 PM   #19
tipitop's Avatar
Trade: carpenter
^^^ My line of thinking was it is rated to -100c it can not miss. And it is about right.
tipitop is offline
Old 01-04-2018, 08:45 PM   #20
LRG WoodCrafting
Leo G's Avatar
I just wear my Timberland Steel Toed workboots. Kept me more than warm enough for the 2 hours I was out taking care of the snow. I really need to find a pair of work gloves that will allow my my dexterity and keep me warm. So thin, tight fitting and warm. Not something easily accomplished.
Carpenter by day.
http://lrgwood.com
Leo G is online now
Scope of work CarpenterSFO General Discussion 20 11-03-2014 07:27 PM
Non union jobsite (quaker church)vandalized in philadelphia $500,000 Damage mastersplinter Carpentry 41 04-19-2013 01:06 AM
Winter work........ MO_Blast_Momma Sandblasting 7 12-07-2010 07:36 AM
Prepping for outdoor work...winter Eric S Tools & Equipment 32 09-27-2009 08:40 PM
