Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Contractors Talk Forums > General Discussion
Old 11-05-2009, 10:15 AM   #1
Higgs's Avatar
Trade: CE Project Engineer
Vented Soffit
Yestarday got a call from our housing office about some soffit that the wind ripped of the side of one of our housing units. I went out to check it out because our home inspector is currently on leave. Turns out the contractor stapled a 1x2 furring strip to the rafters and then stapled the soffit to the furring strip. Well the staples only penetrated about 1/2" so when we got a good gust of wind which we do all the time. It ripped the vented soffit, wrap, and furring strips, down. Has anyone seens this before. its a first for me and i have done a good bit of siding work.
Higgins
"The more we sweat in peace, the less we bleed in war."
-- Vijaya Lakshmi Pandit (1900-1990)
Higgs is offline   Reply With Quote
Old 11-05-2009, 10:40 AM   #2
Just sounds like not enough penetration
on the fasteners.
neolitic is offline   Reply With Quote
Old 11-05-2009, 10:51 AM   #3
Hmmm
edwardbros's Avatar
To me sounds like the installer was lazy and instead of grabbing a different gun to nail on the furing strip, used what they had in there hand.
Fix it right and plan on going back when the otherside lets loose, then fix that side right.
Also make sure you tell your installer you found his short cut, and to change his ways if he still wants to do work for you.
edwardbros is offline   Reply With Quote
Old 11-05-2009, 10:59 AM   #4
Trade: Roofing, Siding
I have seen this but only on large panels. As EdwardBros stated, just seems like the guy did not want to grab a different gun. Also, how do you staple it? Is there a staple in every rib located on the outside or just one into a panel?
I admit the first time I did soffit, I figured they were light enough and only needed one. A few weeks later I had to go back and since then I make sure that sucker is stapled up there.
BamBamm5144 is online now   Reply With Quote
Old 11-05-2009, 11:20 AM   #5
call the sider and give him the opportunity to fix it for you.
jhark123 is offline   Reply With Quote
Old 11-05-2009, 11:29 AM   #6
Trade: Framing
Only seen that on large soffit panels, porch ceilings.
If the staples had been long enough into the rafterw or trusses, it probable would not have occurred.
Or did you have straight line tornado winds??
Framer53 is offline   Reply With Quote
Old 11-05-2009, 11:31 AM   #7
Something tells me that it
will be a bit more complicated than
one phone call since the customer
is the USAF.
Old 11-05-2009, 09:20 PM   #8
Trade: Siding, Metal Roofs, and whatever to pay the bills
You say USAF, Was a big El Paso Co. involved with construction of the homes ?
The subs they had here used 3/8 staples on soffits and 2" nails for siding over 1 1/2 inch foam. They didnt use 1x2s here just tried to hit studs (failed alot)
Everytime a wind blows I get calls
Red Adobe is offline   Reply With Quote
Old 11-06-2009, 05:26 AM   #9
I repaired some soffit a month or so ago that was fastened with T-50 staples You never know how cheap or stupid someone is going to be by the size of the company.
Red Adobe....kinda provides for a steady income doesn't it? When you find places like that it an instant love hate relationship with someone you don't even know.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline   Reply With Quote
Old 11-06-2009, 08:34 AM   #10
Yes love the $$$, I use an older unmarked truck for jobs like that, so no one sees my real CO truck and asociates me with doing the original job
Old 11-07-2009, 02:02 PM   #11
Higgs's Avatar
even though the house is out of warenty we are going to have the contractor come out and fix it due to sub par construction. we are also going to check the rest of the houses in the neighborhood and if they are the same have them fix those as well. should be interesting.
Higgins
Old 11-07-2009, 02:54 PM   #12
freemason21's Avatar
Trade: carpentry and painting
that's always the problem!!
Originally Posted by Mike Finley View Post
You're probably the next coming of Jesus in regards to construction.
freemason21 is offline   Reply With Quote
cathedral ceiling with no vented soffit acces straightline Insulation 1 10-24-2009 10:36 AM
Cedar soffit mopardave Carpentry 9 06-07-2009 04:00 AM
Vinyl soffit span... what backing OC? bobaganoosh Windows, Siding and Doors 11 12-24-2008 12:41 AM
Surfing Soffit Dilemma smadax Decks & Fencing 10 12-08-2008 01:07 AM
MA Code, and vented Soffit Patrick General Discussion 14 04-30-2008 09:44 PM
