What Is This Stuff & How Do You Hang On It?
Old 05-03-2009, 08:34 AM   #1
stp57's Avatar
Trade: carpenter/ handyman
I have one marketing customer that has me hang banners at credit unions. I have been running into this problem lately at the new branches where the exterior walls seem to be made of a foamboard covered over with stucco or kind of plaster texture? My anchors are pretty useless in this stuff. I am afraid to use toggle bolts because what if they rip out a large hole under stress & how would you patch it?
I have also had to deal with some paper thin columns that also seem to be a plaster over very thin fiberglass. All I can do is cement an anchor in and come back later. Some of my out of town jobs make that difficult. Someone please fill me in on the construction of this crap?
Steve
stp57 is offline
Old 05-03-2009, 08:45 AM   #2
KentWhitten's Avatar
Re: What Is This Stuff & How Do You Hang On It?
First description sounds like Dryvit. Not sure of an answer for you.
Salmon Falls Cabinetry
KentWhitten is offline
Old 05-03-2009, 08:57 AM   #3
And I do electrical, too!
480sparky's Avatar
Steve
Click here.
Google EIFS and you'll find tons of info on it. Dryvit is one brand of it.
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 05-03-2009, 09:01 AM   #4
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Synthetic stucco is applied over a fiberglass mesh which is applied over the foam.
Has it's benefits and it's liabilities.
On the downside you can not patch the stuff. The entire wall surface needs to be re coated to get it to look worth a damn.
If I was you I would not penetrate a synthetic stucco wall to hang a banner.
That's just me though
Gus Dering is offline
The Following 4 Users Say Thank You to Gus Dering For This Useful Post:
Deadhead Derek (05-03-2009), naptown CR (05-03-2009), nEighter (05-03-2009), sparehair (05-04-2009)
Old 05-03-2009, 09:08 AM   #5
stp57's Avatar
Thanks Duke,
This is how Dryvit says to anchor into their walls:
http://www.dryvit.com/fileshare/doc/...on/ds504_6.pdf
Only practical if a stud is handy (& detectable). The stuff I am dealing with doesn't appear to have plywood (or any kind of wood) behind it? If it does, it must be awfully thin?
Here is one man's take on potential problem with Dryvit:
http://video.google.com/videoplay?do...56611776297279
stp57 is offline
Old 05-03-2009, 09:16 AM   #6
Thanks Duke,
Good luck, I see a lot of that
going over DenseArmor, or whatever
drywall sheathing is called.
I'd think you'd need to fasten
a 1X, or some such, to the studs
then hang from that?
neolitic is offline
Old 05-03-2009, 09:27 AM   #7
stp57's Avatar
Thanks guys for the info.
I have learned that I have most likely voided EIFS's warranty & that a strong wind will most definitely rip the anchor from the wall. Also, patching this stuff is very difficult. In my case, I would have to locate metal studs to anchor into & they will never be where the customer happens to want the banners?
Oh well, gotta think this one through.
Steve
stp57 is offline
Old 05-03-2009, 09:33 AM   #8
Steve
That's why I said to fasten something
like a 1X hanging rail, or maybe
some sort of picture frame deal
if they have a standardized size
for these things.
I know......in your dreams....
neolitic is offline
Old 05-03-2009, 09:36 AM   #9
stp57's Avatar
Neo,
In my case it is usually eyebolts to hold 3x10 banners. Not looking good for me, I'm sure.
Steve
stp57 is offline
Old 05-03-2009, 10:29 AM   #10
Sean
SLSTech's Avatar
Eyebolts in the parapet area - generally the back side - where the plywood is, bottom ropes wrapped around a column or something similar if available
SLSTech is offline
Old 05-03-2009, 11:01 AM   #11
easymoney's Avatar
Trade: General
(puke)
easymoney is offline
Old 05-03-2009, 11:07 AM   #12
easymoney's Avatar
Trade: General
The objective is to securely hang some banner (size?) in a somewhat permanent location, right?
I'd take a hole saw maybe an inch or two in diameter and core out the foam or acousitc material away, and then anchor directly to the concrete or drywall as usual. save the core "plugs" somewhere on location to patch if things need to be moved...
Old 05-03-2009, 12:27 PM   #13
Originally Posted by easymoney View Post
(puke)
Why not?
I'm talking about fastening a horizontal
(12' ?) 1X that he can then screw, bolt,
whatever, into.
Ideally one placed 3 or 4' above the other
to fasten the top and bottom.
neolitic is offline
Old 05-03-2009, 12:32 PM   #14
KemoSabe
loneframer's Avatar
If there is plywood behind it, it won't be there for long. I've seen a bunch of buildings with a Dryvit system that have completely disintegrated because of moisture trapped behind the Tyvek. The styrofoam seems to have been the culprit. My insurance company won't insure an EIFS system.
loneframer is offline
Old 05-03-2009, 03:10 PM   #15
easymoney's Avatar
Trade: General
Why not?
whatever, into.
(still puke)
Old 05-03-2009, 03:18 PM   #16
Professional Instigator
rbsremodeling's Avatar
(still puke)
And your solution Is
rbsremodeling is offline
Old 05-03-2009, 03:36 PM   #17
Neo,
Steve
Thanks Duke,
Do you read any of the prior posts?
He seems to be saying there
is nothing there except studs.
Puke doesn't tell me why a ledger
is a bad idea.
Care to elaborate?
neolitic is offline
Old 05-03-2009, 03:55 PM   #18
easymoney's Avatar
Trade: General
I personally don't like the Idea of a "ledger" acrossed a clean surface, (if it's not clean then use what's there) as I mentioned I would tap into whats behind the "foam & stucco". Their HAS to be SOMETHING providing backing like plywood..., BUT, if not then use a large toggle or molly (with large washers) to catch the stucco's wire mesh. make sure you add some silicone behind the washer to keep moisture out.
Old 05-03-2009, 03:59 PM   #19
Capra aegagrus
Tinstaafl's Avatar
Neo's solution may not be all that pretty unless you paint it with butterflies, but it's structurally sound.
Yours isn't.
Tinstaafl is online now
Old 05-03-2009, 04:00 PM   #20
In other words, you have a solution
as long as you ignore the conditions
that stp57 says he is dealing with.
Cool.
neolitic is offline
Skimstone, interesting stuff genecarp Specialty Coatings 11 02-05-2012 09:41 PM
Dewalt track saw, funny stuff genecarp Carpentry 60 05-04-2009 09:23 PM
any of you guys used this stuff? dayexco Construction 8 02-11-2009 03:03 PM
Watch your stuff! tgeb Excavation & Site Work 9 02-04-2009 06:28 AM
new stuff to me mike stanislaw Decks & Fencing 3 12-31-2008 08:01 AM
