Venting A Server Room?
Old 03-17-2008, 01:17 AM   #1
wireless's Avatar
Trade: Electrician
What is the best way to keep a server room cooler? Would a regular bathroom vent work?
wireless is offline
Old 03-17-2008, 01:55 AM   #2
General Contractor
Laketahoedan's Avatar
Re: Venting A Server Room?
yes, air extraction will help remove the warm air created by the servers.
If you can introduce cooler air on one side of the room (near the floor and have your exhaust near the ceiling it would limit the heat.
Air conditioning would be ideal for server longevity.
Laketahoedan is offline
Old 03-17-2008, 02:10 AM   #3
send_it_all's Avatar
How funny it is that this topic came up. I just did this at 19 branches of a bank. I used (4) 14" x 25" return air grills. Cut a hole in the bottom of the door and sanwiched it with two of the grills, then cut a similar hole in the sheetrock above the door way and did the same thing. Turn the grills so the angles on the vents do their best to hide the framing in the top opening.
send_it_all is offline
Old 03-17-2008, 02:10 AM   #4
mdshunk's Avatar
Larger server rooms get a CRAC unit such as those made by Leibert, but smaller one's normally have a mini-split highwall unit.
mdshunk is offline
Old 03-17-2008, 11:44 AM   #5
wireless's Avatar
Trade: Electrician
That is what I told them initially. It is 48 Square feet with 9' ceilings. I was thinking of a small bath vent and using the space under the door as the makeup air or putting a open vent in the drop ceiling on the opposite side of the vent.
wireless is offline
Old 03-17-2008, 12:16 PM   #6
kauser667's Avatar
be carefull that the walls are not fire rated. If so you will need fire dampers.
kauser667 is offline
How do you spray a room - new construction? Zeebo Painting & Finish Work 16 01-27-2008 11:32 AM
Advice with room addition and blueprints A.W.Davis Remodeling 35 03-28-2007 07:32 PM
Room to room fan dkillianjr Electrical 12 12-14-2006 01:08 AM
Room to room fan Larry007 HVAC 5 11-24-2006 01:07 PM
New Dedicated Server Coming (again) Nathan General Discussion 13 08-30-2006 02:00 PM
