What The Heck Is This?
Old 07-01-2009, 12:50 AM   #1
EVIL GENIUS
Michaeljp86's Avatar
Trade: General Contractor, electrical, fabrication, & welding
Send a message via AIM to Michaeljp86
This came from a HVAC contractors auction. They had a huge box of power tools so this came with. Its a ridgid 776, whatever that is. It would make a nice ground clamp for welding pipe.
I am just a vessel from which genius flows -Homer Simpson
Global warming is a myth, like evolution and the metric system.
U.S. Coast Guard
Michaeljp86 is offline
Old 07-01-2009, 03:44 AM   #2
BobsLandscaping's Avatar
Trade: Landscaping
Re: What The Heck Is This?
Tubing cutter?
BobsLandscaping is offline
Old 07-01-2009, 06:42 AM   #3
BillD's Avatar
Trade: General contractor
It looks like a pipe clamp for a cut off saw of some sort.
Bill
BillD is offline
Old 07-01-2009, 06:53 AM   #4
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Pinch off tool.
Cdat is offline
The Following User Says Thank You to Cdat For This Useful Post:
hughjazz (07-01-2009)
Old 07-01-2009, 09:20 AM   #5
OGStilts's Avatar
It's a hinge door stop I didn't know ridgid made those.
OGStilts is offline
Old 07-01-2009, 09:36 AM   #6
EVIL GENIUS
Here is another pic, it looks almost like its supposed to punch a hole through a pipe. The threaded rod is hollow, I dont know if its missing parts or not. It may go with a pipe threading machine or something. Some guy probably bought something at the auction and its missing this.
U.S. Coast Guard
Old 07-01-2009, 11:32 AM   #7
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
i think it's a peicing tool for steel pipes used when saddling a connection for gas.
NickTech is offline
Old 07-01-2009, 12:06 PM   #8
EVIL GENIUS
The auctioneer asked one guy standing there what it was and I didnt listen because I didnt care. Nobody wanted it so they threw it in a pile of power tools and sold the whole pile.
U.S. Coast Guard
Old 07-01-2009, 01:09 PM   #9
TxElectrician's Avatar
Trade: Electrical
I can't tell you what it is, but a google of "ridgid 776" brings your question up in the #2 spot!
TxElectrician is offline
Old 07-01-2009, 01:17 PM   #10
theworx's Avatar
Maybe something a fire sprinkler guy would use? Most of the guys use Rigid machines here.
theworx is offline
Old 07-01-2009, 02:14 PM   #11
mikec's Avatar
Trade: remodeling contractor
some sort of wet tap?
mikec is offline
Old 07-01-2009, 02:30 PM   #12
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
Maybe a support arm for a threader?
Cdat is offline
Old 07-01-2009, 04:07 PM   #13
EVIL GENIUS
I googled it before I posted it here hoping to find out what it is.
U.S. Coast Guard
Old 07-01-2009, 04:12 PM   #14
Sr. Estimator
part&pieces's Avatar
Trade: Estimator
Left handed smoke valve?
Dunno, actually but it looks like a pipe clamp to be used with a pipe threader.
part&pieces is offline
Old 07-01-2009, 04:57 PM   #15
PGD's Avatar
Trade: Doorfitter
It's not a tubing cutter or pipe cutter 'cause the teeth wouldn't allow it to spin.
It's not likely a tap (with missing blade) cause it's off center and why limit the diameter.
It's not a clamp cause it's got a few different leverage handles.
It looks like aluminum so you can carry it around in your tool pouch ....
I think it's an adjustable wrench with a missing jaw. Made by Rube Goldberg himself!
PGD is offline
The Following User Says Thank You to PGD For This Useful Post:
Deadhead Derek (07-01-2009)
Old 07-01-2009, 08:54 PM   #16
buildpinnacle's Avatar
Trade: Public Insurance Adjuster
Definitely a can opener with the motor removed.
Pinnacle Limited
Public Insurance Adjusters
(800) 918-7840
buildpinnacle is offline
Old 07-01-2009, 09:02 PM   #17
JamesKB2's Avatar
Trade: GC Residential / Light Commercial
I agree, it's part of a greater assembly. The smooth rod is a pivot and installs into another part. The clamp jaw (lower) is there, but the upper jaw might have inserted into the hollow shank of the screw. It might be offset to allow the missing jaw to exert more force opposite the direction of torque.
This, just from looking at it. I did a quick search of Ridgid's website, but couldn't see anything on current models of reamers or cutters or threaders that had that part on it.
HOWEVER, if you REALLY want to know, go to their website and submit a query to them with your pictures. I'm sure they have somebody there that knows....
I will build you whatever you want, just draw it on the back of a big enough check.
JamesKB2 is offline
Old 07-01-2009, 10:53 PM   #18
hughjazz's Avatar
Trade: carpenter
Pinch off tool.
I'd need a MUCH BIGGER one myself
hughjazz is offline
Old 07-01-2009, 10:58 PM   #19
I builds'em
Winchester's Avatar
Trade: Renovations & Decks
I agree with these guys as the most logical answer
Wrenches gain no advantages from perpendicular handles and it would just get in the way.
I've never seen something for pinching off with jaws like that (teeth).
Teeth are to stop it from spinning. It has to be a clamp.
Winchester is offline
Old 07-01-2009, 11:09 PM   #20
Inner10's Avatar
Trade: Control Systems
True it has teeth, but why the relief hole in the bottom? That screams punch.
Inner10 is online now
What the heck do I do now? superdeez Off Topic (Non Trade) 31 04-06-2009 01:43 PM
What the Heck? MrRoofer Roofing 3 03-04-2009 10:22 AM
55 volts on both hot and neutral, what the heck!? karma_carpentry Electrical 32 02-28-2009 09:12 AM
How in the heck do we remove old adhesive? Porta-Crane Flooring 12 02-15-2009 11:10 AM
