What Is Solution For Thermal Insulating Of Exterior Walls With Sheetrock On?
Old 01-13-2018, 11:41 AM   #1
tipitop's Avatar
Trade: carpenter
Rewards Points: 2,867
It is probably question that I'm asked most not only at job sites than in bars. I know in one case before 13 years guy called foam guys. They drill small hole every two feet vertically and every 16" horizontally (between studs). Then with small nozzle they throw foam in. I remember that it regard insulation worked excellent as I was at that same project over entire winter.
Now my question if that work, and seem to me it work (can be wrong) why other people allow itself to live in non insulated houses in MN?
Edit to be sure I mean sheetrock on the walls from inside in house.
tipitop is offline
Old 01-13-2018, 12:21 PM   #2
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 848
Re: What Is Solution For Thermal Insulating Of Exterior Walls With Sheetrock On?
To answer your question about "why" people don't spray foam the interior of the walls, all I can say is that they have made the decision that the cost of install is greater than they will recoup in energy prices and comfort level over time.
I don't know if they are right or not but they are right for themselves.
Andy.
ScipioAfricanus is offline
Old 01-13-2018, 12:21 PM   #3
fjn's Avatar
Trade: mason
Rewards Points: 8,386
Instead of foam,possibly dense pack cellulose would be a better alternative.The foam may cause moisture build up problems.
The current issue of FHB magazine just covered dense pack,although it was for new construction.
fjn is offline
Old 01-13-2018, 12:29 PM   #4
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 3,596
Different climate in MN, but here I encounter dense pack cellulose installed from the exterior. I have yet to find moisture issues caused by it. It's fairly affordable too.
I've also seen foam, and it had more voids than the cellulose.
Golden view is online now
Old 01-13-2018, 12:53 PM   #5
tipitop's Avatar
Trade: carpenter
You said cellulose installed from exterior. But it go up to only 2". Foam inside walls go to 3,5" even more for 2X6 and need not siding off. Above is good call about moisture issue as plastic cover is not applied from inside like when new wall is covered.
I see people freezing in houses all time when they call me to see some project. No surprise as there is virtually nothing in the walls of houses that are build in 60ties and down. Of course except asbestos insulation that transformed to (cancerogen) dust.
tipitop is offline
Old 01-13-2018, 12:57 PM   #6
edward trowelhands
Trade: Diplomat
Cellulose, like paper fiber. Any thickness. I've even seen 24" thick walls with it blown in.
The Following 2 Users Say Thank You to Golden view For This Useful Post:
fjn (01-13-2018), tipitop (01-14-2018)
Old 01-13-2018, 04:55 PM   #7
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 20
I dare say because said injected foam shrinks & leaves gaps later... now if you want to remove siding & sheathing then apply it properly or else go with dense-packed cellulose & verify with thermal camera
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Philament (01-13-2018)
Old 01-13-2018, 08:28 PM   #8
hdavis's Avatar
Rewards Points: 3,391
Dense pack drill and fill cellulose, either from the inside or outside. It's fast, fairly cheap, and it can be done with the house occupied if done from the outside.
Check sheetrock attachment first, and fix any problem areas.
hdavis is online now
Old 01-13-2018, 08:30 PM   #9
hdavis's Avatar
If there is knob and tube in the walls, those areas can't be insulated at all.
Old 01-14-2018, 11:29 PM   #10
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Rewards Points: 4,434
Send a message via AIM to Michaeljp86
My house is 2 story balloon framed so I got in the attic and on the gabled ends put the hose right down the wall to the foundations and filled it with cellulose. the other walls I drilled through the drywall.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old Yesterday, 08:09 AM   #11
Sean
SLSTech's Avatar
Rewards Points: 20
To add on to HDavis excellent comment, if there is any water issues you also should not blow in any insulation till that is fixed along with removing any knob & tube. If you have aluminum wiring - also no foam
SLSTech is offline
Insulating attic question power Insulation 19 03-10-2013 08:55 PM
Insulating Walls - what if ???? power Insulation 6 03-08-2013 10:12 AM
dewalt tough system storage solution Rich D. Tools & Equipment 39 08-01-2012 02:11 PM
Stucco on wallpaper... The best solution for residential buildings. aulona Wallpaper 10 07-23-2012 03:30 PM
Beating sheetrock solution cnydave Finish Carpentry 19 05-29-2009 09:40 AM
