Used Skidsteer
Old 11-21-2017, 09:19 PM   #21
rustyjames's Avatar
Rewards Points: 1,548
Re: Used Skidsteer
Originally Posted by Mr.joe View Post
Now you guys got me thinking tires or tracks? Lol I've only used tires so may stick with that. Do the tracks wear out easy on asphalt?
Sent from my SM-N950W using Tapatalk
If you're mainly on asphalt you don't want tracks, stick with tires, better yet foam filled, or solid.
rustyjames is online now
Old 11-22-2017, 06:49 AM   #22
Mr.joe's Avatar
Trade: General contractor
Rewards Points: 196
Re: Used Skidsteer
We would manly be on dirt but some time spent on the road scraping mud off
Mr.joe is offline
Old 11-22-2017, 07:54 AM   #23
MattK's Avatar
Trade: Framing, Roofing, Siding
Rewards Points: 1,058
Re: Used Skidsteer
Back to your original post for a minute.
Best part of a skid steer is you can haul it with most pickups. As someone else said, I would invest in the forks attachment as well, maybe even the auger too.
I wouldn't get into renting it out. You can probably get a used one with a trailer and an attachment or two for 20k so if it goes a month without earning you any money it isn't going to crush you.
--MATT
Add your Facebook Business Site to "THE LIST"
http://www.contractortalk.com/f12/if...-should-79504/
Page 77 has the updated, complete list.
MattK is online now
The Following User Says Thank You to MattK For This Useful Post:
Mr.joe (11-26-2017)
Old 11-22-2017, 08:00 AM   #24
rustyjames's Avatar
Re: Used Skidsteer
As long as you're on stiffer ground then regular tires should work fine.
Old 11-22-2017, 08:14 AM   #25
Fishindude's Avatar
Trade: Industrial
Rewards Points: 396
Re: Used Skidsteer
Tracks are great but they cost more money and will require more upkeep and maintenance as they have a lot more moving parts. When they go bad it's expensive.
Fishindude is online now
The Following 2 Users Say Thank You to Fishindude For This Useful Post:
Mr.joe (11-26-2017), rustyjames (11-22-2017)
Old 11-22-2017, 12:02 PM   #26
Windycity's Avatar
Trade: Masonry
Rewards Points: 5,798
Re: Used Skidsteer
A lot has to do with the operator as well. a lot of operators like to jam the controls opposite one another so you’re basically doing circles standing still which wears the hell out of the tires and/or tracks and it will tear up any soft surface. Whereas if you make more gradual turns you will do less damage to both tires/tracks and the landscaping.
Here’s a general rule, if you are going to be on a lot of mixed surfaces but mostly concrete asphalt etc. you generally want to stick with tires, if you are going to constantly be on glass, mud, sand and other soft surfaces the tracks are much better especially if it is a lot of wet mud where tires will easily get stuck
You might want to compare the price difference between tracks and tires because tracks are significantly higher cost to replace. Both of the concrete contractors I know have between 10-20 skid-steers which they use obviously for concrete and they plow snow in the winter time with them and neither one has tracked machines
Windycity is online now
Old 11-22-2017, 12:15 PM   #27
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,622
Re: Used Skidsteer
Also a track machine is going to be A LOT more new.
jhark123 is offline
The Following User Says Thank You to jhark123 For This Useful Post:
Old 11-22-2017, 07:18 PM   #28
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 416
Re: Used Skidsteer
Originally Posted by overanalyze View Post
I have always wanted to try a set of over the tire tracks on our machine to see how they did. Seems like they could be a good option and not the worst thing to take off if you didn't want or need the tracks for a specific job.
Sent from my SM-T310 using Tapatalk
I just picked up a set of Grouser ott for my skidsteer last spring for $3400. It makes it a whole new machine. Right after I got them, we were on a job back in the woods where they almost paid for themselves. Just got off another job a couple weeks ago where they definitely paid for themselves.
I take them off if we are gonna be working on blacktop driveways and such, it only takes about 10 mins to take them off, a bit longer to put on.
Sent from my SM-G900V using Tapatalk
mrcat is offline
The Following 2 Users Say Thank You to mrcat For This Useful Post:
jhark123 (11-22-2017), overanalyze (11-22-2017)
Old 11-22-2017, 08:27 PM   #29
Mike-B's Avatar
Rewards Points: 626
Re: Used Skidsteer
We've got a 753, S185, and T190.
753 and 185 are rubber tire machines. We filled the tires and run steel tracks on them. We spend most of our time in the dirt and mud. Tracks are way better for working in soft conditions.
The over the tire steel tracks do have drawbacks though. If they are loose and your tires are wet, you'll be spinning tires inside the tracks.
We leave the steel tracks on 99% of the time. They only come off for jobs on asphalt.
The T190 is a rubber track machine. It is much smoother over rough terrain. It gets better traction than the wheeled machines so you can push/dig harder before you lose traction compared to one with tires.
We used to have a backhoe attachment for the loaders. It worked just fine for digging ditches in decent conditions. Once you get into rock or stiff soils it always tried to pull itself into the ditch instead of pull dirt out of the ditch. I'd not consider it as a production tool for large excavations.
Mike-B is offline
Old 11-23-2017, 05:45 AM   #30
Joasis's Avatar
Rewards Points: 1,466
Re: Used Skidsteer
I have a buddy that was using a 773 Bobcat...he is a concrete guy. He was wanting a new/better skid loader, and not being internet savvy, asked me to help him find one. He wanted another wheeled machine even though I told him tracks were the way.
One rainy, gray, dreary day, he came over to my office and we were scanning the net to see what was available....and I got a call to go unload a steel building that showed up without anyone thinking it would be muddy on the job site.
So my buddy goes with me....my truck was hooked to our gooseneck trailer, and I got on my T200, used the forks to tip the ramps back (meaning I wasn't getting wet or dirty, backed the machine up the ramps, and then used the forks pull pull the ramps back over....got off the Bobcat and walked the trailer back to my truck. No mud on me. Hooked my pre-set chains and off we went.
We get to the job site, and the country road is sloppy wet mud....the drive way is under water....and I tell the trucker to unstrap, and get out of the way. I tipped the ramps from the seat of the Bobcat, off the trailer, and unloaded the entire building kit, sheets and all, without help, without trouble, and without getting out of the machine....now the Cat was dirty and muddy, and I did wear gloves to re-chain when I loaded her back, but essentially....the toughest part of that job on a cold crappy wet day was driving there.
My buddy had got out of the truck and put gloves on to "help" and I waved him off, so he watched the show from the cab....and when we headed back to my office, he said maybe he needed to think about tracks. He could not have loaded his 773 on a wet trailer deck like I did the T200 either.
He bought a used T190 for 18k, and then a year later, a brand new 430 or whatever the new machine that replaced the 190. His old 773 is used now with a demo hammer, because he doesn't give a crap about how hard it is on the old one, and that is about one place a wheeled loaded has value...concrete demolition...but I run my hammer on my T200, and I find I can push the breaker against horizontal walls better with tracks, even on concrete.
I have had a 610, 642, 763, and bought the T200...and I would not trade the tracks for all of my wheel machines....difference between night and day.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
The Following 2 Users Say Thank You to Joasis For This Useful Post:
Mr.joe (11-27-2017), shanewreckd (11-23-2017)
Old 11-27-2017, 08:01 AM   #31
Mr.joe's Avatar
Rewards Points: 196
Re: Used Skidsteer
Found an auction place in Toronto I'm going to check out for an used skid steer. I'm used to the caterpillar controls and bobcat feet pedals. How's case and new Holland?
Mr.joe is offline
Old 11-27-2017, 04:51 PM   #32
Joasis's Avatar
Re: Used Skidsteer
If I were buying today, I would not buy the Bobcat style controls again, I would go with pilot controls. Easier on the ankles.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
The Following User Says Thank You to Joasis For This Useful Post:
Mr.joe (11-27-2017)
Old 11-27-2017, 06:21 PM   #33
mrcat's Avatar
Rewards Points: 416
Re: Used Skidsteer
I'm partial to case, but that's probably because I have 10's of thousands of hours on them. I haven't operated the newest batch yet though...
I've ran cat, bobcat, new holland, and takeuchi, I would put new holland at the bottom of that bunch just from an operators stand point.
If you're used to the foot pedals, the case hand controls don't take long to get used to.
mrcat is offline
Old 11-27-2017, 06:41 PM   #34
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 894
Re: Used Skidsteer
When we bought our S175 it was one of the first machines to have a switch to go between hand or foot controls. Once I got used to hand controls I never went back. It hasn't been switched into foot control for years. To it is easier to finesse the buckets with hand controls vs foot.
overanalyze is offline
Old 11-27-2017, 07:32 PM   #35
rustyjames's Avatar
Re: Used Skidsteer
As far as skid steers, I've only run Bobcats and never really cared for the foot operated bucket controls.
Old 11-27-2017, 08:04 PM   #36
Mr.joe's Avatar
Rewards Points: 196
Re: Used Skidsteer
What's your guys yearly maintenance cost?
Mr.joe is offline
Old 11-28-2017, 06:25 AM   #37
Mr.joe's Avatar
Rewards Points: 196
Re: Used Skidsteer
Also would 4000 hours be too much? On a skid steer?
Mr.joe is offline
Old 11-28-2017, 08:35 AM   #38
mrcat's Avatar
Rewards Points: 416
Re: Used Skidsteer
4,000 hrs is pushing it for a used machine, it's not bad if it's been meticulously maintained, but that's pretty rare, if it's been on a farm or construction site all it's life, it's usually pretty beat up by then. My dad has a couple with over 10,000 hrs on them, but he's a stickler for maintenance. I would shoot for under 2000 hrs, I picked my case 70XT up with 1500 hrs on it.
mrcat is offline
The Following User Says Thank You to mrcat For This Useful Post:
Mr.joe (11-28-2017)
Hydraulic Hammer - skidsteer farmboy555 Tools & Equipment 0 02-23-2017 05:11 PM
Small tractor vs skidsteer NYCB Tools & Equipment 11 07-05-2012 10:34 PM
mini skidsteer - wheel vs. track sunolbob Landscaping 5 04-10-2012 09:36 AM
thinking about a skidsteer nwksremodeler Excavation & Site Work 25 05-22-2011 01:12 PM
Any review on New Holland's LS185b skidsteer denver 2 Excavation & Site Work 5 02-11-2010 09:23 AM
